Excuse me, this message appeared during software installation. How should I resolve it?
ciliu
Message 1 of 9
ciliu
Accepted solutions (3)
Replies (8)
Message 2 of 9
jhackney1972
Please translate the message in the screen capture.  Better yet, attach the autodesk.webdeploy.streamer.log that will define it a lot better.
John Hackney, Retired
Message 3 of 9
ciliu
  1. When the button is pressed, the following situation occurs. How should I handle it?
Message 4 of 9
jhackney1972
Save and attach the autodesk.webdeply.streamer.log you are showing to a reply post.
Message 5 of 9
ciliu
Message 6 of 9
jhackney1972
You could have attached your Log file directly to a reply post using the Attachment section.  No matter, to probably solve this issue follow the directions, to the letter, outlined in Message #6 of this Forum post.
Message 7 of 9
ciliu
2024-10-20 20:01:04,560 - MainProcess(16760) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\chouj\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-10-20 20:01:04,560 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000023A0F3FB6A0> #
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\chouj\AppData\Local\Temp\7zSECFC.tmp\resources\buildinfo.json
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-10-20 20:01:04,561 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-10-20 20:01:04,562 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: zh_TW
2024-10-20 20:01:04,563 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\chouj\AppData\Local\Temp\7zSECFC.tmp\resources
2024-10-20 20:01:04,564 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\chouj\AppData\Local\Temp\7zSECFC.tmp\certs.pem
2024-10-20 20:01:04,564 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000023A0F3F4AF0>, operation=<function multiple_operate at 0x0000023A0EB373A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-10-20 20:01:04,565 - MainProcess(16760) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-10-20 20:01:05,299 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-10-20 20:01:05,385 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-10-20 20:01:06,384 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-10-20 20:01:06,384 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm created successfully
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\chouj\AppData\Local\Autodesk\check_perm removed successfully
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\chouj\AppData\Local\Autodesk
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-10-20 20:01:06,386 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-10-20 20:01:06,568 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:01:06,568 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:01:06,568 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:01:06,568 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:01:06,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:06,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:06,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:06,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-10-20 20:01:06,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-10-20 20:01:06,605 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.41.132.52
2024-10-20 20:01:06,616 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-20 20:01:06,619 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-20 20:01:06,619 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-10-20 20:01:06,619 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-20 20:01:06,619 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-10-20 20:01:06,702 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-10-20 20:01:06,702 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-10-20 20:01:06,702 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-10-20 20:01:06,805 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:01:06,805 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:01:06,821 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:06,821 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:06,821 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:06,980 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000023A04F26DF0>
2024-10-20 20:01:06,981 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-10-20 20:01:06,981 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-10-20 20:01:07,100 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:01:07,101 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:01:07,101 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:01:07,101 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:01:07,119 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,119 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,119 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,180 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-10-20 20:01:07,181 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-10-20 20:01:07,181 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-10-20 20:01:07,181 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:01:07,181 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:01:07,195 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,195 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,195 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,264 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 2ca85433-26ce-40f0-949d-a7dbd6bcf1b4
2024-10-20 20:01:07,266 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.20476 for app 73e72ada57b7480280f7a6f4a289729f
2024-10-20 20:01:07,266 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-20 20:01:07,266 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-10-20 20:01:07,266 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-10-20 20:01:07,308 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-10-20 20:01:07,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 55f2b8bf08a0f7d6af1c49a01c164f640a9f9e73
2024-10-20 20:01:07,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/55f2b8bf08a0f7d6af1c49a01c164f640a9f9e73.js...
2024-10-20 20:01:07,326 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,326 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,326 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,460 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f95b3107f5a738adc0fbc00d9d1e8f2b8dca310a.ta... for package 55f2b8bf08a0f7d6af1c49a01c164f640a9f9e73
2024-10-20 20:01:07,460 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 78e9360cbacc32e04333f6326384a2c429fd8c80
2024-10-20 20:01:07,467 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/78e9360cbacc32e04333f6326384a2c429fd8c80.js...
2024-10-20 20:01:07,476 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,476 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,476 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,492 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,492 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,492 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,550 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d64ada9b1a2148c198d303d6151995fb0bbfda9a.ta... for package 78e9360cbacc32e04333f6326384a2c429fd8c80
2024-10-20 20:01:07,551 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e6bd424313e9c171c4db4ed16b841f9c42a5a02f
2024-10-20 20:01:07,564 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e6bd424313e9c171c4db4ed16b841f9c42a5a02f.js...
2024-10-20 20:01:07,567 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,567 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:07,580 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,581 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,581 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2024-10-20 20:01:07,581 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,581 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,581 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,730 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/01add322417c24440fd53ac2e5e0e4780de703c8.ta... for package e6bd424313e9c171c4db4ed16b841f9c42a5a02f
2024-10-20 20:01:07,730 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f8149026b1b07976ef987e1d8b955ab2530f2d75
2024-10-20 20:01:07,730 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f8149026b1b07976ef987e1d8b955ab2530f2d75.js...
2024-10-20 20:01:07,762 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,763 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:07,764 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:07,764 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,765 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:07,765 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,765 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:07,984 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:07,987 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e713299f7844b79c9f917429da61141e1628ff20.ta... for package f8149026b1b07976ef987e1d8b955ab2530f2d75
2024-10-20 20:01:07,987 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1a62f9c197147d0131ca99bee892d70a879fa5ba
2024-10-20 20:01:08,001 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,002 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1a62f9c197147d0131ca99bee892d70a879fa5ba.js...
2024-10-20 20:01:08,002 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,002 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:08,018 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,018 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,018 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:08,290 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7ed04bc738e49d61102345c8b4591b5c32e9af15
2024-10-20 20:01:08,290 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7ed04bc738e49d61102345c8b4591b5c32e9af15.js...
2024-10-20 20:01:08,308 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,309 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:08,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:08,590 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b1533df58243f69e3238dbf42ecfd8ada148a9e4
2024-10-20 20:01:08,590 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b1533df58243f69e3238dbf42ecfd8ada148a9e4.js...
2024-10-20 20:01:08,604 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,605 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,605 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:08,722 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:08,722 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/24b7f5eeadebea0d4eac35648f374d88ea443c0f.ta... for package 1a62f9c197147d0131ca99bee892d70a879fa5ba
2024-10-20 20:01:08,743 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,743 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,743 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:08,980 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dffc38a22a9e8e1e1a12df4381ed9b76e5bada02
2024-10-20 20:01:08,980 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dffc38a22a9e8e1e1a12df4381ed9b76e5bada02.js...
2024-10-20 20:01:08,994 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:08,994 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:08,994 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,066 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:09,068 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/12a684641c5eba6bdbf3a0191a357921ece11c81.ta... for package 7ed04bc738e49d61102345c8b4591b5c32e9af15
2024-10-20 20:01:09,089 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:09,101 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,101 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,101 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,140 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: abcf88ef5c9ba957039dae22f51cf143d00ed7e5
2024-10-20 20:01:09,140 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/abcf88ef5c9ba957039dae22f51cf143d00ed7e5.js...
2024-10-20 20:01:09,170 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,170 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,170 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,211 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:09,212 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/329a467c53e5b8d462fc5f2f955cda7723db26ec.ta... for package b1533df58243f69e3238dbf42ecfd8ada148a9e4
2024-10-20 20:01:09,242 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,242 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,243 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,269 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:09,349 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 11967d16da3722ff18db6f0c3a342ddf19a7b93a
2024-10-20 20:01:09,349 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/11967d16da3722ff18db6f0c3a342ddf19a7b93a.js...
2024-10-20 20:01:09,363 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,363 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,364 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,638 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 02fe8d82f7400dca8553139c933f1cf5aa3f6504
2024-10-20 20:01:09,638 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/02fe8d82f7400dca8553139c933f1cf5aa3f6504.js...
2024-10-20 20:01:09,652 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,652 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,652 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:09,958 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cb78ecf131c5c20103656f599fec00656959c948
2024-10-20 20:01:09,958 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cb78ecf131c5c20103656f599fec00656959c948.js...
2024-10-20 20:01:09,977 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:09,977 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:09,978 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:10,105 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:10,108 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:10,109 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ecc45d9921f9f230a371a82636b746abe161c1e0.ta... for package dffc38a22a9e8e1e1a12df4381ed9b76e5bada02
2024-10-20 20:01:10,125 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:10,125 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:10,125 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:10,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 33952bcc30b770c8ba33843fb86d95ae075ff4b4
2024-10-20 20:01:10,309 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/33952bcc30b770c8ba33843fb86d95ae075ff4b4.js...
2024-10-20 20:01:10,323 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:10,323 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:10,323 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:10,428 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:10,598 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 52d7dc58b249fe36785825668fe7b27e29161981
2024-10-20 20:01:10,598 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/52d7dc58b249fe36785825668fe7b27e29161981.js...
2024-10-20 20:01:10,617 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:10,617 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:10,617 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:10,888 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: aac69cae5171b91ca435ffdaf5577298fa69c38a
2024-10-20 20:01:10,888 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/aac69cae5171b91ca435ffdaf5577298fa69c38a.js...
2024-10-20 20:01:10,914 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:10,914 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:10,914 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:11,272 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: df616acdf4b85e7b4a888d7f2d8c38e5aa16fb90
2024-10-20 20:01:11,272 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/df616acdf4b85e7b4a888d7f2d8c38e5aa16fb90.js...
2024-10-20 20:01:11,292 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:11,293 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:11,293 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:11,461 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:11,462 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f5cb87334e84b897e8e326d4dad0274ff78eabdb.ta... for package abcf88ef5c9ba957039dae22f51cf143d00ed7e5
2024-10-20 20:01:11,488 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:11,488 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:11,488 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:11,501 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8b95d97b3b79ef8196eb004e314d42e460447028
2024-10-20 20:01:11,502 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8b95d97b3b79ef8196eb004e314d42e460447028.js...
2024-10-20 20:01:11,531 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:11,531 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:11,531 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:11,674 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:11,720 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 13d789ade8ff537c650da25df992ac9400ea78af
2024-10-20 20:01:11,720 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/13d789ade8ff537c650da25df992ac9400ea78af.js...
2024-10-20 20:01:11,734 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:11,734 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:11,734 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:11,955 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:11,955 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7fb012f47a8358ea995b56ebc2ac455f5f1fdc25.ta... for package 11967d16da3722ff18db6f0c3a342ddf19a7b93a
2024-10-20 20:01:11,969 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:11,970 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:11,970 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:12,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b3cc8e25c693140f19cd9b617542212e9da8a77e
2024-10-20 20:01:12,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b3cc8e25c693140f19cd9b617542212e9da8a77e.js...
2024-10-20 20:01:12,056 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:12,058 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:12,058 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:12,344 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:12,388 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3eb62746ec55d0a41753884e398fdd9f72c13e20
2024-10-20 20:01:12,388 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3eb62746ec55d0a41753884e398fdd9f72c13e20.js...
2024-10-20 20:01:12,401 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:12,401 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:12,402 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:12,711 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 94ee032d6fa2b5db18803aebf0d89fca196959ea
2024-10-20 20:01:12,711 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/94ee032d6fa2b5db18803aebf0d89fca196959ea.js...
2024-10-20 20:01:12,728 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:12,728 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:12,729 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:13,040 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 04276e36aaa01b39e9bde7659430b4cc9c28e732
2024-10-20 20:01:13,040 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/04276e36aaa01b39e9bde7659430b4cc9c28e732.js...
2024-10-20 20:01:13,056 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:13,056 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:13,056 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:13,391 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5e03bb35b6245ee067dbbd53ac1a8ed5f8be70b0
2024-10-20 20:01:13,391 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5e03bb35b6245ee067dbbd53ac1a8ed5f8be70b0.js...
2024-10-20 20:01:13,407 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:13,408 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:13,408 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:13,771 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1e68957a4ffbd7d5c21106806f2c8f8085370174
2024-10-20 20:01:13,771 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1e68957a4ffbd7d5c21106806f2c8f8085370174.js...
2024-10-20 20:01:13,784 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:13,784 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:13,784 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:13,973 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9da2ae0e3d1bf7e7dadc925883f5c5fb0285be4c
2024-10-20 20:01:13,973 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9da2ae0e3d1bf7e7dadc925883f5c5fb0285be4c.js...
2024-10-20 20:01:13,988 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:13,988 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:13,988 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:14,302 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 48ba3b28cba0c265646bece42b7573037b2e35f8
2024-10-20 20:01:14,302 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/48ba3b28cba0c265646bece42b7573037b2e35f8.js...
2024-10-20 20:01:14,316 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:14,316 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:14,316 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:14,325 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:14,325 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0655f9ee04484a08b78af43c1d3192b8a07afb0a.ta... for package 02fe8d82f7400dca8553139c933f1cf5aa3f6504
2024-10-20 20:01:14,340 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:14,340 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:14,341 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:14,599 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 844e2e226580488f3f0acd3b0ab1ce2a9d733719
2024-10-20 20:01:14,599 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/844e2e226580488f3f0acd3b0ab1ce2a9d733719.js...
2024-10-20 20:01:14,624 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:14,625 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:14,625 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:14,703 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:15,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 45cb35736d8c4d4429f18fcd068734175a171c2a
2024-10-20 20:01:15,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/45cb35736d8c4d4429f18fcd068734175a171c2a.js...
2024-10-20 20:01:15,062 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:15,062 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:15,062 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:15,434 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f253daa6887ef6048507801bd1254e4e7609aced
2024-10-20 20:01:15,434 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f253daa6887ef6048507801bd1254e4e7609aced.js...
2024-10-20 20:01:15,452 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:15,452 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:15,453 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:16,282 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 77b84d3798d95191f37e2cd24549f66359b9612d
2024-10-20 20:01:16,282 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/77b84d3798d95191f37e2cd24549f66359b9612d.js...
2024-10-20 20:01:16,294 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:16,295 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:16,295 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:16,893 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 37462a8900c47f41d6d42f2f42553c5416a1ceb5
2024-10-20 20:01:16,893 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/37462a8900c47f41d6d42f2f42553c5416a1ceb5.js...
2024-10-20 20:01:16,909 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:16,910 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:16,910 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:17,058 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:17,060 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fb3bbaa323ad23f25c307537eca451dec5466772.ta... for package cb78ecf131c5c20103656f599fec00656959c948
2024-10-20 20:01:17,085 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:17,085 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:17,086 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:17,175 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 930865d524af22115c7de84475b26ed02b25207f
2024-10-20 20:01:17,175 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/930865d524af22115c7de84475b26ed02b25207f.js...
2024-10-20 20:01:17,191 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:17,191 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:17,191 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:17,275 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:17,408 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7c29030942ca087d4e5104a453531831114acd2f
2024-10-20 20:01:17,408 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7c29030942ca087d4e5104a453531831114acd2f.js...
2024-10-20 20:01:17,422 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:17,423 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:17,423 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:17,738 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:01:17,739 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/09fe17abbb70322788ecdffd1aca764920150370.js...
2024-10-20 20:01:17,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:17,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:17,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:17,756 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:17,757 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4d8dd4bb334a2799381c4d80f56291b718abdad7.ta... for package 33952bcc30b770c8ba33843fb86d95ae075ff4b4
2024-10-20 20:01:17,771 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:17,771 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:17,771 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,086 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6e0a1a79752ef660772ace2159de0cd62421bc39
2024-10-20 20:01:18,086 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6e0a1a79752ef660772ace2159de0cd62421bc39.js...
2024-10-20 20:01:18,101 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,102 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,102 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,105 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:18,105 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6cee39b18db6406822a1f7fab2248631156b3202.ta... for package 52d7dc58b249fe36785825668fe7b27e29161981
2024-10-20 20:01:18,121 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,122 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,122 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,139 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:18,502 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:18,559 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 65117e2f06396681b0a6605c2490ec1626d02731
2024-10-20 20:01:18,559 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/65117e2f06396681b0a6605c2490ec1626d02731.js...
2024-10-20 20:01:18,576 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,576 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,576 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,663 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:18,665 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/78fd10421895c22481653f1db27b9198582db1c9.ta... for package aac69cae5171b91ca435ffdaf5577298fa69c38a
2024-10-20 20:01:18,686 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,686 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,687 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,715 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 060116032c7cc33127155acb6cf216dc64b5c2c9
2024-10-20 20:01:18,715 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/060116032c7cc33127155acb6cf216dc64b5c2c9.js...
2024-10-20 20:01:18,735 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,736 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,736 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,741 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:18,743 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/58ff181ff19a1ce89e0d797721dd31dd58bc7734.ta... for package df616acdf4b85e7b4a888d7f2d8c38e5aa16fb90
2024-10-20 20:01:18,759 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,760 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,760 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,842 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:18,875 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b53448026fe456b908c283313fd033543e28fe0b
2024-10-20 20:01:18,875 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b53448026fe456b908c283313fd033543e28fe0b.js...
2024-10-20 20:01:18,891 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,892 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,892 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:18,940 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:18,954 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:18,954 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/58c3b13d13dbe14ae5b19cf9a1b38b32548098d8.ta... for package 8b95d97b3b79ef8196eb004e314d42e460447028
2024-10-20 20:01:18,976 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:18,976 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:18,976 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:19,079 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b81fd6e312d7bdbf63c6afca6bff99d5953ff2a0
2024-10-20 20:01:19,079 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b81fd6e312d7bdbf63c6afca6bff99d5953ff2a0.js...
2024-10-20 20:01:19,094 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:19,094 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:19,094 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:19,250 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:19,250 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/15343ebc7a2a021c822d5716d11021ab07223dc9.ta... for package 13d789ade8ff537c650da25df992ac9400ea78af
2024-10-20 20:01:19,267 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:19,269 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:19,269 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:19,270 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:19,337 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 697f99aeb9fba7ef2c852b7bc11d1118fcb0bb86
2024-10-20 20:01:19,337 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/697f99aeb9fba7ef2c852b7bc11d1118fcb0bb86.js...
2024-10-20 20:01:19,354 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:19,354 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:19,354 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:19,477 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:19,670 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 0c18ba8e501b70c21548315378ac870ecaa8d8f9
2024-10-20 20:01:19,670 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/0c18ba8e501b70c21548315378ac870ecaa8d8f9.js...
2024-10-20 20:01:19,685 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:19,685 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:19,685 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:20,238 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:20,238 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fbb38b7dcd1cf5d7078377f320f88a953cff7d9b.ta... for package b3cc8e25c693140f19cd9b617542212e9da8a77e
2024-10-20 20:01:20,255 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:20,255 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:20,255 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:20,287 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a3015b91e9697acde203e34be2d3e60fb97c7867
2024-10-20 20:01:20,287 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a3015b91e9697acde203e34be2d3e60fb97c7867.js...
2024-10-20 20:01:20,303 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:20,303 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:20,303 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:20,402 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:20,403 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e9e65438914edcc59dde10528747758eec00d81c.ta... for package 3eb62746ec55d0a41753884e398fdd9f72c13e20
2024-10-20 20:01:20,421 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:20,422 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:20,422 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:20,440 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:20,512 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:01:20,512 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6baf56cad33f41bab95f8568ea7f69c9fe1473e9.js...
2024-10-20 20:01:20,527 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:20,527 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:20,527 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:20,736 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:20,815 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cd398d360d746179da04a19fe608256034f75a64
2024-10-20 20:01:20,815 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.js...
2024-10-20 20:01:20,831 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:20,831 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:20,831 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,081 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 06e57954283854894a88ad4a8436d3d00d3f70c0
2024-10-20 20:01:21,081 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/06e57954283854894a88ad4a8436d3d00d3f70c0.js...
2024-10-20 20:01:21,094 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,095 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,095 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,413 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: da33ebca1418486522dd9f059017b7ff1594230a
2024-10-20 20:01:21,413 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/da33ebca1418486522dd9f059017b7ff1594230a.js...
2024-10-20 20:01:21,427 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,427 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,427 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,670 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:21,671 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e5d7bda76526863133c3cb8a5640a40b5ad4abcd.ta... for package 94ee032d6fa2b5db18803aebf0d89fca196959ea
2024-10-20 20:01:21,688 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,688 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,689 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,708 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5e435c890e98d165e1280f21228826b76dc86a87
2024-10-20 20:01:21,708 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5e435c890e98d165e1280f21228826b76dc86a87.js...
2024-10-20 20:01:21,722 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,722 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,722 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,845 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:21,858 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:01:21,858 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/85686d5942cf19e82b61aceceaea893265cc2956.js...
2024-10-20 20:01:21,872 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,873 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,873 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:21,911 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:21,922 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2b7fe552578f8964d63ff2f504d5dbcfb52221e3.ta... for package 04276e36aaa01b39e9bde7659430b4cc9c28e732
2024-10-20 20:01:21,953 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:21,954 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:21,955 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:22,022 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8a556380a00b43fa0e4a76db5eeae2da80672aae
2024-10-20 20:01:22,022 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8a556380a00b43fa0e4a76db5eeae2da80672aae.js...
2024-10-20 20:01:22,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:22,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:22,042 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:22,136 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:22,284 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 250545db385fa3bf65e6bbfb5804e8a388939582
2024-10-20 20:01:22,284 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/250545db385fa3bf65e6bbfb5804e8a388939582.js...
2024-10-20 20:01:22,298 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:22,298 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:22,298 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:22,529 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:01:22,529 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc.js...
2024-10-20 20:01:22,546 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:22,546 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:22,546 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:23,030 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c76372825b4134c42f40b49fdc37489cf1ca6cea
2024-10-20 20:01:23,030 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c76372825b4134c42f40b49fdc37489cf1ca6cea.js...
2024-10-20 20:01:23,045 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:23,045 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:23,045 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:23,433 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 814176b0b3ac80f358f60b920b5daa9561fb19e6
2024-10-20 20:01:23,433 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/814176b0b3ac80f358f60b920b5daa9561fb19e6.js...
2024-10-20 20:01:23,448 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:23,448 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:23,448 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:23,744 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 64e80901ff0412fd1770b47d1d5af4910f3efada
2024-10-20 20:01:23,744 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/64e80901ff0412fd1770b47d1d5af4910f3efada.js...
2024-10-20 20:01:23,762 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:23,762 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:23,762 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:24,373 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f474df637f0164ab8fd956c16b7895fc3f70aed9
2024-10-20 20:01:24,373 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f474df637f0164ab8fd956c16b7895fc3f70aed9.js...
2024-10-20 20:01:24,387 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:24,387 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:24,387 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:24,961 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 7f824eab819b7a46d47bb3f655d39707e4e185d3
2024-10-20 20:01:24,961 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/7f824eab819b7a46d47bb3f655d39707e4e185d3.js...
2024-10-20 20:01:24,974 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:24,974 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:24,974 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:25,469 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 147698f2e933654bd2977211a0fad33d60830942
2024-10-20 20:01:25,469 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/147698f2e933654bd2977211a0fad33d60830942.js...
2024-10-20 20:01:25,485 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:25,485 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:25,485 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:26,082 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 060f1c8c7f51c3f328d82be8c6eaa14739e35541
2024-10-20 20:01:26,082 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/060f1c8c7f51c3f328d82be8c6eaa14739e35541.js...
2024-10-20 20:01:26,097 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:26,097 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:26,097 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:26,343 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cf919f1a3e2f56a7f4f9b87557160da758794ca7
2024-10-20 20:01:26,343 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cf919f1a3e2f56a7f4f9b87557160da758794ca7.js...
2024-10-20 20:01:26,360 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:26,362 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:26,362 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:26,949 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 795c4ffb2c7a6f1f029c1043b235153eac6a9d88
2024-10-20 20:01:26,949 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/795c4ffb2c7a6f1f029c1043b235153eac6a9d88.js...
2024-10-20 20:01:26,966 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:26,967 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:26,967 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:27,562 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9c0445c9266a5337d5602ee8ba6dd76615ed1abe
2024-10-20 20:01:27,562 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9c0445c9266a5337d5602ee8ba6dd76615ed1abe.js...
2024-10-20 20:01:27,573 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:27,573 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:27,573 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:27,878 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:01:27,879 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/12d02acb4d2f84534c8f6f8563214b7032da3b95.js...
2024-10-20 20:01:27,891 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:27,891 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:27,891 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:28,428 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-10-20 20:01:28,428 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 55f2b8bf08a0f7d6af1c49a01c164f640a9f9e73
2024-10-20 20:01:28,436 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 78e9360cbacc32e04333f6326384a2c429fd8c80
2024-10-20 20:01:28,460 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e6bd424313e9c171c4db4ed16b841f9c42a5a02f
2024-10-20 20:01:28,463 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f8149026b1b07976ef987e1d8b955ab2530f2d75
2024-10-20 20:01:28,463 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1a62f9c197147d0131ca99bee892d70a879fa5ba
2024-10-20 20:01:28,469 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7ed04bc738e49d61102345c8b4591b5c32e9af15
2024-10-20 20:01:28,472 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b1533df58243f69e3238dbf42ecfd8ada148a9e4
2024-10-20 20:01:28,473 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dffc38a22a9e8e1e1a12df4381ed9b76e5bada02
2024-10-20 20:01:28,480 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for abcf88ef5c9ba957039dae22f51cf143d00ed7e5
2024-10-20 20:01:28,481 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 11967d16da3722ff18db6f0c3a342ddf19a7b93a
2024-10-20 20:01:28,483 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 02fe8d82f7400dca8553139c933f1cf5aa3f6504
2024-10-20 20:01:28,484 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cb78ecf131c5c20103656f599fec00656959c948
2024-10-20 20:01:28,486 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 33952bcc30b770c8ba33843fb86d95ae075ff4b4
2024-10-20 20:01:28,488 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 52d7dc58b249fe36785825668fe7b27e29161981
2024-10-20 20:01:28,490 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for aac69cae5171b91ca435ffdaf5577298fa69c38a
2024-10-20 20:01:28,491 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for df616acdf4b85e7b4a888d7f2d8c38e5aa16fb90
2024-10-20 20:01:28,494 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8b95d97b3b79ef8196eb004e314d42e460447028
2024-10-20 20:01:28,495 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 13d789ade8ff537c650da25df992ac9400ea78af
2024-10-20 20:01:40,703 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:40,705 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f15cb52ab4ef6739911bf10a50bf6531dd45fa42.ta... for package 5e03bb35b6245ee067dbbd53ac1a8ed5f8be70b0
2024-10-20 20:01:40,719 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:40,719 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:40,719 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:40,985 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:40,993 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:40,993 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/064fc2efb1e8b8241eee6ace0444b791db62575f.ta... for package 1e68957a4ffbd7d5c21106806f2c8f8085370174
2024-10-20 20:01:41,005 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:41,005 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:41,005 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:41,174 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:42,044 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:42,045 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ba32f80b9ec0e13ae2c3f8516aa10e90e34d6c3f.ta... for package 9da2ae0e3d1bf7e7dadc925883f5c5fb0285be4c
2024-10-20 20:01:42,070 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:42,070 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:42,070 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:42,238 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:42,532 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:42,532 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1b59318de1740caf12fc13fe47ba42cb474a6281.ta... for package 48ba3b28cba0c265646bece42b7573037b2e35f8
2024-10-20 20:01:42,547 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:42,547 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:42,550 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:42,798 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:45,562 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:45,563 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/343b076503a3d8e61863c847a80e6c83839ff18b.ta... for package 844e2e226580488f3f0acd3b0ab1ce2a9d733719
2024-10-20 20:01:45,580 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:45,580 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:45,580 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:45,686 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:45,942 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:45,942 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/201ad1df204e3eca878a1bcfbd3ccedb8268bbd4.ta... for package 45cb35736d8c4d4429f18fcd068734175a171c2a
2024-10-20 20:01:45,965 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:45,965 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:45,965 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:46,089 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:48,293 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:48,293 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/dc01e8b054995a08c31fea395b605380c5fa5278.ta... for package f253daa6887ef6048507801bd1254e4e7609aced
2024-10-20 20:01:48,316 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:48,316 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:48,316 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:48,792 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:52,593 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:52,594 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a598fbeded10827a90b4702f831bc4c73933c8c3.ta... for package 77b84d3798d95191f37e2cd24549f66359b9612d
2024-10-20 20:01:52,624 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:52,625 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:52,625 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:52,827 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:55,110 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:55,111 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/06c46195533ef8240159c6033a8a9823cd828d63.ta... for package 37462a8900c47f41d6d42f2f42553c5416a1ceb5
2024-10-20 20:01:55,133 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:55,134 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:55,134 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:55,355 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:55,579 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:55,580 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4e81617e9e19a6371bbe36cba3448ccc23e94e85.ta... for package 930865d524af22115c7de84475b26ed02b25207f
2024-10-20 20:01:55,595 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:55,596 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:55,596 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:55,899 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:56,018 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:56,018 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8583c2b864ddec7f9faa8221d161d21487fb367b.ta... for package 7c29030942ca087d4e5104a453531831114acd2f
2024-10-20 20:01:56,032 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:56,032 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:56,033 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:56,287 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:01:57,395 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:01:57,395 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1b88bc4e4312f7a5ed05299949fd117c0895df6f.ta... for package 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:01:57,419 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:01:57,422 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:01:57,422 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:01:57,830 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:02:03,414 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:03,416 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c710766b3ae28b6618f14ea168bc7728a4339967.ta... for package 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:02:03,432 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:03,432 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:03,432 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:03,435 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b3cc8e25c693140f19cd9b617542212e9da8a77e
2024-10-20 20:02:03,456 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3eb62746ec55d0a41753884e398fdd9f72c13e20
2024-10-20 20:02:03,546 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:02:04,567 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:04,568 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6e0a1a79752ef660772ace2159de0cd62421bc39.ta... for package 6e0a1a79752ef660772ace2159de0cd62421bc39
2024-10-20 20:02:04,585 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:04,585 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:04,586 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:04,793 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\Common
2024-10-20 20:02:04,793 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2024-10-20 20:02:09,633 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:09,636 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d397e120c33c74bedcc3d80d76ced799bea0a3b3.ta... for package 65117e2f06396681b0a6605c2490ec1626d02731
2024-10-20 20:02:09,650 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:09,650 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:09,650 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:09,653 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 94ee032d6fa2b5db18803aebf0d89fca196959ea
2024-10-20 20:02:09,686 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 04276e36aaa01b39e9bde7659430b4cc9c28e732
2024-10-20 20:02:09,825 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5e03bb35b6245ee067dbbd53ac1a8ed5f8be70b0
2024-10-20 20:02:09,828 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1e68957a4ffbd7d5c21106806f2c8f8085370174
2024-10-20 20:02:09,830 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9da2ae0e3d1bf7e7dadc925883f5c5fb0285be4c
2024-10-20 20:02:09,831 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 48ba3b28cba0c265646bece42b7573037b2e35f8
2024-10-20 20:02:09,885 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 844e2e226580488f3f0acd3b0ab1ce2a9d733719
2024-10-20 20:02:09,889 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 45cb35736d8c4d4429f18fcd068734175a171c2a
2024-10-20 20:02:10,047 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:02:10,327 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:10,327 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a3cb5cb195b64e2552718f26b1b7045733e2f58d.ta... for package 060116032c7cc33127155acb6cf216dc64b5c2c9
2024-10-20 20:02:10,346 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:10,346 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:10,346 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:10,578 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:02:36,348 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:36,349 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cfd7fb698ce26d0d36fb2e7f274b6ae9b017d44d.ta... for package b53448026fe456b908c283313fd033543e28fe0b
2024-10-20 20:02:36,372 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:36,373 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:36,373 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:36,921 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:02:37,937 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:02:37,937 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f0b5843e801a29faa62077c2c2ef1b88f485cf71.ta... for package b81fd6e312d7bdbf63c6afca6bff99d5953ff2a0
2024-10-20 20:02:37,958 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:02:37,958 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:02:37,958 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:02:38,226 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:09,031 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:09,033 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/533b13987bc30ff4eea49c5ae04400c023f169bf.ta... for package 697f99aeb9fba7ef2c852b7bc11d1118fcb0bb86
2024-10-20 20:03:09,049 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:09,049 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:09,049 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:09,542 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:32,338 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:32,339 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ee5c9db0151db5c0059adcdd2d91f2e8b27c67d2.ta... for package 0c18ba8e501b70c21548315378ac870ecaa8d8f9
2024-10-20 20:03:32,359 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:32,359 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:32,359 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:32,782 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:35,633 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:35,636 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/351c980b7da2283afdc4ef78bf94d2987a861e01.ta... for package a3015b91e9697acde203e34be2d3e60fb97c7867
2024-10-20 20:03:35,660 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:35,661 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:35,661 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:36,016 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:36,086 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:36,090 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/83a3fb67fbc71934caccf69d0f11c63b289f1837.ta... for package 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:03:36,112 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:36,112 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:36,113 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:36,446 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:41,304 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:41,305 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a3d5df699cab0c62e779e03096ce618d143f6f9e.ta... for package 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:03:41,331 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:41,331 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:41,331 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:41,658 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:41,872 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:41,872 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cd398d360d746179da04a19fe608256034f75a64.ta... for package cd398d360d746179da04a19fe608256034f75a64
2024-10-20 20:03:41,898 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:41,899 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:41,899 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:42,151 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:03:42,151 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2024-10-20 20:03:42,830 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:42,830 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7bea6f746be0599432f2997b8d617b1a8b95606e.ta... for package 06e57954283854894a88ad4a8436d3d00d3f70c0
2024-10-20 20:03:42,854 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:42,854 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:42,854 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:43,138 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:43,846 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:43,849 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/82ae8f04f9ce25d40a8c316d94d41f45dc4ed6bd.ta... for package da33ebca1418486522dd9f059017b7ff1594230a
2024-10-20 20:03:43,865 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:43,866 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:43,866 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:44,359 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:48,193 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:48,195 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1b0b218741efb584d2cbbc44b086ef0018a42cbe.ta... for package 5e435c890e98d165e1280f21228826b76dc86a87
2024-10-20 20:03:48,225 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:48,226 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:48,227 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:48,725 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:51,204 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:51,205 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/dd2c9eba8406ba650f5b4fd57d2cd39e43721e6c.ta... for package 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:03:51,206 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package f253daa6887ef6048507801bd1254e4e7609aced
2024-10-20 20:03:51,206 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 7facf0de95414ab9b6315d8fa534bf91(Unknown) was not in registry
2024-10-20 20:03:51,223 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:51,223 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action a92c95fa064f43089136f50437f73d22(Unknown) was not in registry
2024-10-20 20:03:51,224 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:51,225 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package f253daa6887ef6048507801bd1254e4e7609aced
2024-10-20 20:03:51,225 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:51,230 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f253daa6887ef6048507801bd1254e4e7609aced
2024-10-20 20:03:51,247 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 77b84d3798d95191f37e2cd24549f66359b9612d
2024-10-20 20:03:51,258 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 37462a8900c47f41d6d42f2f42553c5416a1ceb5
2024-10-20 20:03:51,263 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 930865d524af22115c7de84475b26ed02b25207f
2024-10-20 20:03:51,268 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7c29030942ca087d4e5104a453531831114acd2f
2024-10-20 20:03:51,273 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:03:51,273 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-20 20:03:51,273 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5c461fa5ff6ec38afa078cf537137159(ADD_REGISTRY_INFO)
2024-10-20 20:03:51,378 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:51,398 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\CLSID\\{C4F0910E-E0B4-4E68-8086-452730C7A26A}', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmp_nezjivm', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:51,474 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.f3d', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmp993b4_k4', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:51,563 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.f3z', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmp3iiyv02b', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:51,655 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.f2d', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmpzsiwbmkc', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:51,756 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.f2t', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmp2jqqx_tt', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:53,627 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:53,628 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6540d1a2ee0d733e07d1469f082b1a97d2defcc3.ta... for package 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:03:53,646 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:53,646 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:53,646 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:53,698 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.flbr', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmpbsz8dl7m', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:53,771 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.fsch', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmp1lscwzjb', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:53,843 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Could not export subkey: Command '['C:\\Windows\\System32\\reg.exe', 'export', 'HKCU\\Software\\Classes\\.fbrd', 'C:\\Users\\chouj\\AppData\\Local\\Temp\\tmpbvr3w26f', '/y']' returned non-zero exit status 1.
2024-10-20 20:03:53,844 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2024-10-20 20:03:53,844 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-20 20:03:53,845 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 36d909d4c5304fc2a6a47bbb9116f50e(REMOVE_STREAMING_SESSION) was not in registry
2024-10-20 20:03:53,845 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:03:53,847 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 09fe17abbb70322788ecdffd1aca764920150370
2024-10-20 20:03:53,993 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:54,605 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 6e0a1a79752ef660772ace2159de0cd62421bc39
2024-10-20 20:03:54,605 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2024-10-20 20:03:54,605 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-20 20:03:54,625 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.platform_base - INFO :: Executing: "\\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\MaterialLibraryMigrator.exe" "migratecache" "C:\Users\chouj\AppData\Local\Autodesk\Common\Material Library"
2024-10-20 20:03:54,796 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action c1d5a6c7dcbf4562b683600beeae3d5f(REMOVE_TEMP_MATERIAL_FOLDER) was not in registry
2024-10-20 20:03:54,798 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 6e0a1a79752ef660772ace2159de0cd62421bc39
2024-10-20 20:03:54,802 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6e0a1a79752ef660772ace2159de0cd62421bc39
2024-10-20 20:03:54,936 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 65117e2f06396681b0a6605c2490ec1626d02731
2024-10-20 20:03:54,961 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 060116032c7cc33127155acb6cf216dc64b5c2c9
2024-10-20 20:03:55,597 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:55,599 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/764b911f05767d81f7052e6270720b6bb0c30921.ta... for package 8a556380a00b43fa0e4a76db5eeae2da80672aae
2024-10-20 20:03:55,622 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:55,622 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:55,622 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:55,940 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:56,242 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b53448026fe456b908c283313fd033543e28fe0b
2024-10-20 20:03:56,252 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b81fd6e312d7bdbf63c6afca6bff99d5953ff2a0
2024-10-20 20:03:56,572 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 697f99aeb9fba7ef2c852b7bc11d1118fcb0bb86
2024-10-20 20:03:59,274 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:59,276 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2650c1b48762e19efb34f1c7d349d1f4d4cfeb72.ta... for package 250545db385fa3bf65e6bbfb5804e8a388939582
2024-10-20 20:03:59,300 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:59,300 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:59,300 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:59,467 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:03:59,469 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/314b1610cf16cf311168c703d9d0f50b90b6b0fd.ta... for package f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:03:59,491 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:03:59,491 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:03:59,491 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:03:59,678 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:03:59,734 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:00,333 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:00,333 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/53f2e24e6295d4f6c583e3b859abd1ef3895de5d.ta... for package f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:04:00,361 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:00,361 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:00,361 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:03,212 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:04,841 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:04,841 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a67da1ac5fefc2cfe12da2001fb9c83c3c2b7a0a.ta... for package c76372825b4134c42f40b49fdc37489cf1ca6cea
2024-10-20 20:04:04,858 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:04,858 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:04,858 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:05,013 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:05,315 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:05,315 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fb31ef73c2211e8d850f2e898c0ddaa712a5e037.ta... for package 814176b0b3ac80f358f60b920b5daa9561fb19e6
2024-10-20 20:04:05,331 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:05,331 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:05,332 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:05,495 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:05,576 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:05,576 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fc82ac189beff1f9dbac2503482168c028ec88fe.ta... for package 64e80901ff0412fd1770b47d1d5af4910f3efada
2024-10-20 20:04:05,613 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:05,615 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:05,616 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:05,944 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:18,086 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:18,088 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8ead5b8e9ea05ced4e8276b3d2b8d6a1c670abe0.ta... for package 64e80901ff0412fd1770b47d1d5af4910f3efada
2024-10-20 20:04:18,114 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:18,114 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:18,115 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:18,602 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:20,509 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:20,510 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/decfa9610472340a56cb673fa584ed488800f21c.ta... for package f474df637f0164ab8fd956c16b7895fc3f70aed9
2024-10-20 20:04:20,529 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:20,531 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:20,531 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:21,041 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:27,223 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:27,226 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/46b4f86e447fee872ffe7d09c7f2279a5292cf7f.ta... for package 7f824eab819b7a46d47bb3f655d39707e4e185d3
2024-10-20 20:04:27,252 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:27,252 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:27,252 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:27,506 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:29,346 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:29,347 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2769f68d813ce5906a9762625ceb127cd02f0163.ta... for package 7f824eab819b7a46d47bb3f655d39707e4e185d3
2024-10-20 20:04:29,369 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:29,369 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:29,369 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:29,801 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:29,963 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:29,964 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1e3e8ce00d1523b9bcbe1b22ebd15bd9c320e63e.ta... for package 147698f2e933654bd2977211a0fad33d60830942
2024-10-20 20:04:29,992 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:29,993 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:29,993 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:30,333 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:30,768 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:30,769 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/34b5e3e9ed11a860afc46e575a714afb6e058454.ta... for package 060f1c8c7f51c3f328d82be8c6eaa14739e35541
2024-10-20 20:04:30,789 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:30,789 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:30,789 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:31,123 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:33,456 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:33,457 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ca3b556c93a6406a46788b77dc18a729d7be4a30.ta... for package cf919f1a3e2f56a7f4f9b87557160da758794ca7
2024-10-20 20:04:33,487 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:33,487 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:33,487 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:33,605 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:35,991 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:35,994 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0c664b67a9c8fbeaa6839620b44395b8b5d9b96b.ta... for package 795c4ffb2c7a6f1f029c1043b235153eac6a9d88
2024-10-20 20:04:36,025 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:36,025 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:36,025 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:36,271 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:38,423 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:38,424 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cda3bfa9653b3c50a5a595fe8e1f218cfeb558e6.ta... for package 795c4ffb2c7a6f1f029c1043b235153eac6a9d88
2024-10-20 20:04:38,453 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:38,453 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:38,453 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:38,723 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:38,994 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:38,994 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f32f6043ebb65baec1458769ca8cd6863e3ce7bf.ta... for package 9c0445c9266a5337d5602ee8ba6dd76615ed1abe
2024-10-20 20:04:39,029 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:39,029 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:39,030 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:39,912 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:39,945 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:39,945 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2146268449abc457e3182706607590877ca49bcb.ta... for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:04:39,973 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:39,974 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:39,978 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:40,246 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:47,719 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:04:47,722 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ce99e2d44d207da229fe7fbd1d4ae44b2af1263d.ta... for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:04:47,738 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:04:47,739 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:04:47,739 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:04:47,919 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:04:49,862 - MainProcess(16760) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:05:14,109 - MainProcess(16760) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:05:43,897 - MainProcess(16760) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:06:50,007 - MainProcess(16760) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:06:50,014 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 0c18ba8e501b70c21548315378ac870ecaa8d8f9
2024-10-20 20:06:52,457 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a3015b91e9697acde203e34be2d3e60fb97c7867
2024-10-20 20:06:52,475 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:06:52,475 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-20 20:06:52,475 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:06:52,475 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6baf56cad33f41bab95f8568ea7f69c9fe1473e9
2024-10-20 20:06:52,497 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cd398d360d746179da04a19fe608256034f75a64
2024-10-20 20:06:52,509 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 06e57954283854894a88ad4a8436d3d00d3f70c0
2024-10-20 20:06:52,523 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for da33ebca1418486522dd9f059017b7ff1594230a
2024-10-20 20:06:52,536 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5e435c890e98d165e1280f21228826b76dc86a87
2024-10-20 20:06:52,550 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:06:52,550 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-20 20:06:52,550 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-10-20 20:06:52,550 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\streamingsession.json
2024-10-20 20:06:52,563 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:06:52,564 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 85686d5942cf19e82b61aceceaea893265cc2956
2024-10-20 20:06:52,594 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8a556380a00b43fa0e4a76db5eeae2da80672aae
2024-10-20 20:06:52,641 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 250545db385fa3bf65e6bbfb5804e8a388939582
2024-10-20 20:06:52,659 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform predeploy tasks for package f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:06:52,660 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a9cdc10b1ed64039b7dfd3bf8a0dcd5e(REMOVE_WININSTALLER_PRODUCT)
2024-10-20 20:06:52,712 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {CD2A85EC-C80D-4CAC-01C1-FCCDE4A651C8}. Msiexec returns 1605
2024-10-20 20:06:52,755 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {0188C9F4-CCDE-41E9-0150-6B1CFC6AC596}. Msiexec returns 1605
2024-10-20 20:06:52,756 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform predeploy tasks for package f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:06:52,756 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc
2024-10-20 20:06:52,843 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c76372825b4134c42f40b49fdc37489cf1ca6cea
2024-10-20 20:06:52,862 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 814176b0b3ac80f358f60b920b5daa9561fb19e6
2024-10-20 20:06:52,879 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 64e80901ff0412fd1770b47d1d5af4910f3efada
2024-10-20 20:06:53,019 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f474df637f0164ab8fd956c16b7895fc3f70aed9
2024-10-20 20:06:53,035 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 7f824eab819b7a46d47bb3f655d39707e4e185d3
2024-10-20 20:06:53,069 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 147698f2e933654bd2977211a0fad33d60830942
2024-10-20 20:06:53,088 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 060f1c8c7f51c3f328d82be8c6eaa14739e35541
2024-10-20 20:06:53,104 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cf919f1a3e2f56a7f4f9b87557160da758794ca7
2024-10-20 20:06:53,119 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 795c4ffb2c7a6f1f029c1043b235153eac6a9d88
2024-10-20 20:06:53,139 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9c0445c9266a5337d5602ee8ba6dd76615ed1abe
2024-10-20 20:06:53,154 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:06:53,154 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-10-20 20:06:53,155 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-10-20 20:06:53,155 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-10-20 20:06:53,156 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\streamingsession.json
2024-10-20 20:06:53,162 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-10-20 20:06:53,172 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\ApplicationOptions.production.json as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Fusion 360.server.config
2024-10-20 20:06:53,172 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:06:53,182 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\AdpSDKGlobal.config
2024-10-20 20:06:53,182 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:06:53,192 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpdesktopsdk.env
2024-10-20 20:06:53,192 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:06:53,193 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-10-20 20:06:53,194 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-10-20 20:06:53,209 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-10-20 20:06:53,210 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-10-20 20:06:53,238 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:06:53,238 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:06:53,238 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:06:53,517 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is eb31573c8bf111a2be2f78454a20aeb9:1728534118.767573
2024-10-20 20:06:53,517 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-10-20 20:06:53,517 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'eb31573c8bf111a2be2f78454a20aeb9:1728534118.767573' to option 'ETag'
2024-10-20 20:06:53,517 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-10-20 20:06:53,524 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-10-20 20:06:53,546 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:06:53,546 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-10-20 20:06:53,546 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-10-20 20:06:53,552 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:06:53,554 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:06:53,555 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:06:53,556 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:06:53,557 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-10-20 20:06:53,557 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-10-20 20:07:00,445 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-10-20 20:07:00,445 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-10-20 20:07:00,445 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-10-20 20:07:00,448 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-10-20 20:07:00,448 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:07:00,448 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:07:00,448 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:07:00,476 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:07:00,476 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:07:00,481 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-20 20:07:00,491 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:07:00,491 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-10-20 20:07:00,502 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:07:00,502 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-10-20 20:07:00,513 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:07:00,515 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:07:00,515 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:07:00,515 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:07:00,515 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:07:00,563 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:07:00,563 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:07:00,563 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:07:00,564 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:07:00,564 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:07:00,572 - MainProcess(16760) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 12d02acb4d2f84534c8f6f8563214b7032da3b95:
2024-10-20 20:07:00,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-20 20:07:00,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-20 20:07:00,753 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-10-20 20:07:01,335 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get local dns 'utf-8' codec can't decode byte 0xa6 in position 0: invalid start byte.
2024-10-20 20:07:01,335 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS:
2024-10-20 20:07:01,335 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-20 20:07:01,336 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1160, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 92, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1091, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 909, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1869, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1630, in wait_threads
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\concurrent\futures\thread.py", line 52, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1750, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 406, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 342, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 441, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 398, in __filevisitor
File "R:\src\adsk\dls\streamer\manifests.py", line 62, in __next__
File "R:\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
File "R:\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
File "R:\src\adsk\dls\streamer\utils.py", line 258, in __call__
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 121, in substitute
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 114, in convert
File "R:\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
File "R:\src\adsk\dls\streamer\configuration.py", line 782, in __getitem__
File "R:\src\adsk\dls\streamer\windows\platform.py", line 1993, in __getitem__
File "R:\src\adsk\dls\streamer\platform_base.py", line 104, in __getitem__
IndexError
2024-10-20 20:08:15,261 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-20 20:08:15,276 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:08:15,276 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpdesktopsdk.env
2024-10-20 20:08:15,277 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpsdkglobal.config
2024-10-20 20:08:15,319 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\fusion 360.server.config
2024-10-20 20:08:15,470 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy
2024-10-20 20:08:17,157 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-10-20 20:08:17,164 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-10-20 20:08:17,164 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-10-20 20:08:17,164 - MainProcess(16760) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\chouj\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000185717AB6A0> #
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-10-20 20:09:02,704 - MainProcess(31116) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\chouj\AppData\Local\Temp\7zS3984.tmp\resources\buildinfo.json
2024-10-20 20:09:02,705 - MainProcess(31116) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-10-20 20:09:02,705 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-10-20 20:09:02,705 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: zh_TW
2024-10-20 20:09:02,705 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\chouj\AppData\Local\Temp\7zS3984.tmp\resources
2024-10-20 20:09:02,706 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\chouj\AppData\Local\Temp\7zS3984.tmp\certs.pem
2024-10-20 20:09:02,706 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000185717A4AF0>, operation=<function multiple_operate at 0x0000018570EE73A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-10-20 20:09:02,707 - MainProcess(31116) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-10-20 20:09:02,898 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-10-20 20:09:02,952 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-10-20 20:09:03,913 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-10-20 20:09:03,913 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-10-20 20:09:03,913 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-10-20 20:09:03,914 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-10-20 20:09:03,914 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-10-20 20:09:03,914 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-10-20 20:09:03,914 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm created successfully
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\chouj\AppData\Local\Autodesk\check_perm removed successfully
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\chouj\AppData\Local\Autodesk
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-10-20 20:09:03,915 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-10-20 20:09:04,108 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:09:04,109 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:09:04,109 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:09:04,109 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:09:04,136 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,136 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,136 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,136 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-10-20 20:09:04,138 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-10-20 20:09:04,138 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.41.132.52
2024-10-20 20:09:04,169 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-20 20:09:04,169 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-20 20:09:04,170 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-10-20 20:09:04,170 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-20 20:09:04,170 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-10-20 20:09:04,243 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-10-20 20:09:04,243 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-10-20 20:09:04,243 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-10-20 20:09:04,329 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:09:04,329 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:09:04,342 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,342 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,343 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,415 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000018504EA5C10>
2024-10-20 20:09:04,416 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-10-20 20:09:04,416 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-10-20 20:09:04,536 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-20 20:09:04,537 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-20 20:09:04,537 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:09:04,537 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:09:04,549 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,549 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,549 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,616 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-10-20 20:09:04,616 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-10-20 20:09:04,616 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-10-20 20:09:04,616 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-20 20:09:04,616 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-20 20:09:04,628 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,628 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,629 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,703 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is bff3bc01-3b81-42fd-aa1f-318aa01df28d
2024-10-20 20:09:04,709 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.20476 for app 73e72ada57b7480280f7a6f4a289729f
2024-10-20 20:09:04,709 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 55f2b8bf08a0f7d6af1c49a01c164f640a9f9e73 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 78e9360cbacc32e04333f6326384a2c429fd8c80 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e6bd424313e9c171c4db4ed16b841f9c42a5a02f detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f8149026b1b07976ef987e1d8b955ab2530f2d75 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1a62f9c197147d0131ca99bee892d70a879fa5ba detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7ed04bc738e49d61102345c8b4591b5c32e9af15 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b1533df58243f69e3238dbf42ecfd8ada148a9e4 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dffc38a22a9e8e1e1a12df4381ed9b76e5bada02 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk abcf88ef5c9ba957039dae22f51cf143d00ed7e5 detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 11967d16da3722ff18db6f0c3a342ddf19a7b93a detected on system skipping install.
2024-10-20 20:09:04,723 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 02fe8d82f7400dca8553139c933f1cf5aa3f6504 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cb78ecf131c5c20103656f599fec00656959c948 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 33952bcc30b770c8ba33843fb86d95ae075ff4b4 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 52d7dc58b249fe36785825668fe7b27e29161981 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk aac69cae5171b91ca435ffdaf5577298fa69c38a detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk df616acdf4b85e7b4a888d7f2d8c38e5aa16fb90 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8b95d97b3b79ef8196eb004e314d42e460447028 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 13d789ade8ff537c650da25df992ac9400ea78af detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b3cc8e25c693140f19cd9b617542212e9da8a77e detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3eb62746ec55d0a41753884e398fdd9f72c13e20 detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 94ee032d6fa2b5db18803aebf0d89fca196959ea detected on system skipping install.
2024-10-20 20:09:04,724 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 04276e36aaa01b39e9bde7659430b4cc9c28e732 detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5e03bb35b6245ee067dbbd53ac1a8ed5f8be70b0 detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 1e68957a4ffbd7d5c21106806f2c8f8085370174 detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9da2ae0e3d1bf7e7dadc925883f5c5fb0285be4c detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 48ba3b28cba0c265646bece42b7573037b2e35f8 detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 844e2e226580488f3f0acd3b0ab1ce2a9d733719 detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 45cb35736d8c4d4429f18fcd068734175a171c2a detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f253daa6887ef6048507801bd1254e4e7609aced detected on system skipping install.
2024-10-20 20:09:04,725 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 77b84d3798d95191f37e2cd24549f66359b9612d detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 37462a8900c47f41d6d42f2f42553c5416a1ceb5 detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 930865d524af22115c7de84475b26ed02b25207f detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7c29030942ca087d4e5104a453531831114acd2f detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 09fe17abbb70322788ecdffd1aca764920150370 detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6e0a1a79752ef660772ace2159de0cd62421bc39 detected on system skipping install.
2024-10-20 20:09:04,726 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 65117e2f06396681b0a6605c2490ec1626d02731 detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 060116032c7cc33127155acb6cf216dc64b5c2c9 detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b53448026fe456b908c283313fd033543e28fe0b detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b81fd6e312d7bdbf63c6afca6bff99d5953ff2a0 detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 697f99aeb9fba7ef2c852b7bc11d1118fcb0bb86 detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 0c18ba8e501b70c21548315378ac870ecaa8d8f9 detected on system skipping install.
2024-10-20 20:09:04,727 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a3015b91e9697acde203e34be2d3e60fb97c7867 detected on system skipping install.
2024-10-20 20:09:04,728 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6baf56cad33f41bab95f8568ea7f69c9fe1473e9 detected on system skipping install.
2024-10-20 20:09:04,728 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-10-20 20:09:04,728 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 06e57954283854894a88ad4a8436d3d00d3f70c0 detected on system skipping install.
2024-10-20 20:09:04,728 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk da33ebca1418486522dd9f059017b7ff1594230a detected on system skipping install.
2024-10-20 20:09:04,728 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5e435c890e98d165e1280f21228826b76dc86a87 detected on system skipping install.
2024-10-20 20:09:04,729 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 85686d5942cf19e82b61aceceaea893265cc2956 detected on system skipping install.
2024-10-20 20:09:04,729 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 8a556380a00b43fa0e4a76db5eeae2da80672aae detected on system skipping install.
2024-10-20 20:09:04,729 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 250545db385fa3bf65e6bbfb5804e8a388939582 detected on system skipping install.
2024-10-20 20:09:04,731 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f06a1b7692e3d26a0f3da0ed3a15c48f6dd7f7fc detected on system skipping install.
2024-10-20 20:09:04,731 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c76372825b4134c42f40b49fdc37489cf1ca6cea detected on system skipping install.
2024-10-20 20:09:04,731 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 814176b0b3ac80f358f60b920b5daa9561fb19e6 detected on system skipping install.
2024-10-20 20:09:04,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 64e80901ff0412fd1770b47d1d5af4910f3efada detected on system skipping install.
2024-10-20 20:09:04,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f474df637f0164ab8fd956c16b7895fc3f70aed9 detected on system skipping install.
2024-10-20 20:09:04,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 7f824eab819b7a46d47bb3f655d39707e4e185d3 detected on system skipping install.
2024-10-20 20:09:04,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 147698f2e933654bd2977211a0fad33d60830942 detected on system skipping install.
2024-10-20 20:09:04,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 060f1c8c7f51c3f328d82be8c6eaa14739e35541 detected on system skipping install.
2024-10-20 20:09:04,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cf919f1a3e2f56a7f4f9b87557160da758794ca7 detected on system skipping install.
2024-10-20 20:09:04,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 795c4ffb2c7a6f1f029c1043b235153eac6a9d88 detected on system skipping install.
2024-10-20 20:09:04,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9c0445c9266a5337d5602ee8ba6dd76615ed1abe detected on system skipping install.
2024-10-20 20:09:04,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-10-20 20:09:04,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-10-20 20:09:04,767 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-10-20 20:09:04,768 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:09:04,768 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/12d02acb4d2f84534c8f6f8563214b7032da3b95.js...
2024-10-20 20:09:04,781 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,781 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,781 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,934 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2146268449abc457e3182706607590877ca49bcb.ta... for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:09:04,949 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,949 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,951 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ce99e2d44d207da229fe7fbd1d4ae44b2af1263d.ta... for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:09:04,951 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:04,951 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-10-20 20:09:04,965 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:04,966 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:04,966 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:05,044 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:09:05,049 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e
2024-10-20 20:09:05,970 - MainProcess(31116) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:09:07,371 - MainProcess(31116) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-20 20:09:07,372 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:09:07,372 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-10-20 20:09:07,373 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-10-20 20:09:07,373 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-10-20 20:09:07,373 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\streamingsession.json
2024-10-20 20:09:07,381 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-10-20 20:09:07,402 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\ApplicationOptions.production.json as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Fusion 360.server.config
2024-10-20 20:09:07,402 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:09:07,418 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\AdpSDKGlobal.config
2024-10-20 20:09:07,418 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:09:07,428 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpdesktopsdk.env
2024-10-20 20:09:07,428 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-20 20:09:07,429 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-10-20 20:09:07,430 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-10-20 20:09:07,437 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-10-20 20:09:07,437 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-10-20 20:09:07,452 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-20 20:09:07,452 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-20 20:09:07,452 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-20 20:09:07,575 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is eb31573c8bf111a2be2f78454a20aeb9:1728534118.767573
2024-10-20 20:09:07,575 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-10-20 20:09:07,575 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'eb31573c8bf111a2be2f78454a20aeb9:1728534118.767573' to option 'ETag'
2024-10-20 20:09:07,575 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-10-20 20:09:07,576 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-10-20 20:09:07,590 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:09:07,590 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-10-20 20:09:07,590 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-10-20 20:09:07,595 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:09:07,595 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260354, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1729426081, st_mtime=1728465997, st_ctime=1729426013)
2024-10-20 20:09:07,595 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-10-20 20:09:07,596 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:09:07,597 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=281474977128387, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1729426013, st_mtime=1728466055, st_ctime=1729426013)
2024-10-20 20:09:07,597 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-10-20 20:09:07,598 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:09:07,599 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=281474977128388, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1729426013, st_mtime=1728466055, st_ctime=1729426013)
2024-10-20 20:09:07,599 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-10-20 20:09:07,600 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:09:07,600 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=281474977128389, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1729426013, st_mtime=1728466055, st_ctime=1729426013)
2024-10-20 20:09:07,600 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-10-20 20:09:07,601 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=281474977128390, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1729426013, st_mtime=1728466055, st_ctime=1729426013)
2024-10-20 20:09:07,601 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-10-20 20:09:07,602 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-20 20:09:07,602 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=281474977128391, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1729426013, st_mtime=1728466055, st_ctime=1729426013)
2024-10-20 20:09:07,602 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-10-20 20:09:07,602 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-10-20 20:09:07,603 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-10-20 20:09:07,603 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-10-20 20:09:07,603 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-10-20 20:09:07,603 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-10-20 20:09:07,604 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-10-20 20:09:07,604 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-10-20 20:09:07,605 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-10-20 20:09:07,605 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:09:07,605 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:09:07,605 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:09:07,634 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:09:07,634 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:09:07,634 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-20 20:09:07,639 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:09:07,639 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-10-20 20:09:07,644 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-20 20:09:07,644 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-10-20 20:09:07,650 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:09:07,650 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:09:07,650 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:09:07,651 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:09:07,651 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:09:07,682 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-20 20:09:07,682 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-20 20:09:07,682 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-20 20:09:07,682 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-20 20:09:07,682 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-20 20:09:07,690 - MainProcess(31116) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 12d02acb4d2f84534c8f6f8563214b7032da3b95:
2024-10-20 20:09:07,732 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-20 20:09:07,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-20 20:09:07,733 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-10-20 20:09:08,270 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get local dns 'utf-8' codec can't decode byte 0xa6 in position 0: invalid start byte.
2024-10-20 20:09:08,270 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS:
2024-10-20 20:09:08,271 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-20 20:09:08,271 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
IndexError
2024-10-20 20:14:35,486 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-20 20:14:35,500 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 12d02acb4d2f84534c8f6f8563214b7032da3b95
2024-10-20 20:14:35,500 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpdesktopsdk.env
2024-10-20 20:14:35,501 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\adpsdkglobal.config
2024-10-20 20:14:35,551 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c8ccd68f9db18c054d1ebc9c01376922733ac46e\fusion 360.server.config
2024-10-20 20:14:35,694 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy
2024-10-20 20:14:37,405 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-10-20 20:14:37,409 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-10-20 20:14:37,410 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-10-20 20:14:37,410 - MainProcess(31116) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\chouj\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002A5291BB6A0> #
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\chouj\AppData\Local\Temp\7zSD9C6.tmp\resources\buildinfo.json
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-10-22 21:13:23,342 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: zh_TW
2024-10-22 21:13:23,343 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\chouj\AppData\Local\Temp\7zSD9C6.tmp\resources
2024-10-22 21:13:23,344 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\chouj\AppData\Local\Temp\7zSD9C6.tmp\certs.pem
2024-10-22 21:13:23,344 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-10-22 21:13:23,344 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-10-22 21:13:23,344 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-10-22 21:13:23,345 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002A5291B4AF0>, operation=<function multiple_operate at 0x000002A5288FC3A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-10-22 21:13:23,345 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-10-22 21:13:23,345 - MainProcess(36440) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-10-22 21:13:23,345 - MainProcess(36440) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-10-22 21:13:23,345 - MainProcess(36440) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-10-22 21:13:23,742 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-10-22 21:13:23,801 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-10-22 21:13:25,035 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-10-22 21:13:25,035 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-10-22 21:13:25,035 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-10-22 21:13:25,035 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm created successfully
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\chouj\AppData\Local\Autodesk\check_perm removed successfully
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\chouj\AppData\Local\Autodesk
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-10-22 21:13:25,036 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-10-22 21:13:25,408 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-22 21:13:25,409 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-22 21:13:25,409 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-22 21:13:25,409 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-22 21:13:25,442 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:25,442 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:25,442 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:25,442 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-10-22 21:13:25,442 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-10-22 21:13:25,443 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.41.132.52
2024-10-22 21:13:25,491 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-22 21:13:25,492 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-22 21:13:25,492 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4yMjAuOTI=
2024-10-22 21:13:25,493 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-22 21:13:25,493 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-10-22 21:13:26,027 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-10-22 21:13:26,027 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-10-22 21:13:26,027 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-10-22 21:13:26,270 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-22 21:13:26,270 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-22 21:13:26,285 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:26,285 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:26,285 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:26,437 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000002A504F66C10>
2024-10-22 21:13:26,437 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-10-22 21:13:26,437 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-10-22 21:13:26,625 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-10-22 21:13:26,625 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.41.132.52
2024-10-22 21:13:26,625 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-22 21:13:26,625 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-22 21:13:26,639 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:26,639 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:26,639 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:26,772 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-10-22 21:13:26,772 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-10-22 21:13:26,772 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-10-22 21:13:26,772 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-10-22 21:13:26,772 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-10-22 21:13:26,788 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:26,789 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:26,789 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:26,948 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is d92c9e2c-0377-4afe-9660-61e7fefca236
2024-10-22 21:13:26,961 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.20494 for app 73e72ada57b7480280f7a6f4a289729f
2024-10-22 21:13:26,962 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-22 21:13:27,008 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6e0a1a79752ef660772ace2159de0cd62421bc39 detected on system skipping install.
2024-10-22 21:13:27,010 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-10-22 21:13:27,015 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-10-22 21:13:27,015 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-10-22 21:13:27,057 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-10-22 21:13:27,058 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 828540bf6f86ed15baacbbcab028416fa763c0ec
2024-10-22 21:13:27,058 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/828540bf6f86ed15baacbbcab028416fa763c0ec.js...
2024-10-22 21:13:27,074 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,074 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,074 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,316 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/525687bc074c074d64a9f45c61b70c2ef974aab9.ta... for package 828540bf6f86ed15baacbbcab028416fa763c0ec
2024-10-22 21:13:27,316 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1e18e0f841bf7fe70c63694433fa795c4d13aa05
2024-10-22 21:13:27,328 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1e18e0f841bf7fe70c63694433fa795c4d13aa05.js...
2024-10-22 21:13:27,329 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,329 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,341 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,343 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,343 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,343 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,541 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:27,542 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2024-10-22 21:13:27,542 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d0750183ba931dbd99bb0dd6aa66d459473c4c6f.ta... for package 1e18e0f841bf7fe70c63694433fa795c4d13aa05
2024-10-22 21:13:27,542 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c44ed0260a6eb974765844bf11cb52023bf9f86d
2024-10-22 21:13:27,555 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,556 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,556 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,555 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c44ed0260a6eb974765844bf11cb52023bf9f86d.js...
2024-10-22 21:13:27,569 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,570 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,570 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,786 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:27,812 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1d3efe0b1ae783f6c642df36ab98feb9fe581e0b.ta... for package c44ed0260a6eb974765844bf11cb52023bf9f86d
2024-10-22 21:13:27,813 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6ff7584bae79e36b3f3a41d61e069f381dee75e3
2024-10-22 21:13:27,825 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6ff7584bae79e36b3f3a41d61e069f381dee75e3.js...
2024-10-22 21:13:27,827 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,827 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,840 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:27,843 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:27,843 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:27,843 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,161 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:28,176 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f0163b3bb7a4264fa724453137af60a6206f79c6.ta... for package 6ff7584bae79e36b3f3a41d61e069f381dee75e3
2024-10-22 21:13:28,177 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 72fa5f09e8e9d7aee576c591f157c6e812377eb3
2024-10-22 21:13:28,177 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/72fa5f09e8e9d7aee576c591f157c6e812377eb3.js...
2024-10-22 21:13:28,191 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,191 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,191 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,207 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,207 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,207 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,553 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a1387af9da7c5634f2e04e54a5b96bdefd3e833b
2024-10-22 21:13:28,553 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a1387af9da7c5634f2e04e54a5b96bdefd3e833b.js...
2024-10-22 21:13:28,574 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:28,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,774 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:28,775 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ff4fc77a0f64c8334424369a6f82052041804ce0.ta... for package 72fa5f09e8e9d7aee576c591f157c6e812377eb3
2024-10-22 21:13:28,801 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,802 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,802 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,865 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:28,917 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bed05e23b6bea0f04e7f97f86bb70db828676abf
2024-10-22 21:13:28,917 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bed05e23b6bea0f04e7f97f86bb70db828676abf.js...
2024-10-22 21:13:28,917 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/922809066305cdd0c7e0e2a5533154521f63888c.ta... for package a1387af9da7c5634f2e04e54a5b96bdefd3e833b
2024-10-22 21:13:28,961 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,961 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,961 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:28,964 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:28,964 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:28,964 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:29,024 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:29,201 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:29,217 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:29,279 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4ebc29e0e990d40ee176e2e94c684610e14b2aaa
2024-10-22 21:13:29,280 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4ebc29e0e990d40ee176e2e94c684610e14b2aaa.js...
2024-10-22 21:13:29,280 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ae51f179ff0244e690d862eb3506f3072a7293d9.ta... for package bed05e23b6bea0f04e7f97f86bb70db828676abf
2024-10-22 21:13:29,305 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:29,305 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:29,315 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:29,331 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:29,332 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:29,332 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:29,879 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6447f2a747d81f77ca32a02beb5baf74b57f6b5b
2024-10-22 21:13:29,879 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6447f2a747d81f77ca32a02beb5baf74b57f6b5b.js...
2024-10-22 21:13:29,910 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:29,910 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:29,910 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:29,912 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:30,438 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1ca2d69a2b1d65167033072a12e92ee8db169e4b
2024-10-22 21:13:30,438 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1ca2d69a2b1d65167033072a12e92ee8db169e4b.js...
2024-10-22 21:13:30,460 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:30,460 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:30,460 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:30,534 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:30,535 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/48e4eb5ac3379a5fbd564b7f4b6b5a78ca68ce4e.ta... for package 4ebc29e0e990d40ee176e2e94c684610e14b2aaa
2024-10-22 21:13:30,556 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:30,556 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:30,556 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:30,990 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b2b2376a51186f865e069dbc34b5f9a18a981278
2024-10-22 21:13:30,990 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b2b2376a51186f865e069dbc34b5f9a18a981278.js...
2024-10-22 21:13:31,011 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:31,011 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:31,011 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:31,506 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:33,575 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:33,577 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d963aa42c61d1ccd9af6615cc5c13b3308880bff.ta... for package 6447f2a747d81f77ca32a02beb5baf74b57f6b5b
2024-10-22 21:13:33,618 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:33,619 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:33,619 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:35,530 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:36,278 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 711c769d1a5c332084d1fd5d122f02bba348ee8d
2024-10-22 21:13:36,279 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/711c769d1a5c332084d1fd5d122f02bba348ee8d.js...
2024-10-22 21:13:36,299 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:36,299 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:36,299 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:36,441 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:36,441 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5dd8837f7ad6cea276b07671174b3c6df8afac9e.ta... for package 1ca2d69a2b1d65167033072a12e92ee8db169e4b
2024-10-22 21:13:36,463 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:36,463 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:36,463 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:36,715 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e97ff953cbd3b509a01cf64de68d7aa37422afad
2024-10-22 21:13:36,715 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e97ff953cbd3b509a01cf64de68d7aa37422afad.js...
2024-10-22 21:13:36,735 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:36,735 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:36,736 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:36,788 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:37,413 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4cdfb14333b831231bb0f8ad1a4cfea7ced4abd7
2024-10-22 21:13:37,413 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4cdfb14333b831231bb0f8ad1a4cfea7ced4abd7.js...
2024-10-22 21:13:37,433 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:37,433 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:37,433 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:39,598 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e3bcc3ecd406163e87d775d20a0001bb08310d86
2024-10-22 21:13:39,598 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e3bcc3ecd406163e87d775d20a0001bb08310d86.js...
2024-10-22 21:13:39,618 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:39,618 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:39,618 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:43,104 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: fa27cfa56ec93c0ce0a6dfc4d937f0ed7a57177b
2024-10-22 21:13:43,104 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/fa27cfa56ec93c0ce0a6dfc4d937f0ed7a57177b.js...
2024-10-22 21:13:43,125 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:43,125 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:43,126 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:43,786 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b5587d04088e6d047afcff3565da85dd49d4941b
2024-10-22 21:13:43,787 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b5587d04088e6d047afcff3565da85dd49d4941b.js...
2024-10-22 21:13:43,808 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:43,808 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:43,808 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:44,057 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 355879358185019c65b35ace21b47011dfdcd799
2024-10-22 21:13:44,057 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/355879358185019c65b35ace21b47011dfdcd799.js...
2024-10-22 21:13:44,080 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:44,080 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:44,080 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:44,393 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 988102258e0cd26696c6b570cd3a375641324af4
2024-10-22 21:13:44,394 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/988102258e0cd26696c6b570cd3a375641324af4.js...
2024-10-22 21:13:44,416 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:44,417 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:44,417 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:45,068 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8679c423244064749429ffac555295a5fbe823c6
2024-10-22 21:13:45,068 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8679c423244064749429ffac555295a5fbe823c6.js...
2024-10-22 21:13:45,090 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:45,090 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:45,090 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:46,051 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9a2ca85ffe8de177193a6ffed98a43c8329be9e8
2024-10-22 21:13:46,051 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9a2ca85ffe8de177193a6ffed98a43c8329be9e8.js...
2024-10-22 21:13:46,072 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:46,072 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:46,072 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:46,207 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:46,207 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9ee72976cb6986b4b25366e41d910c1005fc9c88.ta... for package b2b2376a51186f865e069dbc34b5f9a18a981278
2024-10-22 21:13:46,229 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:46,230 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:46,230 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:46,960 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:46,972 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 79ded382b4689b79a5d25b8c45da9c4a47365fa2
2024-10-22 21:13:46,972 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/79ded382b4689b79a5d25b8c45da9c4a47365fa2.js...
2024-10-22 21:13:46,996 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:46,996 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:46,997 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:47,500 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 2e3df0a94b285469e8e7d1b5c2835a910b014a76
2024-10-22 21:13:47,501 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/2e3df0a94b285469e8e7d1b5c2835a910b014a76.js...
2024-10-22 21:13:47,524 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:47,524 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:47,525 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:48,230 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a28b7875114199c1777c23031af18cd64b08d759
2024-10-22 21:13:48,230 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a28b7875114199c1777c23031af18cd64b08d759.js...
2024-10-22 21:13:48,251 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:48,252 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:48,252 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:48,601 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6f8979aa76de8cd05483df538b1af3c336fb0248
2024-10-22 21:13:48,601 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6f8979aa76de8cd05483df538b1af3c336fb0248.js...
2024-10-22 21:13:48,622 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:48,622 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:48,623 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:48,795 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 51d03bac06a29650822934d4b4a29fa0e17f996b
2024-10-22 21:13:48,795 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/51d03bac06a29650822934d4b4a29fa0e17f996b.js...
2024-10-22 21:13:48,819 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:48,819 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:48,819 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:49,198 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e80b9833275b4f74d1b2cef12a30a4e1a38303f2
2024-10-22 21:13:49,198 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e80b9833275b4f74d1b2cef12a30a4e1a38303f2.js...
2024-10-22 21:13:49,224 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:49,224 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:49,224 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:49,654 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:49,654 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fb3bbaa323ad23f25c307537eca451dec5466772.ta... for package 711c769d1a5c332084d1fd5d122f02bba348ee8d
2024-10-22 21:13:49,678 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:49,678 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:49,678 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:49,724 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1e7814432acabc28687ddb85340f29236cea74da
2024-10-22 21:13:49,724 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1e7814432acabc28687ddb85340f29236cea74da.js...
2024-10-22 21:13:49,745 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:49,745 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:49,745 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:49,876 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:49,911 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 8ab301d75bf169d28409c711222a9e4a70e3aaed
2024-10-22 21:13:49,911 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/8ab301d75bf169d28409c711222a9e4a70e3aaed.js...
2024-10-22 21:13:49,933 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:49,933 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:49,933 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:50,271 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5f1abfbbab0dcb18f18c034bf2646cf6548629ea
2024-10-22 21:13:50,272 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5f1abfbbab0dcb18f18c034bf2646cf6548629ea.js...
2024-10-22 21:13:50,294 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:50,294 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:50,294 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:50,317 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:50,318 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4b504ec33d5941fd7ad6dcea6670ba98c8e35804.ta... for package e97ff953cbd3b509a01cf64de68d7aa37422afad
2024-10-22 21:13:50,339 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:50,339 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:50,340 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:50,554 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f63a28c483e1168c07bc308aa2f3e1db638bd8b3
2024-10-22 21:13:50,554 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f63a28c483e1168c07bc308aa2f3e1db638bd8b3.js...
2024-10-22 21:13:50,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:50,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:50,575 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:50,598 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:51,000 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 374ed3ae06ee76391dac8c805de554bfc55cd569
2024-10-22 21:13:51,000 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/374ed3ae06ee76391dac8c805de554bfc55cd569.js...
2024-10-22 21:13:51,020 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:51,021 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:51,021 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:51,307 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9512b74ef9026208d7c86e30c460f7ee3edd098f
2024-10-22 21:13:51,307 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9512b74ef9026208d7c86e30c460f7ee3edd098f.js...
2024-10-22 21:13:51,328 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:51,328 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:51,328 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:52,030 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:13:52,030 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/0e7a82af427fc59c847d94b1494dbda61e0f9bee.js...
2024-10-22 21:13:52,051 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:52,051 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:52,051 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:52,069 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:52,070 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ba0570f3479f0b2de96c2e7baa5ceef63481b761.ta... for package 4cdfb14333b831231bb0f8ad1a4cfea7ced4abd7
2024-10-22 21:13:52,092 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:52,092 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:52,092 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:52,490 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a90b11542cb055fa2facc85cd328509b07a95134
2024-10-22 21:13:52,490 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a90b11542cb055fa2facc85cd328509b07a95134.js...
2024-10-22 21:13:52,510 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:52,510 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:52,510 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:52,526 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:53,351 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 06ad1578f61e268f94a6006fa51247086c364a4f
2024-10-22 21:13:53,352 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/06ad1578f61e268f94a6006fa51247086c364a4f.js...
2024-10-22 21:13:53,375 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:53,376 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:53,376 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:54,530 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:54,532 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6b30293d8c1f35bc17b487c4048532c60a2d00b2.ta... for package e3bcc3ecd406163e87d775d20a0001bb08310d86
2024-10-22 21:13:54,553 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:54,553 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:54,553 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:55,112 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:55,114 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/33b1942ded55920fa5948e5181124b473069f9fd.ta... for package fa27cfa56ec93c0ce0a6dfc4d937f0ed7a57177b
2024-10-22 21:13:55,137 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:55,137 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:55,137 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:55,242 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f6bf22b5c50227b6eea656e2c2b7eb2b12f30ddf
2024-10-22 21:13:55,243 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f6bf22b5c50227b6eea656e2c2b7eb2b12f30ddf.js...
2024-10-22 21:13:55,264 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:55,264 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:55,265 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:55,399 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:55,885 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:13:56,400 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dd2079c204ba8d6dd4deac18583c130fd1463c97
2024-10-22 21:13:56,400 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dd2079c204ba8d6dd4deac18583c130fd1463c97.js...
2024-10-22 21:13:56,421 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:56,421 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:56,421 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:13:56,425 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:13:56,425 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/779b325c3f0a02f1bd36c53acf7404102fddc847.ta... for package b5587d04088e6d047afcff3565da85dd49d4941b
2024-10-22 21:13:56,448 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:13:56,448 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:13:56,448 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:01,802 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:01,871 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9cc90d8829ead060992e699e3b2018bf10c2c025
2024-10-22 21:14:01,871 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9cc90d8829ead060992e699e3b2018bf10c2c025.js...
2024-10-22 21:14:01,892 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:01,892 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:01,893 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:02,229 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5eebf4f01c921efcfaeb5c5819b8bbfcdb79221e
2024-10-22 21:14:02,229 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5eebf4f01c921efcfaeb5c5819b8bbfcdb79221e.js...
2024-10-22 21:14:02,252 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:02,252 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:02,252 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:02,664 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:14:02,664 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c3ab23ec323c0b5b67b1f758e869e194f9b33e40.ta... for package 355879358185019c65b35ace21b47011dfdcd799
2024-10-22 21:14:02,686 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:02,687 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:02,687 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:02,744 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d611ddf8df40832c535cf9081b699932a92b17df
2024-10-22 21:14:02,745 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d611ddf8df40832c535cf9081b699932a92b17df.js...
2024-10-22 21:14:02,766 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:02,766 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:02,766 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:03,176 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:03,311 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:14:03,311 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/aad9b566c0af723f2ab18c45698ee6c404c6cf7b.js...
2024-10-22 21:14:03,332 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:03,333 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:03,333 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:03,666 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:14:03,667 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/569db0b08c8a62332e5a88aa98a76d47550267a8.ta... for package 988102258e0cd26696c6b570cd3a375641324af4
2024-10-22 21:14:03,689 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:03,689 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:03,689 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:04,020 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c14dcd31dfe493ad241dd576c7ceebf89cf7ada0
2024-10-22 21:14:04,020 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c14dcd31dfe493ad241dd576c7ceebf89cf7ada0.js...
2024-10-22 21:14:04,041 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:04,042 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:04,042 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:04,384 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:04,493 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:14:04,494 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9c4d287d7f5f1b0cffb0acf228227ce67176d045.ta... for package 8679c423244064749429ffac555295a5fbe823c6
2024-10-22 21:14:04,517 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:04,518 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:04,518 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:04,524 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:14:04,525 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0fca1a138b30d2b5b21491168445fda29f1319c7.ta... for package 9a2ca85ffe8de177193a6ffed98a43c8329be9e8
2024-10-22 21:14:04,547 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:04,547 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:04,547 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:04,927 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bf31d559df77bb6dbb31511a4f49fd9eb63a3653
2024-10-22 21:14:04,927 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bf31d559df77bb6dbb31511a4f49fd9eb63a3653.js...
2024-10-22 21:14:04,948 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:04,948 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:04,948 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:05,210 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:05,261 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:05,775 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 177c34e87ffd489ba7d5ff585719d2cf38e029e3
2024-10-22 21:14:05,776 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/177c34e87ffd489ba7d5ff585719d2cf38e029e3.js...
2024-10-22 21:14:05,799 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:05,799 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:05,799 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:06,838 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:14:06,839 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/af3a09a34cd0f970ef58bd19132afb462b499d2e.js...
2024-10-22 21:14:06,860 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:06,860 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:06,861 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:12,344 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e37606b2180b352f511ff47276ffea1fee80b601
2024-10-22 21:14:12,345 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e37606b2180b352f511ff47276ffea1fee80b601.js...
2024-10-22 21:14:12,365 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:12,365 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:12,365 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:16,803 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e372fc2e644613f809416741459814a264e22e24
2024-10-22 21:14:16,804 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e372fc2e644613f809416741459814a264e22e24.js...
2024-10-22 21:14:16,855 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:16,855 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:16,855 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:22,003 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:14:22,003 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/27fb3ad5f870ce052e762fd8fbc0ba4503c55e83.js...
2024-10-22 21:14:22,026 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:22,027 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:22,027 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:22,828 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 1d009d2d6f7a61f92c9faaf89e636ec9bbcdf4b2
2024-10-22 21:14:22,829 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/1d009d2d6f7a61f92c9faaf89e636ec9bbcdf4b2.js...
2024-10-22 21:14:22,854 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:22,854 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:22,854 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:23,392 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 70b57fd1c54162ff9971b3740c6d9f471ad60d13
2024-10-22 21:14:23,392 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/70b57fd1c54162ff9971b3740c6d9f471ad60d13.js...
2024-10-22 21:14:23,413 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:23,414 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:23,414 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:23,787 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:14:23,788 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6f9bea3cb9eb4f223a20d5a85b89e5e1a7284af3.ta... for package 79ded382b4689b79a5d25b8c45da9c4a47365fa2
2024-10-22 21:14:23,811 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:23,812 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:23,812 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:24,156 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b80b1cf05b5819c5e46a6af41d02ea252a3f785e
2024-10-22 21:14:24,156 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b80b1cf05b5819c5e46a6af41d02ea252a3f785e.js...
2024-10-22 21:14:24,179 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:24,179 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:24,180 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:24,465 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:14:24,977 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a6f93cb5bcde2fb5e81416c71bfcfcf69e0b9ee1
2024-10-22 21:14:24,977 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a6f93cb5bcde2fb5e81416c71bfcfcf69e0b9ee1.js...
2024-10-22 21:14:25,000 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:25,000 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:25,001 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:25,779 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 02ce62bdfe5355eb55a3a462e0615b22548a549b
2024-10-22 21:14:25,779 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/02ce62bdfe5355eb55a3a462e0615b22548a549b.js...
2024-10-22 21:14:25,803 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:25,803 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:25,803 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:26,923 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 451e9b020bf30b70a9ee8fe04457016d4765d7a6
2024-10-22 21:14:26,923 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/451e9b020bf30b70a9ee8fe04457016d4765d7a6.js...
2024-10-22 21:14:26,948 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:26,949 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:26,949 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:27,839 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d782d3508bcfa6f1f09f09caed3e0a755b18db6a
2024-10-22 21:14:27,839 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d782d3508bcfa6f1f09f09caed3e0a755b18db6a.js...
2024-10-22 21:14:27,859 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:27,859 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:27,859 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:28,227 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 614d7775135d7db67ad06ade3bedbf59b2eb1a3f
2024-10-22 21:14:28,227 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/614d7775135d7db67ad06ade3bedbf59b2eb1a3f.js...
2024-10-22 21:14:28,249 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:28,249 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:28,249 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:28,614 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c1592705e1d9f9bb53fcbde2b6d35bc5c2a580b3
2024-10-22 21:14:28,615 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c1592705e1d9f9bb53fcbde2b6d35bc5c2a580b3.js...
2024-10-22 21:14:28,637 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:28,637 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:28,637 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:29,079 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: be1259dc7b8caeaac3fd035b7bf7509ec698d797
2024-10-22 21:14:29,079 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/be1259dc7b8caeaac3fd035b7bf7509ec698d797.js...
2024-10-22 21:14:29,100 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:29,100 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:29,100 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:29,779 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c6969c2542890b10e7996f9bfebb044a9e145411
2024-10-22 21:14:29,779 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c6969c2542890b10e7996f9bfebb044a9e145411.js...
2024-10-22 21:14:29,815 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:14:29,816 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:14:29,816 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:14:30,218 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-10-22 21:14:30,223 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 828540bf6f86ed15baacbbcab028416fa763c0ec
2024-10-22 21:14:30,269 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1e18e0f841bf7fe70c63694433fa795c4d13aa05
2024-10-22 21:14:30,387 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c44ed0260a6eb974765844bf11cb52023bf9f86d
2024-10-22 21:14:30,432 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6ff7584bae79e36b3f3a41d61e069f381dee75e3
2024-10-22 21:14:30,477 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 72fa5f09e8e9d7aee576c591f157c6e812377eb3
2024-10-22 21:14:30,542 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a1387af9da7c5634f2e04e54a5b96bdefd3e833b
2024-10-22 21:14:30,581 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for bed05e23b6bea0f04e7f97f86bb70db828676abf
2024-10-22 21:14:30,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4ebc29e0e990d40ee176e2e94c684610e14b2aaa
2024-10-22 21:14:30,668 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6447f2a747d81f77ca32a02beb5baf74b57f6b5b
2024-10-22 21:14:30,710 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1ca2d69a2b1d65167033072a12e92ee8db169e4b
2024-10-22 21:14:30,752 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b2b2376a51186f865e069dbc34b5f9a18a981278
2024-10-22 21:14:30,832 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 711c769d1a5c332084d1fd5d122f02bba348ee8d
2024-10-22 21:14:31,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e97ff953cbd3b509a01cf64de68d7aa37422afad
2024-10-22 21:14:31,090 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4cdfb14333b831231bb0f8ad1a4cfea7ced4abd7
2024-10-22 21:14:31,135 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e3bcc3ecd406163e87d775d20a0001bb08310d86
2024-10-22 21:14:31,183 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for fa27cfa56ec93c0ce0a6dfc4d937f0ed7a57177b
2024-10-22 21:14:31,242 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b5587d04088e6d047afcff3565da85dd49d4941b
2024-10-22 21:14:31,289 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 355879358185019c65b35ace21b47011dfdcd799
2024-10-22 21:15:04,083 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:04,085 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7ca456d01d987a6b1c1a0d76329df1b4b9dc1417.ta... for package 2e3df0a94b285469e8e7d1b5c2835a910b014a76
2024-10-22 21:15:04,119 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:04,120 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:04,120 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:04,628 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:04,639 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:04,639 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b76c4525292025f4b10360bf3a7f64bc1f7c059a.ta... for package a28b7875114199c1777c23031af18cd64b08d759
2024-10-22 21:15:04,675 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:04,676 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:04,678 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:05,051 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:11,220 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:11,225 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ea5b09eb819ded3b720e5a8ca7ff2c52dff5976e.ta... for package 6f8979aa76de8cd05483df538b1af3c336fb0248
2024-10-22 21:15:11,260 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:11,262 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:11,262 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:11,918 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:12,624 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:12,625 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/51de51e14a84ce5638ed445beeaf393bf32460dc.ta... for package 51d03bac06a29650822934d4b4a29fa0e17f996b
2024-10-22 21:15:12,686 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:12,686 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:12,686 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:13,447 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:18,674 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:18,675 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/db98822d9e9bc13bf64dc582454362627be18bfc.ta... for package e80b9833275b4f74d1b2cef12a30a4e1a38303f2
2024-10-22 21:15:18,714 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:18,715 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:18,715 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:20,250 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:20,887 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:20,889 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/883e39311321da640108642f5c3c3cf266ff96ca.ta... for package 1e7814432acabc28687ddb85340f29236cea74da
2024-10-22 21:15:20,925 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:20,926 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:20,926 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:20,936 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 988102258e0cd26696c6b570cd3a375641324af4
2024-10-22 21:15:21,004 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8679c423244064749429ffac555295a5fbe823c6
2024-10-22 21:15:21,427 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:21,428 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b5ce99e67631cc68d32538bdecb574eb3485839b.ta... for package 8ab301d75bf169d28409c711222a9e4a70e3aaed
2024-10-22 21:15:21,470 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:21,470 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:21,471 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:21,527 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:22,083 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:23,408 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:23,409 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d7c78ed044c30d65361bcd482b867b4458e0f968.ta... for package 5f1abfbbab0dcb18f18c034bf2646cf6548629ea
2024-10-22 21:15:23,450 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:23,450 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:23,450 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:23,706 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:26,247 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:26,249 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e2cfdd1d97648061befd0a1ee85129ae00d4aefa.ta... for package f63a28c483e1168c07bc308aa2f3e1db638bd8b3
2024-10-22 21:15:26,297 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:26,297 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:26,298 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:27,031 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:27,178 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:27,179 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9f1f3ad14fa1397fbe6ab6ce71853376c068342b.ta... for package 374ed3ae06ee76391dac8c805de554bfc55cd569
2024-10-22 21:15:27,224 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:27,224 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:27,225 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:27,605 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:27,813 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:27,814 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d882a6c0eb44b0fd9daca133c136560786d2eaf4.ta... for package 9512b74ef9026208d7c86e30c460f7ee3edd098f
2024-10-22 21:15:27,847 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:27,847 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:27,847 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:28,437 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:29,838 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:29,839 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6df670ce74cfd6be32a2ad1541f7e8dd591af31c.ta... for package 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:15:29,905 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:29,906 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:29,906 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:30,438 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:47,953 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:47,954 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fdc69d27874f1c94f8918c8fecc4471ccc3aa1c3.ta... for package 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:15:47,977 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:47,977 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:47,977 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:47,983 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9a2ca85ffe8de177193a6ffed98a43c8329be9e8
2024-10-22 21:15:48,040 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 79ded382b4689b79a5d25b8c45da9c4a47365fa2
2024-10-22 21:15:48,180 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 2e3df0a94b285469e8e7d1b5c2835a910b014a76
2024-10-22 21:15:48,426 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:49,198 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:49,199 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/66a51e36472952404218be6d71583bde8b2721dc.ta... for package a90b11542cb055fa2facc85cd328509b07a95134
2024-10-22 21:15:49,219 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:49,220 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:49,220 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:49,415 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:49,821 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:49,821 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4a8b4940d47acdfb0dcd0bd278954a36162311e2.ta... for package 06ad1578f61e268f94a6006fa51247086c364a4f
2024-10-22 21:15:49,835 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:49,836 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:49,836 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:49,930 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:49,931 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e08d9cdcbecbf3ee9c6a97bab3749c14080a0e36.ta... for package f6bf22b5c50227b6eea656e2c2b7eb2b12f30ddf
2024-10-22 21:15:49,961 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:49,961 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:49,962 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:49,964 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a28b7875114199c1777c23031af18cd64b08d759
2024-10-22 21:15:50,001 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6f8979aa76de8cd05483df538b1af3c336fb0248
2024-10-22 21:15:50,019 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 51d03bac06a29650822934d4b4a29fa0e17f996b
2024-10-22 21:15:50,049 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:50,100 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e80b9833275b4f74d1b2cef12a30a4e1a38303f2
2024-10-22 21:15:50,121 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1e7814432acabc28687ddb85340f29236cea74da
2024-10-22 21:15:50,151 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:15:50,580 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:15:50,581 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cda4bdf9614f1eaa69739444d061a994e7b245b9.ta... for package dd2079c204ba8d6dd4deac18583c130fd1463c97
2024-10-22 21:15:50,602 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:15:50,602 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:15:50,602 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:15:50,770 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:16:07,428 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:16:07,430 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/feac7438819ab8cac2735a9b99aeabd0ef06bd5e.ta... for package 9cc90d8829ead060992e699e3b2018bf10c2c025
2024-10-22 21:16:07,448 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:16:07,448 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:16:07,448 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:16:08,294 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:16:26,814 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:16:26,815 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a2ca4c4208be1e261f0ffe622ca5946e586a057f.ta... for package 5eebf4f01c921efcfaeb5c5819b8bbfcdb79221e
2024-10-22 21:16:26,830 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:16:26,830 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:16:26,830 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:16:27,178 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:18:39,534 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:18:39,536 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/49664fc217e2fff9eb2b49743ff12688038f1996.ta... for package d611ddf8df40832c535cf9081b699932a92b17df
2024-10-22 21:18:39,559 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:18:39,559 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:18:39,559 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:18:39,944 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:18:56,559 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:18:56,560 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f9136618186c70f67880bece08d7e83a17c9b22c.ta... for package aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:18:56,575 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:18:56,575 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:18:56,575 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:18:56,823 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:18:59,740 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:18:59,741 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/92cd274613bedf78ebe42217be516cc7dddb00ce.ta... for package aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:18:59,769 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:18:59,769 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:18:59,769 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:00,761 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:00,936 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:00,937 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/3d65424c79ce12908718421dff50f8fb5d0141be.ta... for package c14dcd31dfe493ad241dd576c7ceebf89cf7ada0
2024-10-22 21:19:00,963 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:00,963 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:00,963 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:02,291 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:38,986 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:38,987 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/26ed5a05b9d1bfa12713c4b337524774543f5510.ta... for package bf31d559df77bb6dbb31511a4f49fd9eb63a3653
2024-10-22 21:19:39,012 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:39,012 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:39,012 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:39,699 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:46,937 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:46,938 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/14c63d21d5da94eeb8b9b7d1f46ecde4b6a04fd6.ta... for package 177c34e87ffd489ba7d5ff585719d2cf38e029e3
2024-10-22 21:19:46,968 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:46,968 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:46,968 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:47,161 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:50,648 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:50,648 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a3905416341a03f2c9ec24a2e56c8ea088513df1.ta... for package af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:19:50,676 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:50,676 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:50,676 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:50,974 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:54,398 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:54,400 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c08c61338be1347e18b2a99786dbba08f50919f9.ta... for package af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:19:54,417 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:54,417 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:54,418 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:54,611 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:19:55,545 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:19:55,547 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d0c8f5c3d9500e87ec855ebd9cde008864a2e9ec.ta... for package e37606b2180b352f511ff47276ffea1fee80b601
2024-10-22 21:19:55,566 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:19:55,566 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:19:55,566 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:19:55,747 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:33,861 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:33,863 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2844663790324558776812efefea1d526a29a98c.ta... for package e372fc2e644613f809416741459814a264e22e24
2024-10-22 21:20:33,886 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:33,886 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:33,886 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:37,017 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:37,688 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:37,688 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/16a3c1743589aac210cd6f59b83801ec3f3f7a53.ta... for package 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:20:37,708 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:37,708 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:37,708 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:39,218 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:49,478 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:49,480 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ac23521caa31c5152c23f8c97b90af5f0845319b.ta... for package 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:20:49,504 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:49,504 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:49,504 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:50,035 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:51,053 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:51,054 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/868afe733dc3b491d816b1166096537cc21781f4.ta... for package 1d009d2d6f7a61f92c9faaf89e636ec9bbcdf4b2
2024-10-22 21:20:51,072 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:51,072 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:51,072 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:51,659 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:52,009 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:52,010 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/be583c99e1cab2ff84ff83436a5f94b7fa6ba572.ta... for package 70b57fd1c54162ff9971b3740c6d9f471ad60d13
2024-10-22 21:20:52,042 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:52,043 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:52,043 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:52,195 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:20:52,433 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:20:52,433 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/16d2e46770cd7caee3539017fdbbf4a5b74614b7.ta... for package b80b1cf05b5819c5e46a6af41d02ea252a3f785e
2024-10-22 21:20:52,460 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:20:52,460 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:20:52,461 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:20:52,727 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:28,824 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:28,826 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0befd547c5b3d99a85cce6184996ee5304b87163.ta... for package b80b1cf05b5819c5e46a6af41d02ea252a3f785e
2024-10-22 21:21:28,839 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:28,840 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:28,840 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:28,840 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 8ab301d75bf169d28409c711222a9e4a70e3aaed
2024-10-22 21:21:28,841 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 7facf0de95414ab9b6315d8fa534bf91(Unknown) was not in registry
2024-10-22 21:21:28,841 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action a92c95fa064f43089136f50437f73d22(Unknown) was not in registry
2024-10-22 21:21:28,841 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 8ab301d75bf169d28409c711222a9e4a70e3aaed
2024-10-22 21:21:28,843 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 8ab301d75bf169d28409c711222a9e4a70e3aaed
2024-10-22 21:21:28,895 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5f1abfbbab0dcb18f18c034bf2646cf6548629ea
2024-10-22 21:21:28,953 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f63a28c483e1168c07bc308aa2f3e1db638bd8b3
2024-10-22 21:21:28,989 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 374ed3ae06ee76391dac8c805de554bfc55cd569
2024-10-22 21:21:29,019 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9512b74ef9026208d7c86e30c460f7ee3edd098f
2024-10-22 21:21:29,053 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:21:29,054 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-22 21:21:29,054 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5c461fa5ff6ec38afa078cf537137159(ADD_REGISTRY_INFO)
2024-10-22 21:21:29,621 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2024-10-22 21:21:29,621 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-22 21:21:29,621 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 36d909d4c5304fc2a6a47bbb9116f50e(REMOVE_STREAMING_SESSION) was not in registry
2024-10-22 21:21:29,622 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:21:29,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 0e7a82af427fc59c847d94b1494dbda61e0f9bee
2024-10-22 21:21:30,016 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a90b11542cb055fa2facc85cd328509b07a95134
2024-10-22 21:21:30,029 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:30,054 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 06ad1578f61e268f94a6006fa51247086c364a4f
2024-10-22 21:21:30,382 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:30,383 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7daf781fd41139634319bb36ceea8eb7a00799e1.ta... for package a6f93cb5bcde2fb5e81416c71bfcfcf69e0b9ee1
2024-10-22 21:21:30,405 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:30,405 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:30,405 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:30,537 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f6bf22b5c50227b6eea656e2c2b7eb2b12f30ddf
2024-10-22 21:21:30,559 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dd2079c204ba8d6dd4deac18583c130fd1463c97
2024-10-22 21:21:30,671 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:30,698 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9cc90d8829ead060992e699e3b2018bf10c2c025
2024-10-22 21:21:35,132 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:35,134 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/63e7d4f701ed16d914b8c76f487a0df23b056560.ta... for package 02ce62bdfe5355eb55a3a462e0615b22548a549b
2024-10-22 21:21:35,159 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:35,159 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:35,159 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:35,338 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:36,217 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:36,218 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/65bf0aa7294b6371b8961a34f6b8f8728b209162.ta... for package 02ce62bdfe5355eb55a3a462e0615b22548a549b
2024-10-22 21:21:36,246 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:36,246 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:36,246 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:36,547 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:36,673 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:36,673 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7a4a723c37032355c84226d50394e23216d3c192.ta... for package 451e9b020bf30b70a9ee8fe04457016d4765d7a6
2024-10-22 21:21:36,688 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:36,688 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:36,688 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:36,886 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:37,109 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:37,110 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d886e876fde7b7d25c5719bea14968a19b9b7cba.ta... for package d782d3508bcfa6f1f09f09caed3e0a755b18db6a
2024-10-22 21:21:37,132 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:37,132 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:37,132 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:37,298 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:38,360 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:38,361 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/864a8b5f1d37a0886c3bf19e6f02945fba597a0a.ta... for package 614d7775135d7db67ad06ade3bedbf59b2eb1a3f
2024-10-22 21:21:38,376 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:38,377 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:38,377 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:38,545 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:44,486 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:44,487 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/87a885ed35ae5076ca7a988ad44822de30f79710.ta... for package c1592705e1d9f9bb53fcbde2b6d35bc5c2a580b3
2024-10-22 21:21:44,502 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:44,503 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:44,503 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:44,732 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:47,237 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:47,238 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7f938bd64a69382a140220ff88e77a71bce4c974.ta... for package c1592705e1d9f9bb53fcbde2b6d35bc5c2a580b3
2024-10-22 21:21:47,255 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:47,255 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:47,255 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:47,553 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:47,657 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:47,657 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/694627aa73389810f94df850ff843ca54ed1527d.ta... for package be1259dc7b8caeaac3fd035b7bf7509ec698d797
2024-10-22 21:21:47,670 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:47,670 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:47,670 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:47,899 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:47,941 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:47,941 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/486935cc538d3ec60539e1e08d0ad943928a6705.ta... for package c6969c2542890b10e7996f9bfebb044a9e145411
2024-10-22 21:21:47,955 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:47,956 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:47,956 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:48,101 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:21:57,275 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:21:57,276 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/965e97e735a68b9e90565ab1d9fbb7af502abf58.ta... for package c6969c2542890b10e7996f9bfebb044a9e145411
2024-10-22 21:21:57,291 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:21:57,292 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:21:57,292 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:21:59,025 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd
2024-10-22 21:22:03,608 - MainProcess(36440) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:22:40,138 - MainProcess(36440) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:24:06,071 - MainProcess(36440) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:24:41,899 - MainProcess(36440) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-10-22 21:24:41,916 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5eebf4f01c921efcfaeb5c5819b8bbfcdb79221e
2024-10-22 21:24:43,474 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d611ddf8df40832c535cf9081b699932a92b17df
2024-10-22 21:24:43,529 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:24:43,529 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-22 21:24:43,530 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:24:43,531 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for aad9b566c0af723f2ab18c45698ee6c404c6cf7b
2024-10-22 21:24:43,610 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c14dcd31dfe493ad241dd576c7ceebf89cf7ada0
2024-10-22 21:24:43,662 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for bf31d559df77bb6dbb31511a4f49fd9eb63a3653
2024-10-22 21:24:43,692 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 177c34e87ffd489ba7d5ff585719d2cf38e029e3
2024-10-22 21:24:43,723 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:24:43,723 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-10-22 21:24:43,723 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-10-22 21:24:43,723 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\streamingsession.json
2024-10-22 21:24:43,736 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:24:43,738 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for af3a09a34cd0f970ef58bd19132afb462b499d2e
2024-10-22 21:24:43,794 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e37606b2180b352f511ff47276ffea1fee80b601
2024-10-22 21:24:43,913 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e372fc2e644613f809416741459814a264e22e24
2024-10-22 21:24:43,949 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform predeploy tasks for package 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:24:43,949 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a9cdc10b1ed64039b7dfd3bf8a0dcd5e(REMOVE_WININSTALLER_PRODUCT)
2024-10-22 21:24:44,056 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {CD2A85EC-C80D-4CAC-01C1-FCCDE4A651C8}. Msiexec returns 1605
2024-10-22 21:24:44,116 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {0188C9F4-CCDE-41E9-0150-6B1CFC6AC596}. Msiexec returns 1605
2024-10-22 21:24:44,116 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform predeploy tasks for package 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:24:44,117 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 27fb3ad5f870ce052e762fd8fbc0ba4503c55e83
2024-10-22 21:24:44,247 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 1d009d2d6f7a61f92c9faaf89e636ec9bbcdf4b2
2024-10-22 21:24:44,298 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 70b57fd1c54162ff9971b3740c6d9f471ad60d13
2024-10-22 21:24:44,357 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b80b1cf05b5819c5e46a6af41d02ea252a3f785e
2024-10-22 21:24:44,584 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a6f93cb5bcde2fb5e81416c71bfcfcf69e0b9ee1
2024-10-22 21:24:44,646 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 02ce62bdfe5355eb55a3a462e0615b22548a549b
2024-10-22 21:24:44,730 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 451e9b020bf30b70a9ee8fe04457016d4765d7a6
2024-10-22 21:24:44,791 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d782d3508bcfa6f1f09f09caed3e0a755b18db6a
2024-10-22 21:24:44,841 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 614d7775135d7db67ad06ade3bedbf59b2eb1a3f
2024-10-22 21:24:44,877 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c1592705e1d9f9bb53fcbde2b6d35bc5c2a580b3
2024-10-22 21:24:44,942 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for be1259dc7b8caeaac3fd035b7bf7509ec698d797
2024-10-22 21:24:44,996 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package c6969c2542890b10e7996f9bfebb044a9e145411
2024-10-22 21:24:44,996 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-10-22 21:24:45,099 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-10-22 21:24:45,099 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-10-22 21:24:45,099 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\streamingsession.json
2024-10-22 21:24:45,114 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-10-22 21:24:45,131 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\Applications\Fusion\Fusion360App\ApplicationOptions.production.json as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\Fusion 360.server.config
2024-10-22 21:24:45,131 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-22 21:24:45,167 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\AdpSDKGlobal.config
2024-10-22 21:24:45,167 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-22 21:24:45,198 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\adpdesktopsdk.env
2024-10-22 21:24:45,198 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-10-22 21:24:45,216 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-10-22 21:24:45,222 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-10-22 21:24:45,230 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-10-22 21:24:45,230 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-10-22 21:24:45,270 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-10-22 21:24:45,271 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-10-22 21:24:45,271 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-10-22 21:24:45,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is 7185a287afc9e1ea3982d9218a163901:1729295712.585494
2024-10-22 21:24:45,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-10-22 21:24:45,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '7185a287afc9e1ea3982d9218a163901:1729295712.585494' to option 'ETag'
2024-10-22 21:24:45,623 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-10-22 21:24:45,630 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-10-22 21:24:45,662 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-22 21:24:45,663 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-10-22 21:24:45,663 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-10-22 21:24:45,673 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,674 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=1407374883971010, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1729426381, st_mtime=1728465997, st_ctime=1729426013)
2024-10-22 21:24:45,674 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-10-22 21:24:45,684 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,684 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=562949953839043, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1729426147, st_mtime=1728466055, st_ctime=1729426013)
2024-10-22 21:24:45,684 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-10-22 21:24:45,764 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,764 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=562949953839044, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1729426147, st_mtime=1728466055, st_ctime=1729426013)
2024-10-22 21:24:45,765 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-10-22 21:24:45,777 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,777 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=562949953839045, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1729426147, st_mtime=1728466055, st_ctime=1729426013)
2024-10-22 21:24:45,777 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-10-22 21:24:45,792 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,792 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=562949953839046, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1729426147, st_mtime=1728466055, st_ctime=1729426013)
2024-10-22 21:24:45,792 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-10-22 21:24:45,856 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-10-22 21:24:45,856 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=562949953839047, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1729426147, st_mtime=1728466055, st_ctime=1729426013)
2024-10-22 21:24:45,856 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-10-22 21:24:45,874 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-10-22 21:24:45,874 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-10-22 21:24:45,875 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-10-22 21:24:45,875 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-10-22 21:24:45,875 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-10-22 21:24:45,875 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-10-22 21:24:45,932 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-10-22 21:24:45,933 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-22 21:24:45,933 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-22 21:24:45,933 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-22 21:24:45,974 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-22 21:24:45,974 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-22 21:24:45,977 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-10-22 21:24:45,985 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-22 21:24:45,985 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-10-22 21:24:45,993 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-10-22 21:24:45,993 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-10-22 21:24:46,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-22 21:24:46,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-22 21:24:46,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-22 21:24:46,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-22 21:24:46,000 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-22 21:24:46,179 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-10-22 21:24:46,179 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-10-22 21:24:46,179 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-10-22 21:24:46,179 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-10-22 21:24:46,179 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-10-22 21:24:46,188 - MainProcess(36440) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for c6969c2542890b10e7996f9bfebb044a9e145411:
2024-10-22 21:24:46,259 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-10-22 21:24:46,260 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNDEuMTMyLjUy
2024-10-22 21:24:46,260 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4yMjAuOTI=
2024-10-22 21:24:46,886 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get local dns 'utf-8' codec can't decode byte 0xa6 in position 0: invalid start byte.
2024-10-22 21:24:46,886 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS:
2024-10-22 21:24:46,886 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-10-22 21:24:46,886 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1160, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 92, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1091, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 909, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1869, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1630, in wait_threads
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\concurrent\futures\thread.py", line 52, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1750, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 406, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 342, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 441, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 398, in __filevisitor
File "R:\src\adsk\dls\streamer\manifests.py", line 62, in __next__
File "R:\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
File "R:\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
File "R:\src\adsk\dls\streamer\utils.py", line 258, in __call__
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 121, in substitute
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 114, in convert
File "R:\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
File "R:\src\adsk\dls\streamer\configuration.py", line 782, in __getitem__
File "R:\src\adsk\dls\streamer\windows\platform.py", line 1993, in __getitem__
File "R:\src\adsk\dls\streamer\platform_base.py", line 104, in __getitem__
IndexError
2024-10-22 21:29:18,444 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-10-22 21:29:18,470 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in c6969c2542890b10e7996f9bfebb044a9e145411
2024-10-22 21:29:18,470 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\adpdesktopsdk.env
2024-10-22 21:29:18,471 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\adpsdkglobal.config
2024-10-22 21:29:18,513 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\766955f24f3d1bdacb570c8ea3d3857eaa1fdddd\fusion 360.server.config
2024-10-22 21:29:18,657 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy
2024-10-22 21:29:20,931 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-10-22 21:29:20,938 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-10-22 21:29:20,938 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-10-22 21:29:20,938 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-10-22 21:29:20,938 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002A5291BB6A0> #
2024-10-22 21:29:20,938 - MainProcess(36440) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-11-08 22:16:55,026 - MainProcess(37940) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\chouj\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-11-08 22:16:55,027 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-11-08 22:16:55,027 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-11-08 22:16:55,027 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000246FFE7B6A0> #
2024-11-08 22:16:55,027 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-11-08 22:16:55,027 - MainProcess(37940) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\chouj\AppData\Local\Temp\7zSE244.tmp\resources\buildinfo.json
2024-11-08 22:16:55,028 - MainProcess(37940) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-11-08 22:16:55,028 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-11-08 22:16:55,028 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: zh_TW
2024-11-08 22:16:55,030 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\chouj\AppData\Local\Temp\7zSE244.tmp\resources
2024-11-08 22:16:55,031 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\chouj\AppData\Local\Temp\7zSE244.tmp\certs.pem
2024-11-08 22:16:55,031 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000246FFE74AF0>, operation=<function multiple_operate at 0x00000246FF5B73A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-11-08 22:16:55,033 - MainProcess(37940) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-11-08 22:16:55,665 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-11-08 22:16:55,783 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-11-08 22:16:56,722 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-11-08 22:16:56,724 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-11-08 22:16:56,724 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-11-08 22:16:56,724 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-11-08 22:16:56,725 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-11-08 22:16:56,725 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-11-08 22:16:56,725 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm created successfully
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\chouj\AppData\Local\Autodesk\check_perm removed successfully
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\chouj\AppData\Local\Autodesk
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-11-08 22:16:56,726 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-11-08 22:16:56,923 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-08 22:16:56,924 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.220.198.109
2024-11-08 22:16:56,925 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-08 22:16:56,925 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-08 22:16:56,983 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:56,984 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:56,984 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:56,984 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-11-08 22:16:56,984 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-11-08 22:16:56,985 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.220.198.109
2024-11-08 22:16:56,998 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-11-08 22:16:57,000 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMjIwLjE5OC4xMDk=
2024-11-08 22:16:57,001 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-11-08 22:16:57,001 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-11-08 22:16:57,001 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-11-08 22:16:57,087 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-11-08 22:16:57,087 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-11-08 22:16:57,087 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-11-08 22:16:57,198 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-08 22:16:57,199 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.220.198.109
2024-11-08 22:16:57,223 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:57,224 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:57,224 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:57,318 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x00000246866D5C10>
2024-11-08 22:16:57,319 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-11-08 22:16:57,319 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-11-08 22:16:57,420 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-08 22:16:57,421 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.220.198.109
2024-11-08 22:16:57,421 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-08 22:16:57,421 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-08 22:16:57,449 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:57,449 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:57,449 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:57,550 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-11-08 22:16:57,550 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-11-08 22:16:57,550 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-11-08 22:16:57,550 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-08 22:16:57,550 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-08 22:16:57,583 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:57,584 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:57,584 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:57,651 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 1b12622c-d996-40ca-8809-c99084b1fd89
2024-11-08 22:16:57,709 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.20508 for app 73e72ada57b7480280f7a6f4a289729f
2024-11-08 22:16:57,709 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-11-08 22:16:57,819 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6e0a1a79752ef660772ace2159de0cd62421bc39 detected on system skipping install.
2024-11-08 22:16:57,825 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-11-08 22:16:57,839 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-11-08 22:16:57,839 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-11-08 22:16:57,908 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-11-08 22:16:57,910 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b2b9c93fb007354925e122f37ad1eea2d425a627
2024-11-08 22:16:57,910 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b2b9c93fb007354925e122f37ad1eea2d425a627.js...
2024-11-08 22:16:57,945 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:57,945 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:57,945 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,059 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/eb2a0d7a224047e7cb032adeb46bcfd367fc39c0.ta... for package b2b9c93fb007354925e122f37ad1eea2d425a627
2024-11-08 22:16:58,060 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 58cbc2e9a18d1cb630cee6651a5435c9cece1ba9
2024-11-08 22:16:58,075 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/58cbc2e9a18d1cb630cee6651a5435c9cece1ba9.js...
2024-11-08 22:16:58,109 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,109 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,109 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,127 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,127 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,127 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,221 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/67d3f9c22308145bbdc2796c33c582e46e6fa547.ta... for package 58cbc2e9a18d1cb630cee6651a5435c9cece1ba9
2024-11-08 22:16:58,222 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e609460608a2a3931a4a3c6994fd6d6ce931ae76
2024-11-08 22:16:58,222 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e609460608a2a3931a4a3c6994fd6d6ce931ae76.js...
2024-11-08 22:16:58,264 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,280 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:58,280 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,283 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,284 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,284 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,284 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,285 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path does not exist. Creating
2024-11-08 22:16:58,431 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:58,449 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/71b943edd96eba7c06e0562aba13b08c55e0f76b.ta... for package e609460608a2a3931a4a3c6994fd6d6ce931ae76
2024-11-08 22:16:58,450 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4a1a618b81269d20864dceb8c0dd39a361b32248
2024-11-08 22:16:58,450 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4a1a618b81269d20864dceb8c0dd39a361b32248.js...
2024-11-08 22:16:58,501 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,502 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,502 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,504 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,505 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,505 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,801 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:58,803 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/674fe624582cd3fb33f6f42dc0d109f6e2d63809.ta... for package 4a1a618b81269d20864dceb8c0dd39a361b32248
2024-11-08 22:16:58,803 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 06d9ffbce2cebe881ff46f2889b1760731b336fe
2024-11-08 22:16:58,807 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/06d9ffbce2cebe881ff46f2889b1760731b336fe.js...
2024-11-08 22:16:58,838 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,855 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:58,856 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,857 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:58,857 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:58,860 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,236 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3c772b8e350ffb3b6898a049ec348e3648d39d18
2024-11-08 22:16:59,236 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3c772b8e350ffb3b6898a049ec348e3648d39d18.js...
2024-11-08 22:16:59,271 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:59,273 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,275 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,275 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,492 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 87a95511cb6e7f530394c97273570b8878b29690
2024-11-08 22:16:59,492 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/87a95511cb6e7f530394c97273570b8878b29690.js...
2024-11-08 22:16:59,531 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,532 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,532 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,567 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:16:59,570 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c95c02d27eca6c012843d7a2161810d7ace9846b.ta... for package 06d9ffbce2cebe881ff46f2889b1760731b336fe
2024-11-08 22:16:59,608 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,609 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,609 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,639 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e8aeadf67225e88985ede819c4c239889ba93839
2024-11-08 22:16:59,639 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e8aeadf67225e88985ede819c4c239889ba93839.js...
2024-11-08 22:16:59,668 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,669 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,669 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,685 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:16:59,686 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/53bd7ef67dcc8b793910fbb5ecbdfbd243448caa.ta... for package 3c772b8e350ffb3b6898a049ec348e3648d39d18
2024-11-08 22:16:59,731 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,731 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,731 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:16:59,814 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:59,828 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: d41ccd99467b9e16bbc1b84e05d3a6ac85c1fd58
2024-11-08 22:16:59,828 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/d41ccd99467b9e16bbc1b84e05d3a6ac85c1fd58.js...
2024-11-08 22:16:59,858 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:16:59,861 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:16:59,861 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:16:59,861 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,062 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4851d8f0becc123ec744ccbcf8a2df736a547cca
2024-11-08 22:17:00,063 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4851d8f0becc123ec744ccbcf8a2df736a547cca.js...
2024-11-08 22:17:00,104 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,104 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,105 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,120 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:00,121 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0a471296987a4ef20cf60395595afdd624eccb05.ta... for package 87a95511cb6e7f530394c97273570b8878b29690
2024-11-08 22:17:00,169 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,170 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,170 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,287 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:00,288 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/431953383ee6564c6a23e70d04d63d34ed14fb1a.ta... for package e8aeadf67225e88985ede819c4c239889ba93839
2024-11-08 22:17:00,330 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,330 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,331 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,433 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cc51ec1908bf1ad1c1885ba2ac3adf5cd738a6a4
2024-11-08 22:17:00,433 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cc51ec1908bf1ad1c1885ba2ac3adf5cd738a6a4.js...
2024-11-08 22:17:00,457 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,457 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,457 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,613 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:00,616 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:00,691 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4dada2f0763ceead3c52b0303c8b89259d509437
2024-11-08 22:17:00,692 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4dada2f0763ceead3c52b0303c8b89259d509437.js...
2024-11-08 22:17:00,769 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,769 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,769 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:00,951 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: f29d564ca85cace42f9aff4bcf1eb63353bbedef
2024-11-08 22:17:00,951 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/f29d564ca85cace42f9aff4bcf1eb63353bbedef.js...
2024-11-08 22:17:00,991 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:00,991 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:00,991 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:01,250 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dd25f34f219c13b18d9facc963806b3f192ac2ce
2024-11-08 22:17:01,251 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dd25f34f219c13b18d9facc963806b3f192ac2ce.js...
2024-11-08 22:17:01,275 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:01,275 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:01,275 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:01,609 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b0642492ee964376dc3ee9053bcdcaeee8de336c
2024-11-08 22:17:01,609 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b0642492ee964376dc3ee9053bcdcaeee8de336c.js...
2024-11-08 22:17:01,639 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:01,639 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:01,639 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:01,950 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 53e5efc2a2f89573f72de491b2ea89c0ef758d0c
2024-11-08 22:17:01,950 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/53e5efc2a2f89573f72de491b2ea89c0ef758d0c.js...
2024-11-08 22:17:01,978 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:01,978 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:01,978 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:02,320 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 08b2b271ae5e7cb2c8e7bc2a4b3e46da9bdf93b3
2024-11-08 22:17:02,320 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/08b2b271ae5e7cb2c8e7bc2a4b3e46da9bdf93b3.js...
2024-11-08 22:17:02,344 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:02,344 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:02,344 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:02,615 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3cef5a8e8d43137f29d279ec3ff032e8e356fad4
2024-11-08 22:17:02,615 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3cef5a8e8d43137f29d279ec3ff032e8e356fad4.js...
2024-11-08 22:17:02,652 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:02,653 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:02,653 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,036 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: b45fcfba832205c5837259fb746dd0844b1d7f29
2024-11-08 22:17:03,036 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/b45fcfba832205c5837259fb746dd0844b1d7f29.js...
2024-11-08 22:17:03,069 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,074 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,074 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,189 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 6806f66669e78f23ca79ca629bdbaed11dd6a720
2024-11-08 22:17:03,191 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/6806f66669e78f23ca79ca629bdbaed11dd6a720.js...
2024-11-08 22:17:03,237 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,238 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,238 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,382 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 4c0c71306f9dd80820c4583178b67793ae8771ff
2024-11-08 22:17:03,382 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/4c0c71306f9dd80820c4583178b67793ae8771ff.js...
2024-11-08 22:17:03,417 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,418 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,420 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,607 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 327b6695b7a54ab14182022b53e2f70be18b0e8f
2024-11-08 22:17:03,607 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/327b6695b7a54ab14182022b53e2f70be18b0e8f.js...
2024-11-08 22:17:03,643 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,643 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,644 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,649 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:03,650 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2200ff07dde0e8ccea85c25d8e7588f9aa79599b.ta... for package d41ccd99467b9e16bbc1b84e05d3a6ac85c1fd58
2024-11-08 22:17:03,676 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,677 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,677 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:03,817 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 673ed1caf2e099120678ca9963fc90ba883d0c23
2024-11-08 22:17:03,817 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/673ed1caf2e099120678ca9963fc90ba883d0c23.js...
2024-11-08 22:17:03,842 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:03,843 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:03,843 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:03,844 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,113 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 72d099ecbffba8eb1d4304281e3d79ea85f7e7fa
2024-11-08 22:17:04,113 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/72d099ecbffba8eb1d4304281e3d79ea85f7e7fa.js...
2024-11-08 22:17:04,140 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,141 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,141 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,247 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:04,248 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/dba5ce93a5a6b701cf2d6b77f97090511db54ac7.ta... for package 4851d8f0becc123ec744ccbcf8a2df736a547cca
2024-11-08 22:17:04,286 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,286 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,286 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,342 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c93c674fb2c188d1c236a7fac26eb1dc25543de7
2024-11-08 22:17:04,343 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c93c674fb2c188d1c236a7fac26eb1dc25543de7.js...
2024-11-08 22:17:04,382 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,383 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,383 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,522 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:04,649 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 946fe838d6042c8fafb5e63a3e000062a95a6657
2024-11-08 22:17:04,650 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/946fe838d6042c8fafb5e63a3e000062a95a6657.js...
2024-11-08 22:17:04,687 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,688 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,690 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,791 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:04,794 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/8dc6fb2c50b709b3b94dead1b9d85c3ef965e846.ta... for package cc51ec1908bf1ad1c1885ba2ac3adf5cd738a6a4
2024-11-08 22:17:04,833 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,834 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,834 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:04,962 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 12201b53ca9d5f71865b656a382020ff680f7d87
2024-11-08 22:17:04,962 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/12201b53ca9d5f71865b656a382020ff680f7d87.js...
2024-11-08 22:17:04,989 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:04,989 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:04,989 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:05,133 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:05,221 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:05,222 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/fb3bbaa323ad23f25c307537eca451dec5466772.ta... for package 4dada2f0763ceead3c52b0303c8b89259d509437
2024-11-08 22:17:05,268 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:05,269 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:05,269 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:05,315 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a578efe195008f39540001e7a721188fd26539ca
2024-11-08 22:17:05,315 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a578efe195008f39540001e7a721188fd26539ca.js...
2024-11-08 22:17:05,339 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:05,339 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:05,339 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:05,397 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:05,558 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: eb5496cfef22efa775bf870006963d0a6022334e
2024-11-08 22:17:05,558 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/eb5496cfef22efa775bf870006963d0a6022334e.js...
2024-11-08 22:17:05,582 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:05,583 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:05,583 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:05,857 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5d284f95b23152d5a3df4797030c60845022f4ed
2024-11-08 22:17:05,858 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5d284f95b23152d5a3df4797030c60845022f4ed.js...
2024-11-08 22:17:05,882 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:05,883 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:05,884 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:05,981 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 77cb03243c6e65d9bae0db7fb15faf9895e7b1db
2024-11-08 22:17:05,982 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/77cb03243c6e65d9bae0db7fb15faf9895e7b1db.js...
2024-11-08 22:17:06,006 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,007 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,007 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,078 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:06,079 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/af2d174d7556aafca22dfba1b2d0c0a62c7c273d.ta... for package f29d564ca85cace42f9aff4bcf1eb63353bbedef
2024-11-08 22:17:06,115 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,116 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 653167bec0be4c57b65b642c0df857589468b5b5
2024-11-08 22:17:06,116 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,118 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/653167bec0be4c57b65b642c0df857589468b5b5.js...
2024-11-08 22:17:06,118 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,142 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,143 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,145 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,266 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:06,266 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/66fe473178c1977fe51eef46df9ad7728cd7de22.ta... for package dd25f34f219c13b18d9facc963806b3f192ac2ce
2024-11-08 22:17:06,295 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,296 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,296 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,332 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 100cccaecb2d15b043c6f0eba84be691d676df5c
2024-11-08 22:17:06,332 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/100cccaecb2d15b043c6f0eba84be691d676df5c.js...
2024-11-08 22:17:06,360 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,360 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,360 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,365 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:06,440 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:06,494 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:17:06,495 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/94513c4aed27ff9bb4d184fe25c4f4358299c254.js...
2024-11-08 22:17:06,522 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,522 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,522 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:06,829 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e730a6df54fc29863a35045d8d257a7dc4c604c9
2024-11-08 22:17:06,830 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e730a6df54fc29863a35045d8d257a7dc4c604c9.js...
2024-11-08 22:17:06,853 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:06,853 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:06,853 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,111 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: bb3427cfa0279f9b56714e2de234834f6d2d595c
2024-11-08 22:17:07,111 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/bb3427cfa0279f9b56714e2de234834f6d2d595c.js...
2024-11-08 22:17:07,144 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,144 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,144 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,322 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 958575cd6562e1d7d9b6c82400b088216e021be5
2024-11-08 22:17:07,322 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/958575cd6562e1d7d9b6c82400b088216e021be5.js...
2024-11-08 22:17:07,345 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,346 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,346 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,547 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dd991cbd4d852dfe74704599715f6f2eae86916f
2024-11-08 22:17:07,548 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dd991cbd4d852dfe74704599715f6f2eae86916f.js...
2024-11-08 22:17:07,572 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,573 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,573 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,747 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 81fb200c7382d6427afab3ed8c0a0ab6b7b8645f
2024-11-08 22:17:07,747 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/81fb200c7382d6427afab3ed8c0a0ab6b7b8645f.js...
2024-11-08 22:17:07,770 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,770 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,771 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,775 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:07,776 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/eb03cf4a199bc3dc7c76ea21d0f5aa405476a3fc.ta... for package b0642492ee964376dc3ee9053bcdcaeee8de336c
2024-11-08 22:17:07,805 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,806 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,806 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,873 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9e4ecb3d2cd1024e4d85d80f83fbfa9d99209604
2024-11-08 22:17:07,875 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9e4ecb3d2cd1024e4d85d80f83fbfa9d99209604.js...
2024-11-08 22:17:07,897 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,897 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,897 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:07,902 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:07,955 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:07,955 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e26031fe6449844e3318465770621eee7f2ba65d.ta... for package 53e5efc2a2f89573f72de491b2ea89c0ef758d0c
2024-11-08 22:17:07,978 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:07,978 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:07,978 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,032 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9ff1031dbe14eabd839c1ed58a46238c3f86aeda
2024-11-08 22:17:08,032 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9ff1031dbe14eabd839c1ed58a46238c3f86aeda.js...
2024-11-08 22:17:08,058 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:08,059 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:08,059 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,120 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:08,122 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e264b7a8b40a018085dbf5603f9a616360d36b4e.ta... for package 08b2b271ae5e7cb2c8e7bc2a4b3e46da9bdf93b3
2024-11-08 22:17:08,166 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:08,169 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:08,170 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:08,170 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,200 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:17:08,201 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/dea86e05cd6bd3873063782f9cdd133e7f7349a2.js...
2024-11-08 22:17:08,225 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:08,226 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:08,226 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,336 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:08,337 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f1db5c58b69cb93bad1b4e7b599bc2eabc828b3f.ta... for package 3cef5a8e8d43137f29d279ec3ff032e8e356fad4
2024-11-08 22:17:08,371 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:08,372 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:08,372 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:08,373 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,381 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a9364f1b657e03a620fcf263f960f2697c0d1f9b
2024-11-08 22:17:08,381 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a9364f1b657e03a620fcf263f960f2697c0d1f9b.js...
2024-11-08 22:17:08,407 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:08,407 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:08,408 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:08,625 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:09,183 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: c0d66b729ed38a7271f6fb3eb47dd82c5cbb1ec7
2024-11-08 22:17:09,184 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/c0d66b729ed38a7271f6fb3eb47dd82c5cbb1ec7.js...
2024-11-08 22:17:09,221 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:09,222 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:09,222 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:09,459 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 040a2aad4cb6c93b4b912420b34fa64a1a417ead
2024-11-08 22:17:09,459 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/040a2aad4cb6c93b4b912420b34fa64a1a417ead.js...
2024-11-08 22:17:09,487 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:09,488 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:09,488 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:09,853 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:17:09,853 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e324d41e196054786bdb30087bd4f8ee816d58ee.js...
2024-11-08 22:17:09,880 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:09,880 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:09,880 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,060 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 9078114387e4ad8dce77b5a1ed32c0b39464184c
2024-11-08 22:17:10,060 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/9078114387e4ad8dce77b5a1ed32c0b39464184c.js...
2024-11-08 22:17:10,084 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,085 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,085 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,090 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:10,092 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/45063ed6753cb278186e46b831c031d91b56e467.ta... for package b45fcfba832205c5837259fb746dd0844b1d7f29
2024-11-08 22:17:10,120 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,121 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,121 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,138 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:10,139 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/1ebde3be26a6e9b8eac8b3e7c9abb2e53c29e4bf.ta... for package 6806f66669e78f23ca79ca629bdbaed11dd6a720
2024-11-08 22:17:10,167 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,168 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,168 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,203 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 5203605fcdca6672a8bf38f5bd886532d3aaa02d
2024-11-08 22:17:10,203 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/5203605fcdca6672a8bf38f5bd886532d3aaa02d.js...
2024-11-08 22:17:10,225 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,227 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,227 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,228 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:10,256 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:10,257 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/93518a894955e9ca7c728faacaeaf14afd64e64b.ta... for package 4c0c71306f9dd80820c4583178b67793ae8771ff
2024-11-08 22:17:10,285 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:10,287 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,288 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,288 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,313 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:10,316 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/81dfe51c093b644e6ce2d2f6c39d8cede1310f2b.ta... for package 327b6695b7a54ab14182022b53e2f70be18b0e8f
2024-11-08 22:17:10,361 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,362 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,362 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,365 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:17:10,365 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e951b9466a99ba5c72dd35f8ae0335b7b3af1488.js...
2024-11-08 22:17:10,389 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,389 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,389 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,413 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:10,539 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: ffd46f14c97720fa222056d1529b3c3a735c3646
2024-11-08 22:17:10,539 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/ffd46f14c97720fa222056d1529b3c3a735c3646.js...
2024-11-08 22:17:10,570 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,570 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,570 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:10,572 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:10,826 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 553f9adabc467595038b81d3cc32e8a4ca5b6566
2024-11-08 22:17:10,826 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/553f9adabc467595038b81d3cc32e8a4ca5b6566.js...
2024-11-08 22:17:10,849 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:10,849 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:10,849 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:11,101 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: cc21342311f188c785e8fe33afca5925b48a4be3
2024-11-08 22:17:11,101 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/cc21342311f188c785e8fe33afca5925b48a4be3.js...
2024-11-08 22:17:11,125 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:11,125 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:11,125 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:11,319 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e342f62b5ffd535fcf337a1eedc8076539860584
2024-11-08 22:17:11,319 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e342f62b5ffd535fcf337a1eedc8076539860584.js...
2024-11-08 22:17:11,348 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:11,349 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:11,349 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:11,583 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: e231ab7c4c396582ba77b4a22e73f3d68da0ea36
2024-11-08 22:17:11,584 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/e231ab7c4c396582ba77b4a22e73f3d68da0ea36.js...
2024-11-08 22:17:11,607 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:11,608 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:11,608 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:11,842 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: a0f24a777e8b1b7b06a7f41764c28bc32e1ed569
2024-11-08 22:17:11,842 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/a0f24a777e8b1b7b06a7f41764c28bc32e1ed569.js...
2024-11-08 22:17:11,870 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:11,871 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:11,871 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:12,104 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 69c6f1d61393be812bd24893532c1b5411342260
2024-11-08 22:17:12,105 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/69c6f1d61393be812bd24893532c1b5411342260.js...
2024-11-08 22:17:12,141 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:12,142 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:12,142 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:12,349 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 3515a03351b5465d4d7fa4e74fc63903851ea889
2024-11-08 22:17:12,349 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/3515a03351b5465d4d7fa4e74fc63903851ea889.js...
2024-11-08 22:17:12,373 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:12,373 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:12,373 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:12,647 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 181a83196687a40ee98591748309a1e672b51cfb
2024-11-08 22:17:12,647 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/181a83196687a40ee98591748309a1e672b51cfb.js...
2024-11-08 22:17:12,673 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:12,674 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:12,675 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:12,924 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 37f794abc887cb4b52d337da566abb00e08ad60c
2024-11-08 22:17:12,925 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/37f794abc887cb4b52d337da566abb00e08ad60c.js...
2024-11-08 22:17:12,956 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:12,956 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:12,957 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:13,783 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-08 22:17:13,783 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/07efb585d4f6fba907e5f04825eeaaddeed49dae.js...
2024-11-08 22:17:13,818 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:13,818 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:13,819 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:14,445 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-11-08 22:17:14,470 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b2b9c93fb007354925e122f37ad1eea2d425a627
2024-11-08 22:17:14,673 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 58cbc2e9a18d1cb630cee6651a5435c9cece1ba9
2024-11-08 22:17:14,919 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e609460608a2a3931a4a3c6994fd6d6ce931ae76
2024-11-08 22:17:14,972 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4a1a618b81269d20864dceb8c0dd39a361b32248
2024-11-08 22:17:15,032 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 06d9ffbce2cebe881ff46f2889b1760731b336fe
2024-11-08 22:17:15,177 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3c772b8e350ffb3b6898a049ec348e3648d39d18
2024-11-08 22:17:15,230 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 87a95511cb6e7f530394c97273570b8878b29690
2024-11-08 22:17:15,314 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e8aeadf67225e88985ede819c4c239889ba93839
2024-11-08 22:17:15,516 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for d41ccd99467b9e16bbc1b84e05d3a6ac85c1fd58
2024-11-08 22:17:15,647 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4851d8f0becc123ec744ccbcf8a2df736a547cca
2024-11-08 22:17:15,782 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cc51ec1908bf1ad1c1885ba2ac3adf5cd738a6a4
2024-11-08 22:17:15,893 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4dada2f0763ceead3c52b0303c8b89259d509437
2024-11-08 22:17:16,034 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for f29d564ca85cace42f9aff4bcf1eb63353bbedef
2024-11-08 22:17:16,174 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dd25f34f219c13b18d9facc963806b3f192ac2ce
2024-11-08 22:17:16,344 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b0642492ee964376dc3ee9053bcdcaeee8de336c
2024-11-08 22:17:16,485 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 53e5efc2a2f89573f72de491b2ea89c0ef758d0c
2024-11-08 22:17:16,598 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 08b2b271ae5e7cb2c8e7bc2a4b3e46da9bdf93b3
2024-11-08 22:17:16,716 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3cef5a8e8d43137f29d279ec3ff032e8e356fad4
2024-11-08 22:17:19,923 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:19,928 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/ee8d52ae2c3d1ecad89d609256e3aefa22fb8410.ta... for package 673ed1caf2e099120678ca9963fc90ba883d0c23
2024-11-08 22:17:19,971 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:19,971 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:19,971 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:20,265 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:20,339 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:20,340 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a7897576b62dc9331e3c1acc8fdf3eae0ddc0bd7.ta... for package 72d099ecbffba8eb1d4304281e3d79ea85f7e7fa
2024-11-08 22:17:20,375 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:20,375 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:20,376 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:20,643 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:28,314 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:28,318 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c6ad6b49d760bba196427df93e8bde58e646b1c5.ta... for package c93c674fb2c188d1c236a7fac26eb1dc25543de7
2024-11-08 22:17:28,364 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:28,364 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:28,364 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:28,471 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:28,654 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:28,654 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/986ba7d0e2304496aaff24e812b563f2fc6b15eb.ta... for package 946fe838d6042c8fafb5e63a3e000062a95a6657
2024-11-08 22:17:28,687 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:28,688 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:28,689 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:28,846 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:33,547 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:33,550 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/86afe36feb639030044bbb92f49e75534be17b2c.ta... for package 12201b53ca9d5f71865b656a382020ff680f7d87
2024-11-08 22:17:33,582 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:33,583 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:33,583 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:33,601 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for b45fcfba832205c5837259fb746dd0844b1d7f29
2024-11-08 22:17:33,691 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:33,945 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 6806f66669e78f23ca79ca629bdbaed11dd6a720
2024-11-08 22:17:33,952 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:33,953 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/991a12528d484ca2cb19c0a7cd527d9532bdafee.ta... for package a578efe195008f39540001e7a721188fd26539ca
2024-11-08 22:17:33,991 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:33,992 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:33,993 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:34,106 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:34,233 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:34,235 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/eba00fd61aed6730c9bf7e87fe68421a1e8646b1.ta... for package eb5496cfef22efa775bf870006963d0a6022334e
2024-11-08 22:17:34,264 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:34,265 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:34,265 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:34,376 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:34,712 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:34,713 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/4d4071205ae064a463ce497483f9bb479ef8138a.ta... for package 5d284f95b23152d5a3df4797030c60845022f4ed
2024-11-08 22:17:34,743 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:34,744 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:34,744 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:34,890 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:36,841 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:36,843 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/21f720c959966d967c12f15ac0124d1fbc247d85.ta... for package 77cb03243c6e65d9bae0db7fb15faf9895e7b1db
2024-11-08 22:17:36,883 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:36,883 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:36,883 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:37,006 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:38,345 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:38,347 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/f7c2d65bbf343f2ee436e6c11deb012c9b13c90d.ta... for package 653167bec0be4c57b65b642c0df857589468b5b5
2024-11-08 22:17:38,388 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:38,388 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:38,388 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:38,532 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:38,770 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:38,771 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/5ec0c9ae161fc57915a785f38fcc7e69e9db1b4a.ta... for package 100cccaecb2d15b043c6f0eba84be691d676df5c
2024-11-08 22:17:38,799 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:38,800 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:38,800 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:38,884 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:39,177 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:39,178 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/af6a706c079dd545bc77a15f47fb8f5e45cb444b.ta... for package 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:17:39,212 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:39,212 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:39,212 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:39,367 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:40,106 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:40,114 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/690185d579caed680863488e576c0909343d3c5e.ta... for package 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:17:40,159 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:40,159 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:40,159 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:40,533 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:43,427 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:43,430 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/621d86a3581c3a06e6eca6362df02a122367f38f.ta... for package e730a6df54fc29863a35045d8d257a7dc4c604c9
2024-11-08 22:17:43,458 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:43,458 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:43,459 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:43,560 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:43,732 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:43,733 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/78824313f4a9c96e0175a5039382dd3a938877a0.ta... for package bb3427cfa0279f9b56714e2de234834f6d2d595c
2024-11-08 22:17:43,760 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:43,761 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:43,761 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:44,238 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:54,333 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:54,336 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/62016853fa42004ac891bf52bfc9311dbe308cc4.ta... for package 958575cd6562e1d7d9b6c82400b088216e021be5
2024-11-08 22:17:54,361 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:54,361 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:54,361 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:54,365 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 4c0c71306f9dd80820c4583178b67793ae8771ff
2024-11-08 22:17:54,451 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 327b6695b7a54ab14182022b53e2f70be18b0e8f
2024-11-08 22:17:54,721 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 673ed1caf2e099120678ca9963fc90ba883d0c23
2024-11-08 22:17:54,788 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 72d099ecbffba8eb1d4304281e3d79ea85f7e7fa
2024-11-08 22:17:54,847 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c93c674fb2c188d1c236a7fac26eb1dc25543de7
2024-11-08 22:17:54,900 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 946fe838d6042c8fafb5e63a3e000062a95a6657
2024-11-08 22:17:54,973 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:17:55,014 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 12201b53ca9d5f71865b656a382020ff680f7d87
2024-11-08 22:17:55,071 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a578efe195008f39540001e7a721188fd26539ca
2024-11-08 22:17:56,380 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:17:56,381 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2d6abff6d658cb5d7cbd11eb30e54c7690bbdd76.ta... for package dd991cbd4d852dfe74704599715f6f2eae86916f
2024-11-08 22:17:56,410 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:17:56,411 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:17:56,411 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:17:56,511 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:18:18,574 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:18:18,577 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0344986429cea43c456f0eba5168dc01cf816dd4.ta... for package 81fb200c7382d6427afab3ed8c0a0ab6b7b8645f
2024-11-08 22:18:18,600 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:18:18,600 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:18:18,600 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:18:20,065 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:18:40,859 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:18:40,862 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d10c6ee3b9acfd1c498a55675faf2ed9686ae056.ta... for package 9e4ecb3d2cd1024e4d85d80f83fbfa9d99209604
2024-11-08 22:18:40,893 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:18:40,893 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:18:40,893 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:18:41,174 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:18:57,380 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:18:57,383 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/7d6a4c1f492f13e8dae58167ca861309e3b1dc16.ta... for package 9ff1031dbe14eabd839c1ed58a46238c3f86aeda
2024-11-08 22:18:57,384 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package eb5496cfef22efa775bf870006963d0a6022334e
2024-11-08 22:18:57,385 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 7facf0de95414ab9b6315d8fa534bf91(Unknown) was not in registry
2024-11-08 22:18:57,385 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action a92c95fa064f43089136f50437f73d22(Unknown) was not in registry
2024-11-08 22:18:57,401 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package eb5496cfef22efa775bf870006963d0a6022334e
2024-11-08 22:18:57,421 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:18:57,421 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:18:57,422 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:18:57,454 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for eb5496cfef22efa775bf870006963d0a6022334e
2024-11-08 22:18:57,693 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5d284f95b23152d5a3df4797030c60845022f4ed
2024-11-08 22:18:57,771 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:18:57,915 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 77cb03243c6e65d9bae0db7fb15faf9895e7b1db
2024-11-08 22:18:58,075 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 653167bec0be4c57b65b642c0df857589468b5b5
2024-11-08 22:18:58,236 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 100cccaecb2d15b043c6f0eba84be691d676df5c
2024-11-08 22:18:58,968 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:18:58,973 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/9332901653b5700f170a4dc855a30a4fa2ebd414.ta... for package dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:18:58,998 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:18:58,999 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:18:58,999 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:18:59,400 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:01,146 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:01,148 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c7d92b5b0460809d9cbbb831ce5ba7075d003000.ta... for package dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:19:01,180 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:01,180 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:01,180 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:01,586 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:01,738 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:01,739 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/95ed5de8b132937c8fcf45bbc49717e49869179b.ta... for package a9364f1b657e03a620fcf263f960f2697c0d1f9b
2024-11-08 22:19:01,765 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:01,765 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:01,766 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:02,061 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:02,354 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:02,357 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c94412f95ba272431980c61789b7af647d0c114e.ta... for package c0d66b729ed38a7271f6fb3eb47dd82c5cbb1ec7
2024-11-08 22:19:02,397 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:02,398 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:02,399 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:02,572 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:04,112 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:04,114 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b151e9743f11a4f758df9cb291a2d07cdd0c764f.ta... for package 040a2aad4cb6c93b4b912420b34fa64a1a417ead
2024-11-08 22:19:04,155 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:04,156 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:04,156 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:04,397 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:05,295 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:05,296 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/011ac92c1d17e72880ed4a41fcd975b989752bd3.ta... for package e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:19:05,336 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:05,336 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:05,337 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:05,466 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:12,120 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:12,122 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/cf26d17bb7571baed1384ec6559b7418e284b47d.ta... for package e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:19:12,147 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:12,148 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:12,148 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:12,541 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:14,693 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:14,695 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/14c6b1b8f679be91add36fa38c297fec787ad28f.ta... for package 9078114387e4ad8dce77b5a1ed32c0b39464184c
2024-11-08 22:19:14,719 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:14,720 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:14,720 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:14,944 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:18,291 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:18,294 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/810672b516a5c8d3544c41901a979f638631b28d.ta... for package 5203605fcdca6672a8bf38f5bd886532d3aaa02d
2024-11-08 22:19:18,327 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:18,327 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:18,328 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:18,662 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:18,906 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:18,906 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c410dbeaebe9672613becc536c397671d9136084.ta... for package e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:19:18,946 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:18,947 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:18,947 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:19,082 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:20,021 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:20,030 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/2ea8058636953646e3523331386153ffbf3894ea.ta... for package e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:19:20,031 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:19:20,031 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-11-08 22:19:20,032 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5c461fa5ff6ec38afa078cf537137159(ADD_REGISTRY_INFO)
2024-11-08 22:19:20,101 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:20,101 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:20,102 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:20,270 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:20,947 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:20,948 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e10ba0adfd42d8c13b5ccc880cabb1923b719f5e.ta... for package ffd46f14c97720fa222056d1529b3c3a735c3646
2024-11-08 22:19:20,987 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:20,989 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:20,989 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:21,119 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:21,278 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:21,279 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/a01448ca8df06a8be244f85ce9a55fba81afb406.ta... for package 553f9adabc467595038b81d3cc32e8a4ca5b6566
2024-11-08 22:19:21,329 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:21,329 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:21,330 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:21,454 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:21,878 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:21,879 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/851527b566cde68a7f70ed1ec74cccc3e83a5da0.ta... for package cc21342311f188c785e8fe33afca5925b48a4be3
2024-11-08 22:19:21,908 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:21,909 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:21,910 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:21,958 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1f397ebf8d2a4ca9befc3072340f035e(FILESYSTEM_ACTIONS)
2024-11-08 22:19:21,959 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-11-08 22:19:21,959 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action 36d909d4c5304fc2a6a47bbb9116f50e(REMOVE_STREAMING_SESSION) was not in registry
2024-11-08 22:19:21,960 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:19:22,010 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 94513c4aed27ff9bb4d184fe25c4f4358299c254
2024-11-08 22:19:22,065 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:25,825 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e730a6df54fc29863a35045d8d257a7dc4c604c9
2024-11-08 22:19:26,012 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for bb3427cfa0279f9b56714e2de234834f6d2d595c
2024-11-08 22:19:32,922 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 958575cd6562e1d7d9b6c82400b088216e021be5
2024-11-08 22:19:33,167 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dd991cbd4d852dfe74704599715f6f2eae86916f
2024-11-08 22:19:36,677 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 81fb200c7382d6427afab3ed8c0a0ab6b7b8645f
2024-11-08 22:19:38,668 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:38,674 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/0005c407e22873f877214a44be0613eda53a91ec.ta... for package cc21342311f188c785e8fe33afca5925b48a4be3
2024-11-08 22:19:38,707 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:38,707 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:38,708 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:38,991 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:39,887 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:39,888 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/20ec9d9b849ad77326608d382f05bfc8ee2ecfc8.ta... for package e342f62b5ffd535fcf337a1eedc8076539860584
2024-11-08 22:19:39,920 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:39,921 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:39,921 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:40,247 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:47,577 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:47,579 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b23fa21c1355e9b365829338bed7d59113c35831.ta... for package e231ab7c4c396582ba77b4a22e73f3d68da0ea36
2024-11-08 22:19:47,603 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:47,603 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:47,604 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:47,980 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:53,361 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:53,362 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/6347764c1cfc036b054282a9103ed0610c21465d.ta... for package e231ab7c4c396582ba77b4a22e73f3d68da0ea36
2024-11-08 22:19:53,388 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:53,388 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:53,388 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:53,689 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:53,902 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:53,903 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/c0b37f72057806696c7e7c9d422557f66d77a7a9.ta... for package a0f24a777e8b1b7b06a7f41764c28bc32e1ed569
2024-11-08 22:19:53,928 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:53,929 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:53,929 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:54,184 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:54,561 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:54,561 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/162f3917601655f469f4d130ffc7df790442fc65.ta... for package 69c6f1d61393be812bd24893532c1b5411342260
2024-11-08 22:19:54,589 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:54,590 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:54,592 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:54,869 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:19:56,555 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:19:56,557 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/333728eca9bcb530a470f22a9b1c5863cf7871c1.ta... for package 3515a03351b5465d4d7fa4e74fc63903851ea889
2024-11-08 22:19:56,592 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:19:56,592 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:19:56,593 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:19:57,243 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:00,834 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:00,838 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/eec5343baae8af2cf46642d844df7000c5ee9b9c.ta... for package 181a83196687a40ee98591748309a1e672b51cfb
2024-11-08 22:20:00,877 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:20:00,878 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:20:00,879 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:20:01,203 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:04,342 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:04,343 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/07fca93ddc19596cb24c822dac83ce16fcfe3584.ta... for package 181a83196687a40ee98591748309a1e672b51cfb
2024-11-08 22:20:04,370 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:20:04,371 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:20:04,371 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:20:05,099 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:05,251 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:05,251 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/b635bb5392c80922d451e79462c163e02a20e017.ta... for package 37f794abc887cb4b52d337da566abb00e08ad60c
2024-11-08 22:20:05,283 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:20:05,283 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:20:05,284 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:20:05,640 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:05,783 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:05,783 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d98aed25a57f9b76163c1ff67b98d0178d4c2799.ta... for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-08 22:20:05,815 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:20:05,816 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:20:05,816 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:20:06,073 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:13,273 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:13,277 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e1180c1f20b0d8fff05408205b5891ea30c70b63.ta... for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-08 22:20:13,306 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:20:13,306 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:20:13,306 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:20:13,644 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-08 22:20:16,474 - MainProcess(37940) - ThreadPoolExecutor-1_3 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:20:26,702 - MainProcess(37940) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:21:10,075 - MainProcess(37940) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:23:00,828 - MainProcess(37940) - ThreadPoolExecutor-1_4 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-08 22:23:00,838 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9e4ecb3d2cd1024e4d85d80f83fbfa9d99209604
2024-11-08 22:23:02,372 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9ff1031dbe14eabd839c1ed58a46238c3f86aeda
2024-11-08 22:23:02,447 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:23:02,448 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-11-08 22:23:02,448 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:23:02,449 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for dea86e05cd6bd3873063782f9cdd133e7f7349a2
2024-11-08 22:23:02,532 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a9364f1b657e03a620fcf263f960f2697c0d1f9b
2024-11-08 22:23:02,603 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for c0d66b729ed38a7271f6fb3eb47dd82c5cbb1ec7
2024-11-08 22:23:02,673 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 040a2aad4cb6c93b4b912420b34fa64a1a417ead
2024-11-08 22:23:02,740 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:23:02,740 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 31e0f47eabdd436bb829e0c65acf67ba(CREATE_PACKAGE_LINK)
2024-11-08 22:23:02,740 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-11-08 22:23:02,740 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\streamingsession.json
2024-11-08 22:23:02,755 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform postdeploy tasks for package e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:23:02,756 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e324d41e196054786bdb30087bd4f8ee816d58ee
2024-11-08 22:23:02,843 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 9078114387e4ad8dce77b5a1ed32c0b39464184c
2024-11-08 22:23:02,967 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 5203605fcdca6672a8bf38f5bd886532d3aaa02d
2024-11-08 22:23:03,039 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform predeploy tasks for package e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:23:03,039 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action a9cdc10b1ed64039b7dfd3bf8a0dcd5e(REMOVE_WININSTALLER_PRODUCT)
2024-11-08 22:23:03,207 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {CD2A85EC-C80D-4CAC-01C1-FCCDE4A651C8}. Msiexec returns 1605
2024-11-08 22:23:03,287 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - WARNING :: Failed to remove windows installer product {0188C9F4-CCDE-41E9-0150-6B1CFC6AC596}. Msiexec returns 1605
2024-11-08 22:23:03,287 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Complete perform predeploy tasks for package e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:23:03,288 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e951b9466a99ba5c72dd35f8ae0335b7b3af1488
2024-11-08 22:23:03,485 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for ffd46f14c97720fa222056d1529b3c3a735c3646
2024-11-08 22:23:03,554 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 553f9adabc467595038b81d3cc32e8a4ca5b6566
2024-11-08 22:23:03,636 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for cc21342311f188c785e8fe33afca5925b48a4be3
2024-11-08 22:23:04,006 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e342f62b5ffd535fcf337a1eedc8076539860584
2024-11-08 22:23:04,081 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for e231ab7c4c396582ba77b4a22e73f3d68da0ea36
2024-11-08 22:23:04,197 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for a0f24a777e8b1b7b06a7f41764c28bc32e1ed569
2024-11-08 22:23:04,264 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 69c6f1d61393be812bd24893532c1b5411342260
2024-11-08 22:23:04,342 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 3515a03351b5465d4d7fa4e74fc63903851ea889
2024-11-08 22:23:04,423 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 181a83196687a40ee98591748309a1e672b51cfb
2024-11-08 22:23:04,509 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Recording files in registry for 37f794abc887cb4b52d337da566abb00e08ad60c
2024-11-08 22:23:04,586 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-08 22:23:04,586 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-11-08 22:23:04,590 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-11-08 22:23:04,590 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-11-08 22:23:04,590 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\streamingsession.json
2024-11-08 22:23:04,603 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-11-08 22:23:04,628 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\ApplicationOptions.production.json as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Fusion 360.server.config
2024-11-08 22:23:04,629 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-08 22:23:04,655 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\AdpSDKGlobal.config
2024-11-08 22:23:04,655 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-08 22:23:04,677 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\adpdesktopsdk.env
2024-11-08 22:23:04,677 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-08 22:23:04,679 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-11-08 22:23:04,681 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-11-08 22:23:04,692 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-11-08 22:23:04,692 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-11-08 22:23:04,718 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-08 22:23:04,718 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-08 22:23:04,718 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-08 22:23:04,935 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is dc6b08e1d950877a98c82379d1b58238:1730394818.15428
2024-11-08 22:23:04,935 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-11-08 22:23:04,935 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'dc6b08e1d950877a98c82379d1b58238:1730394818.15428' to option 'ETag'
2024-11-08 22:23:04,935 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-11-08 22:23:04,937 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-11-08 22:23:04,971 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-08 22:23:04,972 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-11-08 22:23:04,972 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-11-08 22:23:04,979 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,979 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=1688849860681666, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1730350706, st_mtime=1729257584, st_ctime=1729426013)
2024-11-08 22:23:04,980 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-11-08 22:23:04,982 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,982 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=844424930549699, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1729603485, st_mtime=1729257651, st_ctime=1729426013)
2024-11-08 22:23:04,982 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-11-08 22:23:04,985 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,986 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=844424930549700, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1729603485, st_mtime=1729257651, st_ctime=1729426013)
2024-11-08 22:23:04,987 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-11-08 22:23:04,989 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,989 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=844424930549701, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1729603485, st_mtime=1729257651, st_ctime=1729426013)
2024-11-08 22:23:04,990 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-11-08 22:23:04,993 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,993 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=844424930549702, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1729603485, st_mtime=1729257651, st_ctime=1729426013)
2024-11-08 22:23:04,994 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-11-08 22:23:04,998 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-08 22:23:04,999 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=844424930549703, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1729603485, st_mtime=1729257651, st_ctime=1729426013)
2024-11-08 22:23:04,999 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-11-08 22:23:05,004 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-11-08 22:23:05,004 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-11-08 22:23:05,007 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-11-08 22:23:05,009 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-11-08 22:23:05,010 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-11-08 22:23:05,011 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-11-08 22:23:05,011 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-11-08 22:23:05,012 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-11-08 22:23:05,018 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-11-08 22:23:05,018 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-08 22:23:05,018 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-08 22:23:05,018 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-08 22:23:05,093 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-08 22:23:05,094 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-08 22:23:05,095 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-11-08 22:23:05,112 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-08 22:23:05,112 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-11-08 22:23:05,122 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-08 22:23:05,122 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-11-08 22:23:05,132 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-08 22:23:05,133 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-08 22:23:05,133 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-08 22:23:05,133 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-08 22:23:05,133 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-08 22:23:06,846 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-08 22:23:06,847 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-08 22:23:06,847 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-08 22:23:06,847 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-08 22:23:06,847 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-08 22:23:06,867 - MainProcess(37940) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 07efb585d4f6fba907e5f04825eeaaddeed49dae:
2024-11-08 22:23:07,010 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-11-08 22:23:07,011 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMjIwLjE5OC4xMDk=
2024-11-08 22:23:07,011 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-11-08 22:23:08,240 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get local dns 'utf-8' codec can't decode byte 0xa6 in position 0: invalid start byte.
2024-11-08 22:23:08,240 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS:
2024-11-08 22:23:08,241 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-11-08 22:23:08,241 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1160, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 92, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1091, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 909, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 1869, in _do_installation
File "R:\src\adsk\dls\streamer\process\process.py", line 1630, in wait_threads
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\concurrent\futures\thread.py", line 52, in run
File "R:\src\adsk\dls\streamer\process\process.py", line 1750, in execute_tasks
File "R:\src\adsk\dls\streamer\process\process.py", line 406, in _executetasks
File "R:\src\adsk\dls\streamer\windows\platform.py", line 342, in create_launch_items
File "R:\src\adsk\dls\streamer\windows\platform.py", line 441, in _manipulate_shortcuts
File "R:\src\adsk\dls\streamer\manifests.py", line 807, in walk_external_references
File "R:\src\adsk\dls\streamer\windows\platform.py", line 398, in __filevisitor
File "R:\src\adsk\dls\streamer\manifests.py", line 62, in __next__
File "R:\src\adsk\dls\streamer\manifests.py", line 44, in _manifestvalfor
File "R:\src\adsk\dls\streamer\manifests.py", line 239, in _process_template_value
File "R:\src\adsk\dls\streamer\utils.py", line 258, in __call__
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 121, in substitute
File "E:\Jenkins\3P\PYTHON\3.9.6\WIN64_1\lib\string.py", line 114, in convert
File "R:\src\adsk\dls\streamer\manifests.py", line 228, in __getitem__
File "R:\src\adsk\dls\streamer\configuration.py", line 782, in __getitem__
File "R:\src\adsk\dls\streamer\windows\platform.py", line 1993, in __getitem__
File "R:\src\adsk\dls\streamer\platform_base.py", line 104, in __getitem__
IndexError
2024-11-08 22:37:00,513 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-11-08 22:37:00,590 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Error detected, removing cache file list in 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-08 22:37:00,590 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\adpdesktopsdk.env
2024-11-08 22:37:00,592 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\adpsdkglobal.config
2024-11-08 22:37:00,669 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.utils - WARNING :: Could not remove non-existant file: \\?\c:\users\chouj\appdata\local\autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\fusion 360.server.config
2024-11-08 22:37:00,907 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy
2024-11-08 22:37:04,440 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-11-08 22:37:04,487 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-11-08 22:37:04,488 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-11-08 22:37:04,488 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-11-08 22:37:04,488 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000246FFE7B6A0> #
2024-11-08 22:37:04,489 - MainProcess(37940) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-11-11 18:58:48,494 - MainProcess(11688) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\chouj\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-11-11 18:58:48,495 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-11-11 18:58:48,495 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-11-11 18:58:48,495 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002131C6DB6A0> #
2024-11-11 18:58:48,495 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-11-11 18:58:48,496 - MainProcess(11688) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\chouj\AppData\Local\Temp\7zS9AB7.tmp\resources\buildinfo.json
2024-11-11 18:58:48,496 - MainProcess(11688) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-11-11 18:58:48,496 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20220719105500
2024-11-11 18:58:48,496 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: zh_TW
2024-11-11 18:58:48,497 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\chouj\AppData\Local\Temp\7zS9AB7.tmp\resources
2024-11-11 18:58:48,497 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\chouj\AppData\Local\Temp\7zS9AB7.tmp\certs.pem
2024-11-11 18:58:48,497 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-11-11 18:58:48,498 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-11-11 18:58:48,498 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-11-11 18:58:48,498 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000002131C6D4AF0>, operation=<function multiple_operate at 0x000002131BE173A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-11-11 18:58:48,498 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-11-11 18:58:48,498 - MainProcess(11688) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-11-11 18:58:48,499 - MainProcess(11688) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-11-11 18:58:48,499 - MainProcess(11688) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-11-11 18:58:49,059 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-11-11 18:58:49,126 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-11-11 18:58:50,111 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-11-11 18:58:50,112 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm created successfully
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\chouj\AppData\Local\Autodesk\check_perm
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\chouj\AppData\Local\Autodesk\check_perm removed successfully
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\chouj\AppData\Local\Autodesk
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-11-11 18:58:50,113 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-11-11 18:58:50,387 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-11 18:58:50,388 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.39.62.109
2024-11-11 18:58:50,388 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-11 18:58:50,388 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-11 18:58:50,413 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:50,413 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:50,413 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:50,413 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-11-11 18:58:50,413 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-11-11 18:58:50,414 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.39.62.109
2024-11-11 18:58:50,442 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-11-11 18:58:50,443 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMzkuNjIuMTA5
2024-11-11 18:58:50,443 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-11-11 18:58:50,443 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-11-11 18:58:50,443 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-11-11 18:58:50,513 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-11-11 18:58:50,513 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-11-11 18:58:50,513 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-11-11 18:58:50,594 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-11 18:58:50,595 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.39.62.109
2024-11-11 18:58:50,608 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:50,608 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:50,608 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:50,677 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000021304E05C10>
2024-11-11 18:58:50,678 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-11-11 18:58:50,678 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-11-11 18:58:50,812 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-11-11 18:58:50,813 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.39.62.109
2024-11-11 18:58:50,813 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-11 18:58:50,813 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-11 18:58:50,826 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:50,826 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:50,826 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:50,975 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-11-11 18:58:50,975 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-11-11 18:58:50,975 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-11-11 18:58:50,976 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-11-11 18:58:50,976 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-11-11 18:58:50,988 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:50,989 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:50,989 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:51,086 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 00ce09ae-26c8-409d-848a-6e0f159b79d0
2024-11-11 18:58:51,116 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.20508 for app 73e72ada57b7480280f7a6f4a289729f
2024-11-11 18:58:51,116 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-11-11 18:58:51,176 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b2b9c93fb007354925e122f37ad1eea2d425a627 detected on system skipping install.
2024-11-11 18:58:51,176 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 58cbc2e9a18d1cb630cee6651a5435c9cece1ba9 detected on system skipping install.
2024-11-11 18:58:51,177 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e609460608a2a3931a4a3c6994fd6d6ce931ae76 detected on system skipping install.
2024-11-11 18:58:51,177 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4a1a618b81269d20864dceb8c0dd39a361b32248 detected on system skipping install.
2024-11-11 18:58:51,178 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 06d9ffbce2cebe881ff46f2889b1760731b336fe detected on system skipping install.
2024-11-11 18:58:51,178 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3c772b8e350ffb3b6898a049ec348e3648d39d18 detected on system skipping install.
2024-11-11 18:58:51,179 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 87a95511cb6e7f530394c97273570b8878b29690 detected on system skipping install.
2024-11-11 18:58:51,179 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e8aeadf67225e88985ede819c4c239889ba93839 detected on system skipping install.
2024-11-11 18:58:51,180 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk d41ccd99467b9e16bbc1b84e05d3a6ac85c1fd58 detected on system skipping install.
2024-11-11 18:58:51,181 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4851d8f0becc123ec744ccbcf8a2df736a547cca detected on system skipping install.
2024-11-11 18:58:51,181 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cc51ec1908bf1ad1c1885ba2ac3adf5cd738a6a4 detected on system skipping install.
2024-11-11 18:58:51,181 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4dada2f0763ceead3c52b0303c8b89259d509437 detected on system skipping install.
2024-11-11 18:58:51,182 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk f29d564ca85cace42f9aff4bcf1eb63353bbedef detected on system skipping install.
2024-11-11 18:58:51,182 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dd25f34f219c13b18d9facc963806b3f192ac2ce detected on system skipping install.
2024-11-11 18:58:51,183 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b0642492ee964376dc3ee9053bcdcaeee8de336c detected on system skipping install.
2024-11-11 18:58:51,183 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 53e5efc2a2f89573f72de491b2ea89c0ef758d0c detected on system skipping install.
2024-11-11 18:58:51,184 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 08b2b271ae5e7cb2c8e7bc2a4b3e46da9bdf93b3 detected on system skipping install.
2024-11-11 18:58:51,184 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3cef5a8e8d43137f29d279ec3ff032e8e356fad4 detected on system skipping install.
2024-11-11 18:58:51,185 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk b45fcfba832205c5837259fb746dd0844b1d7f29 detected on system skipping install.
2024-11-11 18:58:51,185 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6806f66669e78f23ca79ca629bdbaed11dd6a720 detected on system skipping install.
2024-11-11 18:58:51,186 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 4c0c71306f9dd80820c4583178b67793ae8771ff detected on system skipping install.
2024-11-11 18:58:51,186 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 327b6695b7a54ab14182022b53e2f70be18b0e8f detected on system skipping install.
2024-11-11 18:58:51,186 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 673ed1caf2e099120678ca9963fc90ba883d0c23 detected on system skipping install.
2024-11-11 18:58:51,186 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 72d099ecbffba8eb1d4304281e3d79ea85f7e7fa detected on system skipping install.
2024-11-11 18:58:51,187 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c93c674fb2c188d1c236a7fac26eb1dc25543de7 detected on system skipping install.
2024-11-11 18:58:51,188 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 946fe838d6042c8fafb5e63a3e000062a95a6657 detected on system skipping install.
2024-11-11 18:58:51,189 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 12201b53ca9d5f71865b656a382020ff680f7d87 detected on system skipping install.
2024-11-11 18:58:51,189 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a578efe195008f39540001e7a721188fd26539ca detected on system skipping install.
2024-11-11 18:58:51,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk eb5496cfef22efa775bf870006963d0a6022334e detected on system skipping install.
2024-11-11 18:58:51,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5d284f95b23152d5a3df4797030c60845022f4ed detected on system skipping install.
2024-11-11 18:58:51,191 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 77cb03243c6e65d9bae0db7fb15faf9895e7b1db detected on system skipping install.
2024-11-11 18:58:51,191 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 653167bec0be4c57b65b642c0df857589468b5b5 detected on system skipping install.
2024-11-11 18:58:51,192 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 100cccaecb2d15b043c6f0eba84be691d676df5c detected on system skipping install.
2024-11-11 18:58:51,192 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 94513c4aed27ff9bb4d184fe25c4f4358299c254 detected on system skipping install.
2024-11-11 18:58:51,192 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 6e0a1a79752ef660772ace2159de0cd62421bc39 detected on system skipping install.
2024-11-11 18:58:51,193 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e730a6df54fc29863a35045d8d257a7dc4c604c9 detected on system skipping install.
2024-11-11 18:58:51,193 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk bb3427cfa0279f9b56714e2de234834f6d2d595c detected on system skipping install.
2024-11-11 18:58:51,194 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 958575cd6562e1d7d9b6c82400b088216e021be5 detected on system skipping install.
2024-11-11 18:58:51,194 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dd991cbd4d852dfe74704599715f6f2eae86916f detected on system skipping install.
2024-11-11 18:58:51,195 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 81fb200c7382d6427afab3ed8c0a0ab6b7b8645f detected on system skipping install.
2024-11-11 18:58:51,196 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9e4ecb3d2cd1024e4d85d80f83fbfa9d99209604 detected on system skipping install.
2024-11-11 18:58:51,196 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9ff1031dbe14eabd839c1ed58a46238c3f86aeda detected on system skipping install.
2024-11-11 18:58:51,197 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk dea86e05cd6bd3873063782f9cdd133e7f7349a2 detected on system skipping install.
2024-11-11 18:58:51,197 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cd398d360d746179da04a19fe608256034f75a64 detected on system skipping install.
2024-11-11 18:58:51,197 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a9364f1b657e03a620fcf263f960f2697c0d1f9b detected on system skipping install.
2024-11-11 18:58:51,198 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk c0d66b729ed38a7271f6fb3eb47dd82c5cbb1ec7 detected on system skipping install.
2024-11-11 18:58:51,199 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 040a2aad4cb6c93b4b912420b34fa64a1a417ead detected on system skipping install.
2024-11-11 18:58:51,199 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e324d41e196054786bdb30087bd4f8ee816d58ee detected on system skipping install.
2024-11-11 18:58:51,199 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 9078114387e4ad8dce77b5a1ed32c0b39464184c detected on system skipping install.
2024-11-11 18:58:51,200 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 5203605fcdca6672a8bf38f5bd886532d3aaa02d detected on system skipping install.
2024-11-11 18:58:51,200 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e951b9466a99ba5c72dd35f8ae0335b7b3af1488 detected on system skipping install.
2024-11-11 18:58:51,201 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk ffd46f14c97720fa222056d1529b3c3a735c3646 detected on system skipping install.
2024-11-11 18:58:51,202 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 553f9adabc467595038b81d3cc32e8a4ca5b6566 detected on system skipping install.
2024-11-11 18:58:51,202 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk cc21342311f188c785e8fe33afca5925b48a4be3 detected on system skipping install.
2024-11-11 18:58:51,203 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e342f62b5ffd535fcf337a1eedc8076539860584 detected on system skipping install.
2024-11-11 18:58:51,203 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk e231ab7c4c396582ba77b4a22e73f3d68da0ea36 detected on system skipping install.
2024-11-11 18:58:51,204 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk a0f24a777e8b1b7b06a7f41764c28bc32e1ed569 detected on system skipping install.
2024-11-11 18:58:51,205 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 69c6f1d61393be812bd24893532c1b5411342260 detected on system skipping install.
2024-11-11 18:58:51,206 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 3515a03351b5465d4d7fa4e74fc63903851ea889 detected on system skipping install.
2024-11-11 18:58:51,206 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 181a83196687a40ee98591748309a1e672b51cfb detected on system skipping install.
2024-11-11 18:58:51,207 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Package with pk 37f794abc887cb4b52d337da566abb00e08ad60c detected on system skipping install.
2024-11-11 18:58:51,207 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-11-11 18:58:51,207 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-11-11 18:58:51,243 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 1b891e3c161b456cb570ff9a05c8a9c8(INITIAL_INSTALL_DELETE_FILES)
2024-11-11 18:58:51,245 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling package manifest: 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-11 18:58:51,245 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/packages/07efb585d4f6fba907e5f04825eeaaddeed49dae.js...
2024-11-11 18:58:51,257 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:51,257 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:51,257 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:51,318 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/d98aed25a57f9b76163c1ff67b98d0178d4c2799.ta... for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-11 18:58:51,318 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Downloading archive from https://dl.appstreaming.autodesk.com/production/packages/e1180c1f20b0d8fff05408205b5891ea30c70b63.ta... for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-11 18:58:51,332 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:51,332 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Start executing tasks thread
2024-11-11 18:58:51,343 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:51,344 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:51,345 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:51,345 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:51,346 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:51,409 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-11 18:58:51,415 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: Extract path resolves to: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298
2024-11-11 18:58:52,186 - MainProcess(11688) - ThreadPoolExecutor-1_2 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-11 18:58:53,260 - MainProcess(11688) - ThreadPoolExecutor-1_1 - adsk.dls.streamer.process.process - INFO :: package installation complete
2024-11-11 18:58:53,261 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Begin perform postdeploy tasks for package 07efb585d4f6fba907e5f04825eeaaddeed49dae
2024-11-11 18:58:53,262 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action e10f096356f7470ea58e13af02d1ba7c(UPDATE_PINNABLE_LAUNCHER)
2024-11-11 18:58:53,263 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action e11b50c4e45d49c68aa944c2e476a76f(Unknown) was not in registry
2024-11-11 18:58:53,263 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action b32513729518446bbd4984e704827353(WRITE_GA_APPNAME)
2024-11-11 18:58:53,263 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Writing analytics session information to \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\streamingsession.json
2024-11-11 18:58:53,279 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 7df3ec3a7e8d40ada66494b9dc32dc4e(ACTIVATE_CONFIG)
2024-11-11 18:58:53,291 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\ApplicationOptions.production.json as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Fusion 360.server.config
2024-11-11 18:58:53,292 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-11 18:58:53,301 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\AdpSDKGlobal.production.config as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\AdpSDKGlobal.config
2024-11-11 18:58:53,301 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-11 18:58:53,310 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Activating configuration file at \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\Applications\Fusion\Fusion360App\adpdesktopsdk.production.env as \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\c4a5520f9bb0f0174c02662af8bd1ab67cee6298\adpdesktopsdk.env
2024-11-11 18:58:53,310 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: But first deleting pre-existing target
2024-11-11 18:58:53,311 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 8df63efc00a94e9aa262d921a044c83a(PROCESS_TEMPLATE)
2024-11-11 18:58:53,312 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 9a6f9239365141149849b3081dc3fd7c(WRITE_STREAMER_OPTIONS)
2024-11-11 18:58:53,318 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value '0' to option 'GlobalInstall'
2024-11-11 18:58:53,318 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Remove option 'DevBuild'
2024-11-11 18:58:53,331 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-11-11 18:58:53,331 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-11-11 18:58:53,331 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-11-11 18:58:53,463 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: The ETag of url https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f... is dc6b08e1d950877a98c82379d1b58238:1730394818.15428
2024-11-11 18:58:53,463 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...' to option 'StreamerRootUrl'
2024-11-11 18:58:53,463 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'dc6b08e1d950877a98c82379d1b58238:1730394818.15428' to option 'ETag'
2024-11-11 18:58:53,463 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.utils - INFO :: Write value 'production' to option 'InstallStream'
2024-11-11 18:58:53,464 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 1341bb4b8566410e9c7c8aef52bcb222(FILE_ASSOCIATIONS)
2024-11-11 18:58:53,475 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-11 18:58:53,475 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 4afd20f9b05b4349869fb10841d11444(DELIVER_ICON)
2024-11-11 18:58:53,475 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Deliver the icon of Fusion360.exe to the same folder as the Pinnable launcher.
2024-11-11 18:58:53,480 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,480 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico stat result: os.stat_result(st_mode=33206, st_ino=1970324837392322, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=177333, st_atime=1731076828, st_mtime=1730363963, st_ctime=1729426013)
2024-11-11 18:58:53,480 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico st_file_attributes: 32
2024-11-11 18:58:53,482 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,482 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260355, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=40507, st_atime=1731075784, st_mtime=1730364093, st_ctime=1729426013)
2024-11-11 18:58:53,482 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Develop.ico st_file_attributes: 32
2024-11-11 18:58:53,483 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,483 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260356, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39964, st_atime=1731075784, st_mtime=1730364093, st_ctime=1729426013)
2024-11-11 18:58:53,483 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Insider.ico st_file_attributes: 32
2024-11-11 18:58:53,484 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,484 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260357, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39624, st_atime=1731075784, st_mtime=1730364093, st_ctime=1729426013)
2024-11-11 18:58:53,484 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Major.ico st_file_attributes: 32
2024-11-11 18:58:53,485 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,485 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260358, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=39217, st_atime=1731075784, st_mtime=1730364093, st_ctime=1729426013)
2024-11-11 18:58:53,485 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360Minor.ico st_file_attributes: 32
2024-11-11 18:58:53,486 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: The location of Fusion360 icon is: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d
2024-11-11 18:58:53,486 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico stat result: os.stat_result(st_mode=33206, st_ino=1125899907260359, st_dev=2460985963, st_nlink=1, st_uid=0, st_gid=0, st_size=38223, st_atime=1731075785, st_mtime=1730364093, st_ctime=1729426013)
2024-11-11 18:58:53,486 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360PR.ico st_file_attributes: 32
2024-11-11 18:58:53,487 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Special action abd8ee230bcc49f9a56035b8eefedeed(REGISTER_UNINSTALL) was not in registry
2024-11-11 18:58:53,487 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 5ca4357a038540d58fb2092e8a9329a9(REGISTER_SAFE_MODE)
2024-11-11 18:58:53,488 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-11-11 18:58:53,488 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-11-11 18:58:53,489 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - WARNING :: Already installed the latest streamer, do not need to update the streamer
2024-11-11 18:58:53,489 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Streamer folder "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500" is found
2024-11-11 18:58:53,489 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Find the latest streamer executable "C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\20220719105500\streamer.exe"
2024-11-11 18:58:53,490 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.self_deploy - INFO :: Create shortcut file: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\meta\streamer\streamer.bat
2024-11-11 18:58:53,491 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: Creating safe mode registry key "Software\Microsoft\Windows\CurrentVersion\Uninstall\73e72ada57b7480280f7a6f4a289729f"
2024-11-11 18:58:53,491 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-11 18:58:53,491 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-11 18:58:53,491 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-11 18:58:53,509 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-11 18:58:53,509 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-11 18:58:53,509 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 3af6a9fa26704d868bb90e12b3aed9be(EXTERNAL_INSTALLS)
2024-11-11 18:58:53,514 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-11 18:58:53,515 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - INFO :: Executing special action 0b9a4c1251914f7facc25616ea0f9de3(CREATE_LAUNCH_ITEMS)
2024-11-11 18:58:53,519 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.manifests - WARNING :: File reference with id abd72029628f448888fa727750794db8 was not found
2024-11-11 18:58:53,519 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: \\?\C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\FusionLauncher.exe is launchable. Creating a shortcut
2024-11-11 18:58:53,524 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-11 18:58:53,524 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-11 18:58:53,524 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-11 18:58:53,524 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-11 18:58:53,524 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-11 18:58:53,586 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original name: Autodesk Fusion
2024-11-11 18:58:53,586 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: stream name: production
2024-11-11 18:58:53,586 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new name: Autodesk Fusion
2024-11-11 18:58:53,586 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: original launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico Fusion360.ico
2024-11-11 18:58:53,586 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.windows.platform - INFO :: new launch icon: C:\Users\chouj\AppData\Local\Autodesk\webdeploy\production\6a0c9611291d45bb9226980209917c3d\Fusion360.ico
2024-11-11 18:58:53,591 - MainProcess(11688) - ThreadPoolExecutor-1_0 - adsk.dls.streamer.process.process - WARNING :: Exception processing tasks for 07efb585d4f6fba907e5f04825eeaaddeed49dae:
2024-11-11 18:58:53,604 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-11-11 18:58:53,604 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuMzkuNjIuMTA5
2024-11-11 18:58:53,605 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC4xLjExMg==
2024-11-11 18:58:54,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.network_checker - WARNING :: Failed to get local dns 'utf-8' codec can't decode byte 0xa6 in position 0: invalid start byte.
2024-11-11 18:58:54,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS:
2024-11-11 18:58:54,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-11-11 18:58:54,190 - MainProcess(11688) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
IndexError
Message 8 of 9
ciliu
Please help to check the information in the installation error file and how to install it smoothly. Thank you.
Message 9 of 9
ciliu
