Edge selection error with German language setting
g-andresen
Consultant Consultant
g-andresen
A post in the German forum drew my attention to a problem with the window selection of edges in the German version.
I thought that this bug has been fixed in the meantime.
Or was it caused by updates again?
@jeff_strater  ; @Phil.E
günther
g-andresen
The same problem occurs with French and Italian.
günther
jeff_strater
can you explain exactly what does not work in German, French, Italian versions?  By default, edges do not select during window select unless only edges are enabled in the selection filter.  Is it Window select of edges?  How about single-click of edges?  Does that work?  What about inside a command, such as Fillet, that allows edge selection?  Does that work?  Can you provide a screencast?  Thanks.
Jeff Strater
Engineering Director
g-andresen
Hi Jeff,
It is only about the priority of window edge selection.
günther
Screencast
jeff_strater
Got it.  If you enable Edge Priority selection in non-English languages, Window select will not select edges.  The Fusion bug is FUS-75479.  Thanks for the clarification, @g-andresen
Jeff Strater
jeff_strater
it seems this bug has already been fixed, and will be included with the Dec update.  Thanks again for reporting it
Jeff Strater
g-andresen
Hi Jeff,
good news
günther
