Editing single point moves entire sketch
gregduckwitz
Observer Observer
gregduckwitz
Observer
Observer
Hello all - my apologies if this has been covered many before, I just can't find a search result for this anywhere.
I'm also very much an amateur with fusion, I've used it for years in a very niche way but my understanding is limited so bear with me.
I'm trying resize a sketch point by point to a new canvas and I can get every point to resize (with offsets following it) except 4 points.  I can't understand if this is something I'm just missing or maybe can't be done or I'm going about this the wrong way or what.
I'm going to (hopefully) upload a video screencast to show and explain it better.
Running:
Fusion 2.0.19426 arm64 [Native]
macOS 12.3 (21E230) on MacBookPro18,2
Thanks for any help.
jhackney1972
Please attach your model so the Forum users can take a look.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
gregduckwitz
Observer
Observer
Attached is my design/model file.  Thank you.
jhackney1972
I not sure why the point itself will not move but I think you can get the results you desire using the spline handles.  Note that you want to drag the green bars instead of the green curves to maintain sharp points.
gregduckwitz
Observer
Observer
Moving the green handle instead of the point works!  Thank you, I never thought to try that...
