I'm having an odd... issue? I'm not sure if it's intended behavior. My extrusion dialog box has begun to keep all settings from the extrude preceding it, including direction, extent type, distance, taper etc.
So as an example, I create an extrusion:
If I then try to extrude another sketch it's automatically filling in the distance from the previous extrusion. It does the same thing for extent type and direction when making more complex models, and even keeps them between files.
Does anyone know how to disable this? I would prefer to start from a clean slate as far as settings go, and this has only started happening recently.
