Error when circular patterning threaded holes
Pattern of threaded holes - works as intended if the threads are not modelled.
Weird if the threads are modelled. (using the model check-box in the hole generator)
https://a360.co/2Sgpr4d
BR
David
karina.harper
Autodesk Support
Autodesk Support
Hi @Anonymous
It looks like it works ok for me if I change the compute option to "Optimized".
karina.harper
Autodesk Support
Autodesk Support
This has been logged internally as FUS-46923
Ok, Thanks!
David
i-make-robots
"Tips: When patterning features, use Optimized compute where possible to improve performance."
If this is the most-encouraged option then why is it not the default?  Confused.
(here because I hit the exact same problem and "Adjust" was the default.)
eros_nicolau
That did it for me
