Error: Failed to save the zip package C:/Users/
christopher2KLSVU
christopher2KLSVU
Error: Failed to save the zip package C:/Users/PC/AppData/Local/Autodesk/Autodesk Fusion 360/QE6AKANAVMGX/W.login/F/_projectname.c5c5fe77-d944-422b-a518-00ecebef426f.f3d.
I gut such error. I just clicked 3D PCB button in 2D editor to update my 3D board view. The 3D pcb model is opened in another fusion instance where it is put in to the case. I usually do it so and have not had any problem at all. After 3D board is regenerated I have yellow warning  in second fusion instance to sync the model what I usually do.
christopher2KLSVU
again after regenerating 3D view,
Error: boost::filesystem::remove: Odmowa dostepu: "C:/Users/PC/AppData/Local/Autodesk/Autodesk Fusion 360/QE6AKANAVMGX/W.login/F/_projectname.c5c5fe77-d944-422b-a518-00ecebef426f.bak"
Odmowa dostepu = Acces restricted
