Edit sketch of mirrored component
Sluring
Sluring
I have a component with external subcomponents that is mirrored around a sprue for injection moulding. Now my boss said to me, "Make the prongs on the mirrored component shorter."
How do I do that? I would need to access the sketches in the mirrored component.
If it wasn't for the pointy ends I could just have cut them to the desired length.
g-andresen
1. Have you even considered making a modification other than a sketch modification?
2. Share a file with a specific example.
günther
jhackney1972
You will probably have to use some sort of technique that @g-andresen is suggesting since a mirrored component does not carry a separate sketch.  The original component carries the controlling sketch.
John Hackney, Retired
