Export does not work "application/octet-stream"
Hi there,
in the past I could always export files into .skp-files via the A360 platform. However, there is one file I would like to export and it does not work.
The problem is that I don't get a sketchup file but a file from the type "application/octet-stream".
Strangely, I can export any other project of mine into skp, just not this one...
Is there some way to fix this?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
Hmm, not too sure what might be going on, but I can take a peek! Do you mind sharing the file with me at [email protected].
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Hi James,
thanks for your reply!
I did a bit of googling and found a solution: You just have to add the file-extension manually with this kind of file type. I don't know why it only happens with this part but I can work with that workaround for now. 🙂
