Edit joints from the timeline
Hi, I'm new to posting on forums, usually I find the answers that I need online, however I have come across a problem.
When I create a join between components I can create an offset, this really helps with parametric designs.
Unfortunately if I want to go back on the timeline and edit an existing joint it does not give me the chance to create any offsets. I think the image below shows the issue.
I made the joint with no offset but want to change this without disrupting the rest of the model if possible.
Does anyone know if there is a reason for preventing this. When I deselect the components and try to re-select them 1 of the components originally in the joint is greyed out and can't be selected.
The file can be found here if needed: StepLadderV1-v14.f3d or attached with this post
I went through a big learning curve on this project just because I wanted to use parametric design and to utilise the BOM type features to create part drawings automatically.
Steve
