Empty sketch annoying
benburger852
benburger852
I have the following suggestion/ comments
Maybe I`m the only one but here goes
I have this issue that when I create a new sketch wherever it might be; BUT I then decide its not the right place; I have to finish the sketch
HOWEVER now an empty sketch appears in the history; I then have to go and delete it in the history or as a sketch
Really annoying; can`t the FS360 team do a simple check to see if a sketch is empty and then simply remove it when you click finish
Or am I missing something in FS360; being a total armature !!
My 2 cents worth
Tx Ben
Rushikesh.kadam
@benburger852 you could use the Undo option. Undo > Undo Create Sketch.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
