Exiting sketch view doesn't revert to original perspective
Recently I've noticed that if I enter the sketch view and exit it by any means other than selecting the green 'Finish Sketch' check, the camera will remain in orthographic view. Before, ending the sketching environment by switching toolsets (ex: using the hotkey for extrude) would revert to the original perspective, whereas now it will continue to display the sketching environment's orthographic view even after it after it is no longer active.
My main issue is I generally swap from the sketching to modeling environment by activating a tool through a hotkey, and rather than seamlessly transition back into the prior perspective I'm swapping it back manually after each sketch.
jhackney1972
That is the way it works now.  I can only suggest that you assign a hotkey to the Finish Sketch command.  It adds a step but it probably is faster than using the mouse on the icon.
John Hackney, Retired
jeff_strater
This is actually a bug, and is being fixed.  Hope to have a fix out soon.
Jeff Strater
Engineering Director
