error
error
Message 1 of 8
error
Replies (7)
Message 2 of 8
TrippyLighting
@jeff_strater This looks like an odd thing.
@Anonymous could you try to uninstall and  re-install Fusion 360 and see if that eliminates this error message ?
Message 3 of 8
I have unistall and reinstalled but is the same
Message 4 of 8
jeff_strater
@ekinsb, is this add-in something that you recognize?  Do you have any clues about what might be going wrong here?
@innovatenate, have you seen anything like this before?
Jeff Strater
Engineering Director
Message 5 of 8
I mounted parallel desktop with windows 10 to try Artcam Free, but then I removed it
Message 6 of 8
innovatenate
Autodesk Support
Autodesk Support
When you uninstalled, did you use the Fusion Cleaner?
Looks like it may be related to the MakeTime add-in @Anonymous could you have a look?
You may want to go through the process of uninstalling the Add-In to see if it helps. I hope it does!
Nathan Chandler
Principal Specialist
Message 7 of 8
no, where do I find it?
Message 8 of 8
solved !!!! used fusion360 cleaner and reinstalled
