Export Failed .STL .DWG & .OBJ
Urgent! - Client needs model ASAP.
I created an intricate high-poly model of a wicker chair and when I try to export it fails. Message reads "Max attempts with no progress". (See screenshots below) I was able to get it to export as .F3D is there any way I can convert it to .DWG .STL or .OBJ
HughesTooling
Did you try Save As STL from within Fusion?
Mark Hughes
Owner, Hughes Tooling
HughesTooling
Seems like if you only have a mesh you can only export one body at a time. Right click the mesh body and there's an option for STL or OBJ
Mark Hughes
