Export Drawing in Fusion 360 not available
I'm trying to Export a Drawing from Fusion 360 for a Class Assignment.
I have created the Drawing from model and added some different views.
When I come to the step to export, the 'Export' command in the drop down is greyed out/un-available.
Is it because I have a student access?
I see the other options for PDF / DWG / and CVS and those seem to work.
But my instructor was specific in requesting the final drawing through Export.
So do I have a setup issue or what????  Seems pretty straight forth.  Even in the lab, I can't do the export, leading me to think it's my student account setup.
Any suggestions?
masa.minohara
Hi @Anonymous,
Thank you for posting! Fusion (program) can export a drawing as PDF/DWG/CSV only and this is not because you have student entitlement. You can download a drawing in Fusion file format from the web instead.
Hopefully this helps! Please let me know if you have any questions.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
cmiller66
Hi Elizabeth,
Just to add to what Masa said, the Fusion drawing (f2d) can't be exported as a single file.  You can output it as a DWG from within the drawing environment (this breaks its link to the Fusion model) or, if you Open Details on Web you'll see a download button in the upper right corner.  Choose Fusion 360 Archive and this will export a f3z, which contains both the model (f3d) and the drawing.  This file can then be uploaded by the instructor and this will upload both design/drawing.
Chris
