Engraving, following a contour, tool placement
Hello
I have some questions regarding engraving that i can't manage.
a) Is there a way to select the position of the tool on the line? As you can see in the picture in A the tool is in the inside of the contour. In B the tool is on the outside of the contour (the program made the selections ). In C because i had two closed loop and the tool selected the inside in both i finally got a double line.
So Is there a way in A to select the tool on the outside or above the line?
In B is there a way to select the tool above the line (on the center?)
In C is there a way to make that line only the tool go on the center?
And finally how can i make the following in OPEN (single) lines?
How does the application selects the contours? It finds closed loops that i do not want.
Should i use another action and not engraving for the above?
Thank you in advance
