hello @anibalnoval
Apparently, you have used the tormach post.
I opened your fusion file, the toolpath is a wrapped toolpath.
So it's a 4 axis toolpath.
The error message is only the post porcessor telling you that it currently doesn't support 4-5 axis toolpath.
First of all, look at your machine kinematic, the look closely in the post porcessing dialog there is an array containing the post properties.
One of them is called :
you need to switch the value from none to somethink similar to your kinematic.
The available options are rotary axis around:
X, or Y, or Z
You should elect one of thes option.
By default without setting some properties or editing the post, our post support 3 axis toolpath. They are 5 axis ready, but the kinematic need to be defined one way or another.
On the Tormach post, 4th axis is enabled via this property.
On other post, it could be different.
Hop it will solve your issue.
Have a nice day.
protect yourself and your family, from Covid.
______________________________________________________________
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
