editable projects wont show
dhb9mm
dhb9mm
When i click on the show editable projects button, the refresh button starts going in circles, and never shows my projects. The only way i can open my files, is to go under files and click open. I have restarted the program and my computer.
dhb9mm
now I have reached the maximum editable documents, and I cant get in to change them. I use the personal version so I cant ask regular support.
jhackney1972
Take a look at this forum post and see if one of the suggested solutions help with your issue.
John Hackney, Retired
dhb9mm
  1. In Fusion, go to the "File" menu pull down and go to "View > Show Text Commands" to display the text command input window.  That brings up an input window at the bottom of Fusion.  (If you see "Hide" instead, you are already showing this.)
  2. In that input window, look to the far bottom right side and ensure the selector is set to "Txt".
  3. In the "Type Text Commands Here" field at the bottom, type:
    DataPanel.Reload
