Export as STL gone ?
Message 1 of 14
For some odd reason I can't export as .STL
I did it a week ago.
I've got no clue.
Replies (13)
Message 2 of 14
g-andresen
It has changed to "Save as Mesh" and includes the option for STL and 3MF.
Günther
Message 3 of 14
I found an app on the app store called Fyenite that exports to STL. I've been using it to export multiple files at the same time.  It has saved me a lot of time. Just thought I'd mention it.
Good Luck!
Message 4 of 14
I do not see this option on the shortcut tree menu, or in the main file menu.
Message 5 of 14
I see it in File > Export >stl as an option. I did not see this when I checked earlier. My apologies.
Message 6 of 14
g-andresen
Browser > Body > rightclick:
Message 7 of 14
g-andresen
günther
Message 8 of 14
STL option is not showing for me in this menu.
Message 9 of 14
g-andresen
Scroll?
günther
Message 10 of 14
i can see the save as mash option, but which one should i use binary or ASCii? what's the difference?
Message 11 of 14
g-andresen
if it should be STL I would choose the option "Binary"
günther
Message 12 of 14
And what about that stl not showing up in the export menu?
Message 13 of 14
g-andresen
If you want to export a single component as STL you have to save it using "Save as".
Open this "file" and go to File > Export and select STL as format.
günther
Message 14 of 14
andywilx1
When I use the 'Save Mesh' or '3D print' and select Cura in the 3D Print Utility, I'm now unable to send as an STL. Only an 3MF. This has only just happened today. This morning the Format was SLT Binary but this afternoon the option has been greyed out and the default is 3MF.
Is this a Cushion thing or a Cura thing?
If I select a different slicer I can change the Format.
