error in insttalation here is postfile
anthonychristy
anthonychristy
Community Visitor
Community Visitor
2024-04-21 18:07:28,033 - MainProcess(2708) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:07:28,034 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:07:28,035 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:07:28,035 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x00000288B4EED0D0> #
2024-04-21 18:07:28,035 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:07:28,036 - MainProcess(2708) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zSAD15.tmp\resources\buildinfo.json
2024-04-21 18:07:28,036 - MainProcess(2708) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:07:28,037 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:07:28,037 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:07:28,038 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zSAD15.tmp\resources
2024-04-21 18:07:28,040 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zSAD15.tmp\certs.pem
2024-04-21 18:07:28,040 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:07:28,044 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:07:28,044 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:07:28,045 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x00000288B4ED9440>, operation=<function multiple_operate at 0x00000288B45B19E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:07:28,045 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:07:28,045 - MainProcess(2708) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:07:28,045 - MainProcess(2708) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:07:28,046 - MainProcess(2708) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:07:28,792 - MainProcess(5960) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:07:28,815 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:07:28,816 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:07:28,816 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002562122CE50> #
2024-04-21 18:07:28,816 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:07:28,816 - MainProcess(5960) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zSBE5B.tmp\resources\buildinfo.json
2024-04-21 18:07:28,817 - MainProcess(5960) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:07:28,817 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:07:28,818 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:07:28,819 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zSBE5B.tmp\resources
2024-04-21 18:07:28,824 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zSBE5B.tmp\certs.pem
2024-04-21 18:07:28,824 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:07:28,836 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:07:28,837 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:07:28,837 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000025621219440>, operation=<function multiple_operate at 0x00000256208F19E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:07:28,838 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:07:28,838 - MainProcess(5960) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:07:28,838 - MainProcess(5960) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:07:28,838 - MainProcess(5960) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:07:29,858 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:07:29,927 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:07:30,062 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:07:30,084 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:07:31,347 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.registry - WARNING :: Registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track cannot opened because of error [Errno 2] No such file or directory: 'C:\\Users\\hp\\AppData\\Local\\Autodesk\\webdeploy\\meta\\registry_track'.
2024-04-21 18:07:31,348 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-04-21 18:07:31,350 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-21 18:07:31,350 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "An installation is already in progress"
2024-04-21 18:07:31,362 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.registry - INFO :: Failed to query database schema, initializing.
2024-04-21 18:07:31,367 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-21 18:07:31,368 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-04-21 18:07:31,368 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-04-21 18:07:31,369 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-04-21 18:07:31,369 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:07:31,369 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\hp\AppData\Local\Autodesk\check_perm created successfully
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\hp\AppData\Local\Autodesk\check_perm removed successfully
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\hp\AppData\Local\Autodesk
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-04-21 18:07:31,370 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:07:31,487 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:31,487 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:31,487 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:31,488 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-21 18:07:31,488 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-21 18:07:31,758 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.50.246.61
2024-04-21 18:07:31,841 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:07:32,061 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:07:32,062 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:07:32,062 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:07:32,062 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-21 18:07:32,413 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000025621247210>
2024-04-21 18:07:32,414 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:07:32,480 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:07:32,480 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:07:32,481 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:07:32,481 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:07:32,519 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:32,519 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:32,519 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:32,862 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-04-21 18:07:32,862 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-04-21 18:07:32,863 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-04-21 18:07:32,863 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:07:32,901 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:32,901 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:32,901 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:33,285 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000025621263550>
2024-04-21 18:07:33,285 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:07:33,371 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:07:33,371 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:07:33,410 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:33,410 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:33,411 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:33,785 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000025621263410>
2024-04-21 18:07:33,786 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-04-21 18:07:33,786 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-04-21 18:07:33,786 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:07:33,823 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:33,823 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:33,823 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:34,116 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000025621262E50>
2024-04-21 18:07:34,117 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:07:34,207 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:07:34,208 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:07:34,208 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:07:34,208 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:07:34,244 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:34,244 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:34,245 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:34,551 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-04-21 18:07:34,551 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-04-21 18:07:34,551 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-04-21 18:07:34,551 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:07:34,552 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:07:34,609 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:07:34,609 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:07:34,609 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:07:34,957 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 137c025b-9d09-4739-a8c0-5f9f3ef303fe
2024-04-21 18:07:34,960 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18961 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-21 18:07:34,960 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:07:34,963 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-21 18:07:34,963 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-21 18:07:35,098 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 10586] is unsupported.
2024-04-21 18:07:35,169 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:07:35,170 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:07:35,170 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:07:35,596 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgZG5zLmdvb2dsZQ0sIEFkZHJlc3M6ICAyMDAxOjQ4NjA6NDg2MDo6ODg4OA0=
2024-04-21 18:07:35,596 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:07:35,597 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:08:10,906 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:08:10,907 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:08:12,714 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-04-21 18:08:12,729 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:08:12,730 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:08:12,730 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:08:12,730 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000002562122CE50> #
2024-04-21 18:08:12,730 - MainProcess(5960) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:08:15,974 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:08:15,974 - MainProcess(2708) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:12:30,809 - MainProcess(2348) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:12:30,810 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:12:30,810 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:12:30,810 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001F2B064D110> #
2024-04-21 18:12:30,811 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:12:30,811 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:12:30,811 - MainProcess(2348) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zS640D.tmp\resources\buildinfo.json
2024-04-21 18:12:30,812 - MainProcess(2348) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:12:30,812 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:12:30,812 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:12:30,813 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zS640D.tmp\resources
2024-04-21 18:12:30,815 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zS640D.tmp\certs.pem
2024-04-21 18:12:30,815 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:12:30,818 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:12:30,818 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:12:30,820 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001F2B0639300>, operation=<function multiple_operate at 0x000001F2AFD118A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:12:30,820 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:12:30,820 - MainProcess(2348) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:12:30,820 - MainProcess(2348) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:12:30,821 - MainProcess(2348) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:12:31,765 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:12:31,896 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:12:33,168 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-21 18:12:33,171 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-21 18:12:33,172 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-21 18:12:33,172 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-04-21 18:12:33,173 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-04-21 18:12:33,173 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-04-21 18:12:33,173 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:12:33,174 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\hp\AppData\Local\Autodesk\check_perm created successfully
2024-04-21 18:12:33,174 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:12:33,174 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\hp\AppData\Local\Autodesk\check_perm removed successfully
2024-04-21 18:12:33,175 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\hp\AppData\Local\Autodesk
2024-04-21 18:12:33,175 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-04-21 18:12:33,175 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-04-21 18:12:33,175 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:12:33,262 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:33,263 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:33,263 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:33,263 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-21 18:12:33,263 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-21 18:12:33,730 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.50.246.61
2024-04-21 18:12:33,810 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:12:33,891 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:12:33,891 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:12:33,892 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:12:33,892 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-21 18:12:34,246 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001F2B066E650>
2024-04-21 18:12:34,246 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:12:34,325 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:12:34,325 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:12:34,326 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:12:34,326 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:12:34,367 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:34,368 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:34,368 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:34,706 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-04-21 18:12:34,706 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-04-21 18:12:34,706 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-04-21 18:12:34,706 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:12:34,748 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:34,749 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:34,749 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:35,064 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001F2B0683250>
2024-04-21 18:12:35,064 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:12:35,142 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:12:35,143 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:12:35,180 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:35,180 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:35,181 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:35,518 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001F2B0683210>
2024-04-21 18:12:35,519 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-04-21 18:12:35,519 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-04-21 18:12:35,519 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:12:35,594 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:35,594 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:35,594 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:35,927 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001F2B0683210>
2024-04-21 18:12:35,927 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:12:36,012 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:12:36,013 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:12:36,013 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:12:36,013 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:12:36,060 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:36,060 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:36,061 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:36,347 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-04-21 18:12:36,347 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-04-21 18:12:36,347 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-04-21 18:12:36,347 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:12:36,348 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:12:36,406 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:12:36,406 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:12:36,406 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:12:36,740 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 0c971aad-409a-467c-9b8f-5473e1b9c89c
2024-04-21 18:12:36,743 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18961 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-21 18:12:36,743 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:12:36,746 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-21 18:12:36,746 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-21 18:12:36,861 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 10586] is unsupported.
2024-04-21 18:12:36,942 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:12:36,943 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:12:36,943 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:12:37,266 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgZG5zLmdvb2dsZQ0sIEFkZHJlc3M6ICAyMDAxOjQ4NjA6NDg2MDo6ODg4OA0=
2024-04-21 18:12:37,266 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:12:37,267 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2024-04-21 18:12:38,390 - MainProcess(1020) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:12:38,410 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:12:38,410 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:12:38,410 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001AFCEF3D110> #
2024-04-21 18:12:38,411 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:12:38,411 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:12:38,412 - MainProcess(1020) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zS7EE8.tmp\resources\buildinfo.json
2024-04-21 18:12:38,412 - MainProcess(1020) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:12:38,413 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:12:38,413 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:12:38,414 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zS7EE8.tmp\resources
2024-04-21 18:12:38,415 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zS7EE8.tmp\certs.pem
2024-04-21 18:12:38,416 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:12:38,419 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:12:38,420 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:12:38,420 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001AFCEF29300>, operation=<function multiple_operate at 0x000001AFCE6018A0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:12:38,420 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:12:38,420 - MainProcess(1020) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:12:38,421 - MainProcess(1020) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:12:38,421 - MainProcess(1020) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:12:39,106 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:12:39,202 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:12:40,471 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.registry - INFO :: Close registry connection.
2024-04-21 18:12:40,471 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: The registry is locked at this moment. Please refer to detailed information: "This process failed because of another installer deploy in process"
2024-04-21 18:13:05,144 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:13:05,145 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:13:05,145 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:13:05,145 - MainProcess(1020) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001AFCEF3D110> #
2024-04-21 18:13:07,028 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:13:07,029 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:13:08,671 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-04-21 18:13:08,693 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:13:08,693 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:13:08,693 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:13:08,693 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001F2B064D110> #
2024-04-21 18:13:08,693 - MainProcess(2348) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:20:53,640 - MainProcess(5924) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:20:53,642 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:20:53,642 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:20:53,642 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001953E26CDD0> #
2024-04-21 18:20:53,643 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:20:53,643 - MainProcess(5924) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zS121E.tmp\resources\buildinfo.json
2024-04-21 18:20:53,644 - MainProcess(5924) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:20:53,644 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:20:53,645 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:20:53,646 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zS121E.tmp\resources
2024-04-21 18:20:53,647 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zS121E.tmp\certs.pem
2024-04-21 18:20:53,648 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:20:53,652 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:20:53,652 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:20:53,653 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x000001953E259440>, operation=<function multiple_operate at 0x000001953E1319E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:20:53,653 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:20:53,653 - MainProcess(5924) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:20:53,654 - MainProcess(5924) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:20:53,654 - MainProcess(5924) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:20:54,971 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:20:55,112 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:20:56,864 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-21 18:20:56,868 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-21 18:20:56,868 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-21 18:20:56,869 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-04-21 18:20:56,870 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-04-21 18:20:56,870 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-04-21 18:20:56,871 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:20:56,872 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\hp\AppData\Local\Autodesk\check_perm created successfully
2024-04-21 18:20:56,872 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:20:56,873 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\hp\AppData\Local\Autodesk\check_perm removed successfully
2024-04-21 18:20:56,873 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\hp\AppData\Local\Autodesk
2024-04-21 18:20:56,873 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-04-21 18:20:56,873 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-04-21 18:20:56,874 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:20:57,096 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:20:57,097 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:20:57,097 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:20:57,097 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-21 18:20:57,098 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-21 18:20:58,567 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 104.85.128.189
2024-04-21 18:20:58,643 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:20:58,810 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg1LjEyOC4xODk=
2024-04-21 18:20:58,811 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:20:58,811 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:20:58,812 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-21 18:20:59,170 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001953E28E5D0>
2024-04-21 18:20:59,173 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:20:59,319 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:20:59,320 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.85.128.189
2024-04-21 18:20:59,320 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:20:59,320 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:20:59,506 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:20:59,506 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:20:59,506 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:20:59,919 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-04-21 18:20:59,919 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-04-21 18:20:59,920 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-04-21 18:20:59,920 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:21:00,137 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:00,137 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:00,137 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:00,491 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001953E2A32D0>
2024-04-21 18:21:00,494 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:21:00,563 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:00,564 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.85.128.189
2024-04-21 18:21:00,753 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:00,753 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:00,754 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:01,066 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001953E2A3050>
2024-04-21 18:21:01,069 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-04-21 18:21:01,069 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-04-21 18:21:01,070 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:21:01,262 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:01,263 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:01,263 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:01,652 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x000001953E2A2C50>
2024-04-21 18:21:01,654 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:21:01,729 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:01,730 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 104.85.128.189
2024-04-21 18:21:01,730 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:21:01,731 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:21:01,930 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:01,931 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:01,931 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:02,474 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-04-21 18:21:02,474 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-04-21 18:21:02,474 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-04-21 18:21:02,475 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:21:02,475 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:21:02,678 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:02,678 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:02,678 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:03,052 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is 5d5f4a50-a24d-4aa1-8a35-4a2fc4422372
2024-04-21 18:21:03,054 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18961 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-21 18:21:03,055 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:21:03,058 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-21 18:21:03,058 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-21 18:21:03,166 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 10586] is unsupported.
2024-04-21 18:21:03,241 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:03,243 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MTA0Ljg1LjEyOC4xODk=
2024-04-21 18:21:03,243 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:21:21,216 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: RE5TIHJlcXVlc3QgdGltZWQgb3V0Lg0sICAgICB0aW1lb3V0IHdhcyAyIHNlY29uZHMuDQ==
2024-04-21 18:21:21,216 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:21:21,217 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
2024-04-21 18:21:24,343 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:21:24,344 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:21:26,320 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-04-21 18:21:26,384 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:21:26,384 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:21:26,384 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:21:26,384 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x000001953E26CDD0> #
2024-04-21 18:21:26,385 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:21:26,385 - MainProcess(5924) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:21:50,403 - MainProcess(6572) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:21:50,404 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:21:50,404 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:21:50,405 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000027D0552D1D0> #
2024-04-21 18:21:50,405 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:21:50,405 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:21:50,405 - MainProcess(6572) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zSF47F.tmp\resources\buildinfo.json
2024-04-21 18:21:50,406 - MainProcess(6572) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:21:50,406 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:21:50,406 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:21:50,407 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zSF47F.tmp\resources
2024-04-21 18:21:50,409 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zSF47F.tmp\certs.pem
2024-04-21 18:21:50,409 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:21:50,412 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:21:50,412 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:21:50,413 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000027D05519440>, operation=<function multiple_operate at 0x0000027D04BF19E0>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:21:50,413 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:21:50,413 - MainProcess(6572) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:21:50,414 - MainProcess(6572) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:21:50,414 - MainProcess(6572) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:21:51,106 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:21:51,180 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:21:52,370 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-21 18:21:52,373 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-21 18:21:52,373 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-21 18:21:52,374 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-04-21 18:21:52,374 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-04-21 18:21:52,375 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-04-21 18:21:52,375 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:21:52,375 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\hp\AppData\Local\Autodesk\check_perm created successfully
2024-04-21 18:21:52,376 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:21:52,376 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\hp\AppData\Local\Autodesk\check_perm removed successfully
2024-04-21 18:21:52,376 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\hp\AppData\Local\Autodesk
2024-04-21 18:21:52,376 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-04-21 18:21:52,376 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-04-21 18:21:52,377 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:21:52,427 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:52,427 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:52,427 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:52,427 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-21 18:21:52,428 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-21 18:21:52,770 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 49.44.206.130
2024-04-21 18:21:52,959 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:53,191 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NDkuNDQuMjA2LjEzMA==
2024-04-21 18:21:53,192 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:21:53,192 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:21:53,192 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-21 18:21:53,470 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000027D0554E750>
2024-04-21 18:21:53,471 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:21:53,552 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:53,553 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 49.44.206.130
2024-04-21 18:21:53,553 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:21:53,553 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:21:53,589 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:53,589 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:53,589 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:54,012 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-04-21 18:21:54,012 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-04-21 18:21:54,012 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-04-21 18:21:54,012 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:21:54,049 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:54,050 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:54,050 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:54,541 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000027D0555F150>
2024-04-21 18:21:54,542 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:21:54,621 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:54,621 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 49.44.206.130
2024-04-21 18:21:54,657 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:54,657 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:54,657 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:55,043 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000027D0555F010>
2024-04-21 18:21:55,044 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-04-21 18:21:55,044 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-04-21 18:21:55,044 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:21:55,089 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:55,089 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:55,089 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:55,515 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000027D0555EAD0>
2024-04-21 18:21:55,515 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:21:55,592 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:55,593 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 49.44.206.130
2024-04-21 18:21:55,593 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:21:55,593 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:21:55,628 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:55,629 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:55,629 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:56,055 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-04-21 18:21:56,055 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-04-21 18:21:56,055 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-04-21 18:21:56,056 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:21:56,056 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:21:56,093 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:21:56,093 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:21:56,093 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:21:56,627 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is ca644fde-c62d-451b-9751-f40998ec1e28
2024-04-21 18:21:56,630 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18961 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-21 18:21:56,630 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:21:56,633 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-21 18:21:56,633 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-21 18:21:56,715 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 10586] is unsupported.
2024-04-21 18:21:56,782 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:21:56,782 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: NDkuNDQuMjA2LjEzMA==
2024-04-21 18:21:56,783 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:22:14,714 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: RE5TIHJlcXVlc3QgdGltZWQgb3V0Lg0sICAgICB0aW1lb3V0IHdhcyAyIHNlY29uZHMuDQ==
2024-04-21 18:22:14,715 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:22:14,715 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
Traceback (most recent call last):
File "R:\src\adsk\dls\streamer\process\process.py", line 1190, in execute
File "R:\src\adsk\dls\streamer\process\deploy_process.py", line 95, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 1120, in execute_without_errorhandling
File "R:\src\adsk\dls\streamer\process\process.py", line 924, in _config_app
File "R:\src\adsk\dls\streamer\process\process.py", line 415, in _executetasks
File "R:\src\adsk\dls\streamer\platform_base.py", line 484, in check_required_version
adsk.dls.streamer.exceptions.UnsupportedOSVersion: The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:23:28,040 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:23:28,041 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.process.process - WARNING :: Exception in Deploy The current operating system is unsupported, this application requires Windows 10 Build 1803
2024-04-21 18:23:29,828 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.registry - INFO :: Shutting down database connection
2024-04-21 18:23:29,847 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: Shutting down configurator object
2024-04-21 18:23:29,847 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ##################################### End #####################################
2024-04-21 18:23:29,847 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:23:29,848 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000027D0552D1D0> #
2024-04-21 18:23:29,848 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:23:29,848 - MainProcess(6572) - InstallDriver - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:24:07,182 - MainProcess(7716) - MainThread - adsk.dls.streamer - DEBUG :: Logging initialized, with level 10, output file: C:\Users\hp\AppData\Local\Autodesk\autodesk.webdeploy.streamer.log
2024-04-21 18:24:07,183 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: #################################### Begin ####################################
2024-04-21 18:24:07,183 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: # #
2024-04-21 18:24:07,183 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: # <adsk.dls.streamer.configuration.Configurator object at 0x0000020F766FCBD0> #
2024-04-21 18:24:07,184 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: ###############################################################################
2024-04-21 18:24:07,184 - MainProcess(7716) - MainThread - adsk.dls.streamer.manifests - INFO :: Loading build manifest from C:\Users\hp\AppData\Local\Temp\7zS9A3.tmp\resources\buildinfo.json
2024-04-21 18:24:07,184 - MainProcess(7716) - MainThread - adsk.dls.streamer.manifests - DEBUG :: Searching for manifest object member: feature-version
2024-04-21 18:24:07,185 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: The streamer version is: 20240201094011
2024-04-21 18:24:07,185 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Loading default language: en_US
2024-04-21 18:24:07,186 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - DEBUG :: Resource directory set to: C:\Users\hp\AppData\Local\Temp\7zS9A3.tmp\resources
2024-04-21 18:24:07,188 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - INFO :: Setup SSL_CERT_FILE environment variable to C:\Users\hp\AppData\Local\Temp\7zS9A3.tmp\certs.pem
2024-04-21 18:24:07,188 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Defining command line arguments
2024-04-21 18:24:07,191 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Overriding standard streams to capture output
2024-04-21 18:24:07,191 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Parsing command line arguments
2024-04-21 18:24:07,192 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - INFO :: Command-Line Argument Configuration:
Namespace(procfac=<function deploy_process at 0x0000020F77368FE0>, operation=<function multiple_operate at 0x0000020F76A41760>, app_id='73e72ada57b7480280f7a6f4a289729f', language='en', connection='https://dl.appstreaming.autodesk.com/production/', update_connection=None, stream='production', globalinstall=False, no_auto_launch=False, no_uninstall_registry=False, install_origin='Streamer', profile=False, threadscount=5, installlocation=None, ppid=-1, force_full=False, purge=False, cleanup=False, silent=False, launch_args='', pull_dest=None, loglevel=20, logfile=None, headless=False, pipes=None, quietmode=False, infofile=None, no_cleanup=False, cleancacheall=False, removeuserdata=False, removeusercred=False, deep_clean=False)
2024-04-21 18:24:07,192 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - INFO :: >>>>>>>> app id is 73e72ada57b7480280f7a6f4a289729f ---- stream is production ---- global install is False <<<<<<<<
2024-04-21 18:24:07,192 - MainProcess(7716) - MainThread - adsk.dls.streamer.__main__ - DEBUG :: Resetting the standard streams
2024-04-21 18:24:07,193 - MainProcess(7716) - MainThread - adsk.dls.streamer - INFO :: New logging level: 20
2024-04-21 18:24:07,193 - MainProcess(7716) - MainThread - adsk.dls.streamer.configuration - INFO :: Overriding Connection String: https://dl.appstreaming.autodesk.com/production/
2024-04-21 18:24:07,999 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Start to run process: Deploy
2024-04-21 18:24:08,067 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.configuration - INFO :: The PAC invoking process was enabled but the proxy is empty
2024-04-21 18:24:09,323 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.registry - INFO :: registry track file C:\Users\hp\AppData\Local\Autodesk\webdeploy\meta\registry_track is created.
2024-04-21 18:24:09,326 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 3
2024-04-21 18:24:09,327 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.registry - INFO :: Existing database is at revision 4
2024-04-21 18:24:09,327 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Running pre-checks.
2024-04-21 18:24:09,328 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: precheckclass:- [<class 'adsk.dls.streamer.prechecks.CheckFolderAccessibility'>, <class 'adsk.dls.streamer.prechecks.CheckSSLCertificateIssue'>, <class 'adsk.dls.streamer.prechecks.CheckNetworkConnectivity'>, <class 'adsk.dls.streamer.prechecks.DiskSpaceFull'>]
2024-04-21 18:24:09,328 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckFolderAccessibility
2024-04-21 18:24:09,328 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Creating emptry directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:24:09,329 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory: C:\Users\hp\AppData\Local\Autodesk\check_perm created successfully
2024-04-21 18:24:09,330 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Removing directory: C:\Users\hp\AppData\Local\Autodesk\check_perm
2024-04-21 18:24:09,330 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Directory C:\Users\hp\AppData\Local\Autodesk\check_perm removed successfully
2024-04-21 18:24:09,330 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Full owner permission found on directory: C:\Users\hp\AppData\Local\Autodesk
2024-04-21 18:24:09,330 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckFolderAccessibility, Result:- SUCCESS
2024-04-21 18:24:09,331 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckSSLCertificateIssue
2024-04-21 18:24:09,331 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:24:09,378 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:09,379 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:09,379 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:09,379 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Begin of logging network information.
2024-04-21 18:24:09,379 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Proxy mode: ProxyMode.LEGACY
2024-04-21 18:24:09,761 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Domain name : dl.appstreaming.autodesk.com, edge server ip : 23.50.246.61
2024-04-21 18:24:09,830 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:24:09,937 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:24:09,938 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:24:09,938 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:24:09,938 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: End of logging network information.
2024-04-21 18:24:10,242 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020F7739E450>
2024-04-21 18:24:10,243 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:24:10,311 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:24:10,311 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:24:10,312 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:24:10,312 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:24:10,348 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:10,348 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:10,348 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:10,686 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: No problem in SSL Certificate
2024-04-21 18:24:10,686 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckSSLCertificateIssue, Result:- SUCCESS
2024-04-21 18:24:10,686 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- CheckNetworkConnectivity
2024-04-21 18:24:10,686 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:24:10,722 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:10,722 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:10,722 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:11,033 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020F773B2E10>
2024-04-21 18:24:11,034 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:24:11,111 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:24:11,112 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:24:11,147 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:11,148 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:11,148 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:11,566 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Network connectivity is OK <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020F773B2CD0>
2024-04-21 18:24:11,567 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- CheckNetworkConnectivity, Result:- SUCCESS
2024-04-21 18:24:11,567 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Start to execute pre-check:- DiskSpaceFull
2024-04-21 18:24:11,567 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking internet connectivity
2024-04-21 18:24:11,604 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:11,605 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:11,605 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:11,933 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Internet connectivity is OK. <adsk.dls.streamer.netlib._ResilientRequest object at 0x0000020F773B2750>
2024-04-21 18:24:11,933 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Checking DNS
2024-04-21 18:24:12,004 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: The domain dl.appstreaming.autodesk.com is accessible
2024-04-21 18:24:12,004 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Domain name : dl.appstreaming.autodesk.com, host ip : 23.50.246.61
2024-04-21 18:24:12,005 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:24:12,005 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:24:12,040 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:12,040 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:12,040 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:12,368 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Sufficient disk space found on system.
2024-04-21 18:24:12,368 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.prechecks - INFO :: Finish executing pre-check:- DiskSpaceFull, Result:- SUCCESS
2024-04-21 18:24:12,368 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.deploy_process - INFO :: Pre-check run is complete. Return value: {}
2024-04-21 18:24:12,369 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Pulling application manifest: 73e72ada57b7480280f7a6f4a289729f version: None
2024-04-21 18:24:12,369 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.manifests - INFO :: Opening manifest at: https://dl.appstreaming.autodesk.com/production/67316f5e79bc48318aa5f7b6bb58243d/73e72ada57b7480280f...
2024-04-21 18:24:12,406 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: ProxyServer:
2024-04-21 18:24:12,407 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup HTTPSHandler
2024-04-21 18:24:12,407 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.netlib - INFO :: Setup AuthHandler
2024-04-21 18:24:12,721 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The session id is bd02864f-4ebd-4c87-bdab-24d3ebbf2025
2024-04-21 18:24:12,724 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Configure app begin Deploy to 2.0.18961 for app 73e72ada57b7480280f7a6f4a289729f
2024-04-21 18:24:12,724 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detecting the orphans ...
2024-04-21 18:24:12,726 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Executing special action 839cfbb44dc7466fa5ed8a9c7e749813(CHECK_SUPPORTED_OS)
2024-04-21 18:24:12,727 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Required OS version: [10, 0, 17134]
2024-04-21 18:24:12,804 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.platform_base - INFO :: Current OS version [10, 0, 10586] is unsupported.
2024-04-21 18:24:12,862 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: The host dl.appstreaming.autodesk.com is accessible
2024-04-21 18:24:12,863 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: S_I: MjMuNTAuMjQ2LjYx
2024-04-21 18:24:12,863 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: C_PR_I: MTkyLjE2OC40My4yNDE=
2024-04-21 18:24:13,155 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Local DNS: U2VydmVyOiAgZG5zLmdvb2dsZQ0sIEFkZHJlc3M6ICAyMDAxOjQ4NjA6NDg2MDo6ODg4OA0=
2024-04-21 18:24:13,156 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - INFO :: Detected proxies: e30=
2024-04-21 18:24:13,156 - MainProcess(7716) - InstallDriver - adsk.dls.streamer.process.process - ERROR :: Exception during processing:
evanss801
I too am getting errors with SSL certificates when trying to install the FUSION 360 Client Downloader.exe file.
I have worked this through with support (about as much use as a chocolate kettle) and they have directed me to the forums.
I have added as many domains as you list within your technical pages to our internet filtering services, I have checked root certificates and removed them to no avail, I have checked AntiVirus isnt blocking anything and its not.
The last thing I can think is that your hosting server for the client downloader security certificates are not up to date and are possibly causing this error.
