Export to DXF does NOT include text.
TrophySmackWiz
TrophySmackWiz
Exporting to DXF doesn't include any of the text on sketch 3.
jeff_strater
correct.  DXF export does not support native sketch text.  You will have to "explode" the sketch text into lines/arcs to get it included in the DXF
Jeff Strater
Engineering Director
HughesTooling
If you use Save as DXF from the right click menu you can export text but you can only export one sketch at a time like this.
Here's your sketch4 exported to Rhino using Save As DXF.
Mark Hughes
Owner, Hughes Tooling
TrophySmackWiz
Are you saying you're simply confirming the behavior, or are you saying that this is INTENDED behavior.
For the record, I put this in the bug forum because it astonished me that it wasn't exporting text without an additional step.
TrophySmackWiz
Heheh thanks. This is exactly why the text is on its' own sketch independent of everything else. Makes it easier to explode.
jeff_strater
actually, I was mistaken.  Save as DXF from a sketch does support text now.  I think my info was outdated.  Thanks to @HughesTooling for explaining how to use this.
Jeff Strater
TrophySmackWiz
Oh hell I didn't even know that was working.. Now if they could just make the export function use whatever tweak they did to the single sketch save as we can close this.
