Message 1 of 1
Edit in Place not updating if I move the referenced component
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was trying to use the Edit it place to use a second component to create a new feature in a base part. In the simpliest sense, imagine a flat plate, and then I add a dowel pin to the assembly, positions at an angle across the middle of the plate. I can use the edit in place to using the end of the dowel pin to add a "sleeve" feature to the base part, that part is working fin, but I thought that if I MOVE the dowel pin, relative to the plate, or change its diameter, that the edit in place feature would automatically update, but that does not seem to happen. Am I missing something?
