Error the local project is not aggregated
luciano.larocca
luciano.larocca
Good evening, after finishing our work on the attached piece, this error appears at the bottom right: Error the local project is not aggregated. We do not understand what it means, you know how to explain us.
https://a360.co/343TZ0a
dsouzasujay
Hi @luciano.larocca,
I was not able to see any any issues on my machine.
A screencast/video of what you are doing will help me to understand the problem. 
Opening the design or solving the study didn't gave any errors
A screencast/video of showing the error message will help me to understand the problem.
Also, please share the Diagnostic Log Files.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luciano.larocca
Here you are
dsouzasujay
@luciano.larocca,
Thank you for the video.
I can see the error message when switching to Manufacture workspace.
Give me sometime, I will check with development team and respond you back as earliest.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luciano.larocca
Thank you so much for the help
dsouzasujay
Development team are looking into this, I have created an internal ticket to track this issue CAM-34626
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
luciano.larocca
Thank you very much indeed
