Export Flat Pattern DXF Bug?
HughesTooling
Consultant Consultant
HughesTooling
There's a request on the ideastation that I think is a bug so thought I'd make a post here to demonstrate.
The problem is if you open a design, activate a flat pattern then export as a DXF the file is flagged as edited and if you have autosave enable you get a new version. This can cause a lot of problems if the design is part of an assembly and\or has a 2d drawing as they will then need updating. The reason I think the is a bug is there's no problem just activating a flat pattern then exiting the flat pattern, it's only if you export the DXF the file shows as edited.
Mark
Mark Hughes
Owner, Hughes Tooling
karina.harper
Autodesk Support
Autodesk Support
Hi @HughesTooling
Thanks for bringing this up. Would you mind sharing the file so we can explore it/attach it to the request?
HughesTooling
Any simple sheet metal part will do, see attached.
Mark
Mark Hughes
karina.harper
Autodesk Support
Autodesk Support
That works. I've logged it with the dev team.
(internal FUS-46899)
