I am getting back into 3d printing and I have this weird issue where if I export a body to an STL file, the mesh looks like the model is complete but when sliced in cura, the model is missing a face.
I made a simple test model in Fusion 360, a 30mm x 30mm x 6mm rectangle and I inspected the mesh :
Which seems fine to me.
However, when I slice the exported stl of the body above in Cura, it's missing the top surface, creating a hollow box.
I am not sure if Fusion or Cura is the problem here, but in the past, when I used fusion 360 to create models, I never had this issue.
To export the STL, I use the save as mesh... menu. I tried different settings for the quality of the export but it didnt make a difference.
Am I missing something here?
