Export of Machine Model Failed - "f3z machine model not supported"
pmusselmanJLVUJ
pmusselmanJLVUJ
Hi There,
I am trying to export a machine model so that I can have a twin CAM setup on a different team but incur the following error.
Any ideas?
I have a team where I am designing things and another where I would like to CAM/machine from. There doesn't seem like a good way to share designs between teams. You can share with another account but you must fully switch teams to access which leaves behind everything else.
Thanks!
a.laasW8M6T
Hi
If your machine model has linked components that would create the scenario where Fusion would be trying to create an .f3z file
You can use break link to make sure all the components are internal
This must be a recent change as I'm sure you could export.f3z machines before
Andrew Laas
Senior Machinist, Scott Automation
