Export issue
Export issue
fabrizio.bettinelli
Message 1 of 9
Export issue
fabrizio.bettinelli
Hello. I find a issue when I try to export drawing to .stl...so, for real when I click export command on a FILE menù, the SW doesn't give any replys, like open menù or something else...why?
I use the personal version from 28/03/2021
Thanks for your help!
Fabrizio
Replies (8)
Message 2 of 9
g-andresen
try this
günther
Message 3 of 9
fabrizio.bettinelli
Hi, I've tried from the menu you indicate, I have the same issue... don't know why.
Now I've uninstalled the sw, this evening I will reinstall it and try more...
Message 4 of 9
g-andresen
for a new installation the CLEAN UNINSTALL tool must be used!
günther
Message 5 of 9
HughesTooling
There was a bug if your last save was to a drive or folder that's no longer accessible Fusion doesn't show the Open\Save dialogs. Post here explains the problem and how to fix.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 6 of 9
fabrizio.bettinelli
This is a good thing to know! Thanks!
Message 7 of 9
fabrizio.bettinelli
Perfect, I will check the post and try to solve the problem...
Thinking about that...Fusion can have right to doesn't work if the save folder will be moved...
Message 8 of 9
fabrizio.bettinelli
I'll let you know how goes my issue!
Message 9 of 9
fabrizio.bettinelli
Hi all,
I've solved my issue!
I moved the folder in original position and everything work well now!
Fabrizio!
