export in .dwg autocad version 2007
hi, i've a problem to export a 3d  fusion 360's file, i need to export it in  .dwg version  for autocad 2007, i've tried with the standar export but it does not work, how can ai do?
tnx
TheCADWhisperer
File>Export as ACIS (*.sat) and then in AutoCAD issue the ACISIN command.
Attach your file here if you can't figure it out.
ryan.bales
Autodesk Support
Autodesk Support
The drawings platform is built on 2017/2018 AutoCAD. You cannot export a drawing in an older version. Aside from that, it contains objects that were created far after 2007.
You'll need to open it in a newer version of AutoCAD(2017 or 2018) and export the layout and then save down.
Read through this as well: How to edit DWGs from Fusion 360 in the model workspace in AutoCAD
Ryan Bales
Fusion 360 Product Support
