exporting any file of any type causing fusion to crash
BinarySoftware
Message 1 of 10
BinarySoftware
everytime i try to export a drawing to a pdf file or export a part as a stl to be 3d printed fusion 360 crashes. i need help i have deadlines i need to meet. this started happing on 3/23 after lunch time. it is supposed to update on 3/27 but right now it is unusable.
Replies (9)
Message 2 of 10
BinarySoftware
i have restarted the computer and the program as well as reinstalling fusion 360. this usually happens before a update
Message 3 of 10
g-andresen
Hi;
@BinarySoftware wrote:
... as well as reinstalling fusion 360.
did you use CLEAN UNINSTALL?
günther
Message 4 of 10
BinarySoftware
yes and i am still having problems with it. this has happened a couple times before a big update happens. ive also had problems with lag, something as simple as rotating a part to look at another face or closing a drawing will cause my computer to struggle even though it has 128gb of ram
Message 5 of 10
g-andresen
If you share a sample file we could take a look at it.
File > export > save as f3d on local device  > attach it to the next post
günther
Message 6 of 10
HughesTooling
When you say it crashes do you get the crash report dialog or does Fusion just close? Can you make a screencast of what you are seeing\doing? One thought, is it the problem where you don't get a save dialog and Fusion becomes unresponsive?
What is your system spec and OS.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 10
BinarySoftware
i get both a crashreport sometimes and others it just closes out
" error report 302959415 to Autodesk." from my most recent crash i was just trying to export a part crash report.JPGdetails.JPG
Message 8 of 10
HughesTooling
@Phil.E  Can you help with this?
Thanks Mark
Mark Hughes
Message 9 of 10
Phil.E
Thanks @HughesTooling
There are two known issues that affect this workflow. The most common is fixed by a clean uninstall, using the cleaner tool or manual steps. There is also a workaround.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
WorkaroundExport the STL files from a web browser instead of the Fusion 360 desktop client.
The less common issue is related to network shares. If the last used export location is a network share that is not available Fusion will crash.
Here is a customer comment about it.
"...it was the network share shortcut in file save dialog that was connected to password protected network share. Fusion 360 never asked for any credentials and it just .. failed. After clicking on the share with Explorer and entering credentials Fusion 360 started working again."
Here is another forum report with similar outcome:
https://forums.autodesk.com/t5/fusion-360-support/creash-on-stl-export-to-bit-locked-drive/m-p/84828...
Please let me know if either of these are happening for you.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 10 of 10
BinarySoftware
i connected to our cloud server and it fixed the problem thank you.
