Edit Canvas Issue
Edit Canvas Issue
simonVNB54
Edit Canvas Issue
simonVNB54
The Edit Canvas command behaviour appears to have changed recently, and is different to what I have experienced in the past.
After I insert a canvas image into a new design, I right-click on the canvas in the browser and click Edit Canvas.
The result is that the image is rotated 90° clockwise and the scale is reset.
It is possible to then rotate and move the canvas from this point. But any edits to the canvas image's position or scale are reset the moment that I select Edit Canvas again.
My desired workflow is:
I would like to add a canvas, calibrate the scale and then move it to the desired location in the work area relative to the origin point.
screen capture: Before
screen capture: After
jhackney1972
It would seem you have not installed the latest update where this error was fixed.  This article mentions this fix.
John Hackney, Retired
