Editing extrusions and workplanes WITHOUT access to history/timeline bar
Can this be done?
If I enable it, should it show features I have made when it wasn't enabled?
TheCADWhisperer
You can use Direct Editing techniques without timeline.
If  you enable Capture Design History - you will capture only history from that point on.
So there's no way at all? Golly, that is rather sucky.
Thanks anyway.
jeff_strater
You might have missed this from @TheCADWhisperer :  "You can use Direct Editing techniques without timeline."  There is quite a bit of editing that you can doin Direct Modeling.  Press/Pull on end and side faces of an Extrude, and you can use Move to re-position a workplane (which you cannot do in timeline mode).  Those editing techniques are not as powerful as parametric editing, but when you don't have a parametric design, you can't expect the power of parametric edit.
Jeff Strater
Engineering Director
