Error: Internal CAM kernel error. Please report through your support channel.
giulio.ranalli
giulio.ranalli
Doesn't matter what I change , what name I give to the tool, what cutting strategy I choose, what shape/surface I try to work,....always, from today, the software, always return the message:
even using the same identical setting and tools that worked until two days ago...and even trying to do just some modification to an existing too-path.....what is wrong?....
my version is  2.0.12157
Please help
RajkumarIlanchelian
 I believe this is the same issue discussed in this thread - https://forums.autodesk.com/t5/fusion-360-support/after-the-recent-update-this-is-happening-while-tr...
Are you on Windows 7? If so then this is an unsupported OS.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
giulio.ranalli
"Are you on Windows 7? If so then this is an unsupported OS."...thanks to let me know this....it is , really , a great acknowledgment.....but your reply to my post didn't helped one micron to solve the issue......I already solved it....
