Extrude distance equation simplifies itself
numanair
numanair
When entering a simple equation for extrusion distance, the equation collapses itself into its simplest form. For example, I enter ".5+1" and it will change into "1.5". This is not how it used to behave, and other dimensional input does not act this way (such as fillet radius). This puts a complete halt to all my CAD as I use this feature all the time!
TrippyLighting
Yep, that is a bug. There are other areas where that happens as well!
@jodom4  @Phil.E Can you note this down?
When editing, the field displays the value but not the expression. I recently responded to another thread with another filed where that also was the case. I tagged an AD employee but no one ever responded.
It's time to put a stop to that!
jeff_strater
seems to work for me:
Jeff Strater
Engineering Director
TrippyLighting
Yes, the expression is correct in the parameters dialogue.
But when you edit the extrude feature in the timeline, the field in the dialogue displays the value, not the expression.
jeff_strater
ah, so it is Edit Extrude that doesn't work, not Extrude.  OK, got it.
[edit] created FUS-96223 for this bug
Jeff Strater
