Emboss issue
Emboss issue
roughcrunch
Emboss issue
roughcrunch
Hi all,
Trying to emboss some text, but it's embossing in an angle... how to make it straight ?
Please help.
Thanks.
g-andresen
create a text on path (arc) and play with the radius
günther
jhackney1972
You can also Emboss to an external cylinder and then trim off what you want using a offset surface copy of the vase shape.  Model is attached.
John Hackney, Retired
roughcrunch
Thanks for your reply, what about deboss? I'd like to "cut" into the model but to keep the same depth.
Using your example I've tried to "Cut" instead of "Join", but the cut for some letters it's deeper than the others..
jhackney1972
You did not originally specify which type of Emboss you desired.  Your model with the letters cut into the vase is attached.
roughcrunch
Managed to cut into the model using a second offset surface. First offset to 0 and second one to -0.4 and then I've split the bodies from letters and combined them with the original model. Thanks for your help.
