Error while trying to sweep a profile along a path
ababmxking
ababmxking
I am receiving this error while trying to sweep this profile along the path. I had this work one time, of which i had some dims wrong on the profile, but have not had any luck since. Attached is some screen shots of the errors, and of the profile.
jhackney1972
You have attached your DXF profile for the sweep but you failed to provide the model to apply the sweep to.  Please attach it as well.  Also, do you want the DXF profile cut or joined to the base model?
If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
ababmxking
My apologies. I tried to attach it as a .f3z file, but the site is giving the following error, so I'm not sure what to do.  I am trying to cut the profile.
Error:
Correct the highlighted errors and try again.
  • The attachment's fan shroud cut template wip 3 v2.f3z content type (application/fusion) does not match its file extension and has been removed.
Here is a link to the file in my google drive.
.f3z File Download
