Extract the Value of A User Parameter
I would like to simply divide a unit-less number by a unit number, given this isn't possible does anyone know how to extract the value of a parameter (leaving the parameter unit-less in the expression) so division is possible.
HughesTooling
You need to add * 1cm at the end.
Also please don't attach pictures, use the insert photo option from the editor toolbar.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
You can also make a parameter unitless if you divide it by 1 unit. Here's some examples.
Mark
Mark Hughes
Thankyou. I'm not sure why that wasn't coming to mind.
