Excessive Crashing on Tree Modifications with Latest Update
bryan_moosman
bryan_moosman
Anyone else seeing excessive crashing recently?  I think in the last 3 days, I've seen more crashes than the last 6 months combined.  I've had at least 5 in the last two hours.
I've noticed the crashing occurs frequently when items are added into the tree by various methods - drag and drop body into another component, copy paste from a component, merging components, etc.  Anyone else getting these issues?
Another factor might be that I have a pretty large parametric assembly linked into an upper level assembly that does not capture design history.  Might be something trying to trigger the parametric update any time a component is added in the tree?
RajkumarIlanchelian
@bryan_moosman Does the application present a crash report to be sent? If so can you confirm that you are sending in the report? We can quickly look into the reports submitted by you to see what could be happening.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
bryan_moosman
I've submitted probably a half-dozen or so of the reports.  I can replicate the issue repeatedly if I copy a specific component out of an assembly and try to paste it anywhere.
RajkumarIlanchelian
@bryan_moosman Sorry for the late reply but would you be able to share the assembly that has this specific component? You can post the share link here and password protect it or you can send me the link and password to rajDOTkumarDOTilanchelianATautodeskDOTcom. Please also indicate which component you are trying to copy paste.
Autodesk Fusion
Join Fusion Insider
