Edit Feature of Pipe does not work as expected
kdimitoka
kdimitoka
I would like to share a problem regarding pipe editing. In my model, there is a frame which consist of steal profiles (30x30x2 mm).  This frame was created by square hollow pipe command.
When I try to edit pipe properties, I encounter a edit menu which contains wrong property of my pipe. In my case, even though my pipe actual thickness is 2 mm, the edit menu shows 7,5 mm instead of the value (2 mm) of thickness. If I do not notice this situation and then click the OK button, my frame model get updated with wrong value where it shows on edit feature pipe.
I added a couple of screenshot regarding the problem and also I added my fusion model file in this message attachment .
Is there anybody who has lived this problem before? How can I fix it ?
Thanks for your interest in advance,
Kutay
HughesTooling
Seems like a bug. It seems like it's auto populating with a 1/4 the section size. @jeff_strater Is this a known bug?
Mark Hughes
Owner, Hughes Tooling
HughesTooling
If I change your section size to 40mm the wall keeps changing back to 10mm!
Also seems to only be a problem if the pipe is created as a square.
@kdimitoka I did notice after changing to a circular section then back to square it seems to work as expected and stops auto populating with 1/4 the section.
EDIT.
It does affect the other section types when you first create the pipe but if you edit a already created pipe, change the section type and set section thickness and save it stops auto populating when you change back to the original section type.
Mark Hughes
HughesTooling
@Phil.E Is this a known bug?
Thanks Mark
Mark Hughes
Phil.E
It is now. Thanks. FUS-150104
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
