Export to STL not possible
gillesbielmann
Observer Observer
gillesbielmann
Observer
Observer
Fusion 360 can no longer export to STL.
The progress bar doesn't move at all, even after several hours.
I've tried with other drawings, cleared the cache, restarted the computer, reinstalled the program but it still doesn't work.
I don't know what else to do. Can you please help me?
jhackney1972
You should use the Save as Mesh command instead of Export. It is much more efficient and offers some advantages. Select your Body in the Browser, right mouse click and select the command. Set you desired parameters in the dialog box (not shown) and save your file.
John Hackney, Retired
Phil.E
There is a new build of Fusion that should have a fix for this. Can you please update Fusion to build 2.0.18220, which was released yesterday, and let us know if the issue is solved for you?
How to update Fusion
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
gillesbielmann
Observer
Observer
Thank you really much, soir solution Works fine !
