Export a file from fusion to SOLIDEDGE
ptrfpp
ptrfpp
Kind autodesk team,
I have problem to export a file which can be edited in SOLIDEDGE for a client. I did a STEP file but my client is not able to read the different bodies I made with it ! can someone help me out?
g-andresen
without seeing the file, it´s not possible.
günther
ptrfpp
there you go
TrippyLighting
Can you elaborate on what "cannot read bodies" means ?
A STEP file only contain "dumb" bodies. No sketches, construction geometry, joints etc.
That geometry can be edited fine in SolidEdge.
IMHO your bodies should by all means be organized into components.
TheCADWhisperer
@ptrfpp wrote:
there you go
This is not a *.STEP or *.stp file?
Several of your sketches are underconstrained?
My guess is the SOLIDEDGE user does not know how to use SOLIDEDGE.
Direct editing of imported STEP training is needed.
HughesTooling
Does it work any better if you convert the bodies to components? Not sure how Solidedge would deal with all the bodies in one component like you have it. For an assembly like this I'd use Rule#1 and create individual self-contained components from the start.
Mark Hughes
Owner, Hughes Tooling
