export f3d file
export f3d file
sapto_romadi
export f3d file
sapto_romadi
after making 3d model ball valve and the component create full in fusion 360, but when i will export not available f3d extension file, but f3z fil extension...how to show f3d ?
jhackney1972
If your model contains an External reference file or contains a Configuration is will be a F3Z file when exported.  You can Break Link most of the time for an external file but if you have a configuration in the model it will have to remain an F3Z file unless you want to export only one configuration member.
John Hackney, Retired
sapto_romadi
Thank you so much your answer get me out from my trouble.
