Having trouble making a cut from a sketch. I've tried defining the sketch 3 different ways and received 3 different errors. In all cases, the sketch was derived from projected lines that were "broken link"ed into sketch lines.
- When the sketch (sketch 10) is defined by the body face, extrude positive direction, I get the "inconsistent edge-face relationships" error.
- When the sketch (sketch 11) is defined by the x-y plane, extrude positive direction, I get the "system inconsistency processing surface tangency" error
- When the sketch (sketch 12) is defined by a construction plane offset parallel to the x-y plane, extrude negative direction, I get the "There was a problem combining geometry together. If attempting a Join/Cut/Intersect, try to ensure that the bodies have a clear overlap (problems can occur where faces and edges are nearly coincident).
The first method worked for sketch 9 in the areas above and below the trouble selection represented by extrude 7 & 8 in the design history.
I'm planning to run this on a CNC router/mill.
Any advice?
Thank you
