Message 1 of 28
I need to provide a full size pdf from a sketch. I use to export the sketch as .dxf file then use dwg trueview to generate the pdf from this dxf file. This method was working well, but since some months, I can't anymore export sketch as dxf , it freeze fusion360 when there are too much lines on the sketch. the bug report was posted there: https://forums.autodesk.com/t5/fusion-360-support/save-sketch-to-dxf-freeze/td-p/12002548
as this is not fixed and don't know if it will be fixed, I'm looking for an other way to generate those full size pdf, does anyone have a method to do it ?
