Error: cloud storage
richard_polzer
Observer Observer
richard_polzer
Observer
Observer
I am new to Autodesk Fusion. I just installed it as academic licensed.  In Abos/Contracts it tells me 250 List Places and due date 12.12.2025.
However, if I try to run a simulation, i always get some kind of error like this:
Connecting Rod Assembly v2: Simulation Model 1 - Studie 1 - Statische Spannung
_____ 2024-12-16 21:39:12 _____
Dokument wird in den Cloud-Speicher hochgeladen. Cloud-Job ist ausstehend.
Lösung wird gestartet
Fehler: Lösung kann nicht gestartet werden, da kein Speicher dafür in der Cloud eingerichtet werden konnte
Can someone give me advice where the problem lies?
RajkumarIlanchelian
@henderh Hugh, any ideas on the error?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
richard_polzer
Observer
Observer
I think the problem was maybe, that I was missing the Autodesk Desktop Connector installation. I downloaded it, but maybe the installation was missing. A bit confusing installation here.
henderh
Hi @richard_polzer,
Fusion Simulation solves shouldn't rely on Desktop Connector. Perhaps the timing was a coincidence.
If you're still having issues, you can try this technical solution article:
In case you encounter the issue again, please attach the Fusion log files when this happens:
  • Help pull-down (upper right of the UI) > Support and Diagnostics > Diagnostic Log Files
Best regards,
ps: thank you for tagging me @RajkumarIlanchelian
Hugh Henderson
QA Engineer (Fusion Simulation)
