export my files, switching to another program
dhb9mm
dhb9mm
I am switching to another program for my CAD/CAM, and wish to export my files so I don't loose al my drawings i have spent many hours making.  In the new program I can only open DXF, DWG, EPS, AI, PDF, and SVG. My files are all done in 2D so SVG is not an option, or rather I think that is why it fails when i try to export my files as an SVG. I am using the personal version so I can't export in a file format i can use. Is there any way I can keep from loosing my files?
g-andresen
1. If you need 2 D files > export (save) as DXF
2. Fusion has no Export SVG option
günther
dhb9mm
for personal use, you cant export as dxf
jhackney1972
As you can see in the Screencast, the Save as DXF works just fine.  You have to export from the sketch in the Design Workspace.  If you have multiple sketches in your design you may have to combine them.
John Hackney, Retired
