Enable Capture Design History as default
programming2C78B
Advisor Advisor
Message 1 of 16
programming2C78B
I'm now programming 2-6 parts every day and getting caught with all the inconviences of being halfway through a sketch when I realize I don't have history enabled. I GET that this apparently uses more cpu/memory, but we literally do not a process a single part without it. Can there please be an option or pop-up ask to enable this every time I open a new part from My Computer (step files from customer)
Please click "Accept Solution" if what I wrote solved your issue!
Replies (15)
Message 2 of 16
davebYYPCU
Check your Preferences, we are all different, but you can set Capture as default.
Might help....
Message 3 of 16
TheCADWhisperer
Might help....
Message 4 of 16
programming2C78B
I did, and always have had the design > design history set to Capture. The issue is this is NOT applied when you import a new model.
Message 5 of 16
g-andresen
Import from other than f3d opens without "History disabled".
günther
Message 6 of 16
TheCADWhisperer
@g-andresen
Did you mean, “without History enabled?”
Message 7 of 16
TrippyLighting
Correct!
Message 8 of 16
g-andresen
Of course I mean it
günther
Message 9 of 16
seth.madore
For anyone that stumbles upon this thread in the future; this is no longer an issue! In the Jan 28th release (2025), imported models will respect your Design History preference. If your preference is set to "Enabled", imported models (STEP, IGES etc) will import with Timeline active.
Seth Madore
Message 10 of 16
bwalker145
Seth, where is this setting located for imports? I thought I had it enabled, but apparently not!
Message 11 of 16
jhackney1972
I have the latest update to Fusion but the feature of automatically turning on Capture Design History does not work when opening STEP files.  In the Animated GIF, I show you that Capture Design History is on in Preferences, I then open a STEP file but the Timeline does not display showing Capture Design History did not activate.
John Hackney, Retired
Message 12 of 16
bwalker145
Thanks John, that's the same behavior I'm experiencing as well. I have that setting set to "Parametric", and imports still don't have "Capture Design History" enabled by default; wasn't sure if there was some other setting/checkbox that I'm missing.
I primarily import parasolid & step, both of which exhibit the same behavior.
Message 13 of 16
TrippyLighting
That is pretty odd!
With the latest release this was enabled by default, and I've used it without problems since on many STEP and even X_T (parasolid) files form a number of different sources.
Either through File->open or through upload to the data panel.
On two different Windows computers.
Message 14 of 16
seth.madore
Interesting. I've got the same settings as @jhackney1972 and am having no issue open up STEP files and have Timeline active 🤔
Seth Madore
Message 15 of 16
bwalker145
Funny enough, this is now working for me. I uploaded a new file (parasolid) today, and it defaulted to parametric. I went back and re-uploaded a file that a couple days ago didn't work as expected, and now it defaulted to parametric as well.
No idea what changed, but at least it's working so far!
Message 16 of 16
jhackney1972
Seth,
I just open two STEP files and like @bwalker145, the Timeline appears as it should, with Capture Design History enabled.  What kinda of magic did you send along the Internet to fix my system. 😁  I am glad it is working and like @bwalker145 I have no idea what happened.
