Etch Lines For Laser Cutting
prairieridgeent
prairieridgeent
I'm working on a part that I want to get laser cut and I want to make an etch line on the part so I can know where to weld on another part. Just wondering if anyone has done this before or knows how to do it?
jhackney1972
For you first toolpath, you will select your Laser Tool and set it to Etch instead of cutting through.  You will then select your sketch path, on your model, for the area you want etched.  Screencast will show you the process.
John Hackney, Retired
prairieridgeent
ok thank you
