Error joining linked design
Issue: while insterting a new joint to a linked design, I directly get the warning 'reference failure'.
Starting point:
An existing 'design A' used as master design
An exsiting 'design B' used as linked design
I want to insert the design B in master design A and link them together over two defined O-joint in both design.
So I did:
1) insert design B in master design A
2) Joining design B to master design A: Add joint using O-Joint in design A and B. See join 'Rigide18'
in picture: Fusion 360, Support Error joint with linked design, Original design Browser-View.PNG
3) Warning appear:
Picture: Fusion 360, Support Error joint with linked design, Original design Error text.PNG
4) no way to solve this warning expect following workaround.
Successfull tesded Workarounds:
1) Start new master design C
2) In Design A 'break Link' of linked design B.
3) Use Origin in design B instead of O-Joint.
None of the workaround are an alternative for me because of the extensive timeline of the design A.
Can you explain me what can be the issue?
Best regards
Nicolas
Timeline Design A
Browser design A (moldframe v5), Use O-Joint 'interface frame-mold' and 'FrameInterface'
Warning canot be solved.
Workaruond with new design C
