Edit extrusion feature extrudes something I didnt select
IonNight
IonNight
Sometimes, when editing extrusion. Fusion is behaving very weird and extruding all what I didn't select.
11 second video:
https://youtu.be/uTV5H9SS5vk
This has happened many many times, but its always random and I don't know how to reproduce the error.
Is this intentional or am I doing something wrong?
Fusion version: 2.0.20981 x86_64
My PC specs (shouldn't be the issue)
Windows 10 Pro
Intel 9900K (ik its bottlenecked by the GPU)
64GB DDR4 3600
RTX 4090
g-andresen
Obviously you are unintentionally selecting several overlapping profiles.
Move the cursor over the area, click and hold the left mouse button and select (only) the desired profile from the info field
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
IonNight
No, I am obviously holding CTRL to make it easier to select the profile I want without opening the menu to talked about.
The file is not possible to grab, I did a work around.
jeff_strater
Not intentional.  Problems like this do exist, but to fix them, we need the design in the state where it happened.  Next time you run into it, share the model in that state with us.  Thanks.
Jeff Strater
Engineering Director
IonNight
I was intentional holding CTRL. As I'm self tought, I'm not used to all the QOL functions. I've heard someone else talk about that menu you mentioned, but I forget to use it.
I will remember the file sharing next to the next time and  save it as a new file to be able to work on it if you guys want to have a look in the meantime 😄
IonNight
I kinda misread that above. I did not unintentionally select different profiles. I had 1 profile active that was broken, but I worked around it with another extrusion.
This thread will remain unsolved until I get the error again and can provide you with a savefile.
