Edge selection set appears to not be working
dagroenewald
Observer Observer
dagroenewald
Observer
Observer
After selecting a number of edges in my model and saving as a selection set I can seem to reselect the set of edges by clicking on the selections sets Select menu option.  Can anyone confirm this is working for them.
pawel.potyrala
Hello @dagroenewald,
thanks for posting!
I just tested the following workflow and cannot seem to reproduce the issue:
  1. Go to Select -> Selection Filters
  2. Disable all options but Body Edges
  3. Select a number of Body Edges
  4. Right-click and Create Selection Set
  5. Re-select the set of edges from within the browser tree.
Here's a screencast:
Is that the workflow that fails for you? Can you make sure that the top component (or a correct component) is activated? If this persists, could you record a short screencast presenting your workflow?
Thanks in advance!
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
dagroenewald
Observer
Observer
Thanks for the response - yes that appears to be the same workflow although I don't have a component just a body on which I am selecting the edges.
The selection seems to show the correct count of the edges.  Not sure I know how to do a screen cast to send you.
pawel.potyrala
Hi @dagroenewald,
thanks for the reply! I just tried this for bodies - it works just as it worked for the components.
Here's an instruction on how to record a screencast:
How to use Autodesk Screencast to document a support issue
Thanks!
Best regards,
Paweł Potyrała
