Thank you for checking back in on this issue. Our development teams have been able to isolate and correct it, and as long as there are no setbacks, we should see it in an upcoming release.
We found that the issue was limited to models which used prescribed displacements, so in the meantime if you are able to convert this to a force load in your model, you should get results. I know converting from displacements to forces isn't always easy or possible.
If you continue to experience issues even when not using the prescribed displacements, please let us know. Thank you,
Mitch
i don't use prescribed displacements - i'm only using initial linear velocity, and it doesn't work.
it's super easy to replicate the bug. just make two objects, and constrain one, and apply an initial linear velocity to the other, and when you run the event simulation you will see that they don't move.
Thanks again. We were able to test the initial velocity in the patched version and this (and other faulty loads) are working.
